Quantum: Spherical Harmonics Not Including r^2 term?
  • Thread starter laser1
7 replies · 4K views · last reply
laser1
N/A
N/A
Text stating the l = 1 spherical harmonics Y_1^0 = A cos θ and Y_1^±1 = ∓B sin θ e^(±iφ), and part a asking to normalise them to show A = (3/(4π))^(1/2) = √2 B.
In the solutions, I must integrate ##Y_1^0 Y_1^{\pm 1}##. But my concern is when it states that the differential element (I think area?) is ##d\theta d\phi##. I know that as
Vector differential dl equals dr e_r + r dθ e_θ + r sin(θ) dφ e_φ, written in spherical coordinates with unit vectors e_r, e_θ and e_φ.
then ##dA=r^2 \sin \theta d\theta d\phi##. But the solution only states ##\sin \theta d\theta d\phi##. Why is this? Also, the units are not even area, so I have some problems with what this differential element is.
Is not the differential of area but the solid angle. I am not sure what you want to understand here, the spherical harmonics only are in radial coordinates and pertain only to the angular part.
Where does the ##\sin \theta d\theta d\phi## come from? I had thought it came from the fact that the jacobian in spherical coordinates is ##r^2 \sin \theta## but maybe I was wrong.
Do that and you should get zero, and you will get zero if you do the integration correctly. They are orthogonal functions, after all. What you need to integrate are ##\left(Y_1^0\right)^2## and ##Y_1^{\pm1}\,\left(Y_1^{\pm1}\right)^\ast##.
You are integrating over the surface of the unit sphere, so ##r=1##.
why unit sphere rather than an arbitrary sphere?
Diagram of a spherical surface patch in 3D coordinates with z, x and y axes; area element dA labelled, with edges r dθ, r sinθ dφ, dθ, dφ, r and sinθ marked, and angles θ and φ shown.
In conventional spherical coordinates an area element ##dA## on the surface of a sphere of radius ##r## is the product of two arc lengths, ##ds_{\theta}=r~d\theta## and ##ds_{\phi}=r\sin\!\theta~d\phi## so that $$dA=ds_{\theta}\times ds_{\phi}=r^2~\sin\!\theta d\theta~d\phi.$$By definition this area subtends a solid angle $$d\Omega=\frac{dA}{r^2}=\sin\!\theta d\theta~d\phi.$$ The radius is irrelevant.
The orthonormality condition for the spherical harmonics is $$\int Y^*_{l'm'}(\theta,\phi)Y_{lm}(\theta,\phi)~d\Omega=\int_0^{2\pi}d\phi\int_0^{\pi}Y^*_{l'm'}(\theta,\phi)Y_{lm}(\theta,\phi)\sin\!\theta d\theta=\delta_{ll'}\delta_{mm'}.$$There is no ##r##.
Solid angle
