How Does Max Tegmark's Multiverse Theory Influence Human Decision-Making?
bennington
I was reading and attempting to understand Max Tegmark's research on the multiverse, and I found this:
http://science.howstuffworks.com/quantum-suicide.htm
Now, while How Stuff Works is generally a good site, there are some areas that they could have been clearer on. The paragraph
A man sits down before a gun, which is pointed at his head. This is no ordinary gun; it's rigged to a machine that measures the spin of a quantum particle. Each time the trigger is pulled, the spin of the quantum particle -- or quark -- is measured. Depending on the measurement, the gun will either fire, or it won't. If the quantum particle is measured as spinning in a clockwise motion, the gun will fire. If the quark is spinning counterclockwise, the gun won't go off. There'll only be a click.
[Aren't there other aubatomic particles other than quarks?]
I always thought that the spin of a particle does not mean the particle is spinning like a top in physical space, but refers it as intrinsic angular momentum. The mathematics behind it behaves (I think) a lot like "normal" angular momentum of a top spinning but from what I have read, that is not what is meant by spin. I also have heard that it is impossible to measure its spin due to confinement.
Also, if the universe has a consistent basis on the same mathematical laws, then other variables can't be changed. Otherwise, the whole laws of mathematics would be off. In other words, if the universe has a progressive time which could be equated to a math problem being worked out, then even the smallest problems would have to obey the rules of the biggest problems. Correct?
I seem to fail to understand how this would apply to humans and their decisions, since the MWI only applies to subatomic particles. Any insight?
Aren't you expecting a bit much from the site? I mean, the details aren't the point are they?
It's true that spin of a particle isn't much like classical spin, but you can certainly measure a particle's spin on a given spatial axis, using a stern-gerlach device for example, and you'll always get either the result "spin-up" or "spin-down" on that axis.
I don't understand what you mean by "other variables", or "progressive time which could be equated to a math problem being worked out", or what this has to do with the quantum suicide thought-experiment. Can you elaborate?
No, the whole point of the MWI is to assume that all systems obey the same quantum laws as individual particles, including macroscopic systems like us (which are after all just large collections of interacting particles). See here or here for more info.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
