Quantum: Spherical Harmonics Not Including r^2 term?
  • Thread starter Thread starter laser1
7 replies · 3K views
laser1
N/A
N/A
In the solutions, I must integrate ##Y_1^0 Y_1^{\pm 1}##. But my concern is when it states that the differential element (I think area?) is ##d\theta d\phi##. I know that as
then ##dA=r^2 \sin \theta d\theta d\phi##. But the solution only states ##\sin \theta d\theta d\phi##. Why is this? Also, the units are not even area, so I have some problems with what this differential element is.
Is not the differential of area but the solid angle. I am not sure what you want to understand here, the spherical harmonics only are in radial coordinates and pertain only to the angular part.
Where does the ##\sin \theta d\theta d\phi## come from? I had thought it came from the fact that the jacobian in spherical coordinates is ##r^2 \sin \theta## but maybe I was wrong.
Do that and you should get zero, and you will get zero if you do the integration correctly. They are orthogonal functions, after all. What you need to integrate are ##\left(Y_1^0\right)^2## and ##Y_1^{\pm1}\,\left(Y_1^{\pm1}\right)^\ast##.
You are integrating over the surface of the unit sphere, so ##r=1##.
why unit sphere rather than an arbitrary sphere?
In conventional spherical coordinates an area element ##dA## on the surface of a sphere of radius ##r## is the product of two arc lengths, ##ds_{\theta}=r~d\theta## and ##ds_{\phi}=r\sin\!\theta~d\phi## so that $$dA=ds_{\theta}\times ds_{\phi}=r^2~\sin\!\theta d\theta~d\phi.$$By definition this area subtends a solid angle $$d\Omega=\frac{dA}{r^2}=\sin\!\theta d\theta~d\phi.$$ The radius is irrelevant.
The orthonormality condition for the spherical harmonics is $$\int Y^*_{l'm'}(\theta,\phi)Y_{lm}(\theta,\phi)~d\Omega=\int_0^{2\pi}d\phi\int_0^{\pi}Y^*_{l'm'}(\theta,\phi)Y_{lm}(\theta,\phi)\sin\!\theta d\theta=\delta_{ll'}\delta_{mm'}.$$There is no ##r##.
Reply
Solid angle
Reply
pines-demon said:
Thanks, I guess the justification is "a unit sphere by definition" then!
