Undergrad Quasi-Static Processes: Does dQ = 0?
  • Thread starter Thread starter manhattan_project
    Quasi-static
In quasi-static processes, the relationship dQ = dE + dW holds, but when dW = -dE, it raises the question of whether dQ can equal zero, suggesting no heat exchange. This confusion is particularly relevant in isothermal quasi-static processes, where dQ is not zero. The reference to Reif's Fundamentals of Statistical and Thermal Physics indicates that the work done by the system is defined as dWr = -dEr, implying that dW = -dE is specific to certain conditions. However, it is argued that a system cannot remain in a particular thermodynamic state if its internal energy changes, indicating that the equation may only apply to adiabatic changes. Understanding these distinctions is crucial for accurately interpreting thermodynamic processes.
manhattan_project
We know that dQ = dE + dW for any system. However, in quasi-static processes, dW = -dE. Does this mean that dQ = 0 and no heat (Q) is absorbed or given off? If so, why is that?
Who says that this is the case for a quasi-static process? What about an isothermal quasi-static process, where dQ is not equal to zero?
I guess I am confused when dQ = 0.
In Reif's Fundamentals of Statistical and Thermal Physics, in Section 2.9 on quasi-static processes, it states that the work dW done by the system when it remains in a particular state r is defined as dWr = -dEr. I understood this as saying that dW = -dE for quasi-static processes
I don’t have a copy of that book. But, it dorsn’t sound correct to say that a system remains in a particular thermodynamic state if its internal energy changes. The equation you have written is correct only for an adiabatic change.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 21 ·
  • · Replies 23 ·
