Why do some op amps require capacitors in parallel with supply voltages?
  • Thread starter Thread starter scott_alexsk
    Amp Op amp
The INA101 operational amplifier requires two 1 microfarad capacitors in parallel with the supply voltages in its TO-100 package configuration to provide paths to ground for noise on the power supply. This decoupling is essential for maintaining stability and preventing oscillations in both analog and digital circuits. The datasheet specifies that the INA101 operates correctly within a supply voltage range of +/-5V to +/-20V, with an absolute maximum of +/-20V. Designers must consider input and output limitations as specified in the datasheet to ensure proper functionality.
  • Understanding of operational amplifier configurations
  • Familiarity with the INA101 datasheet
  • Knowledge of decoupling capacitors and their role in circuit design
  • Basic concepts of power supply voltage requirements
  • Review the INA101 datasheet for detailed specifications and application information
  • Study the role of decoupling capacitors in analog circuit design
  • Learn about operational amplifier input and output limitations
  • Explore best practices for power supply design in electronic circuits
Electronics engineers, circuit designers, and students studying operational amplifier applications will benefit from this discussion, particularly those working with the INA101 and similar devices.
scott_alexsk
For the INA101, in the configuration for the most basic circuit with the TO-100 package, two 1 mircofarad capacitors seem to be required to be placed in parallel with the supply voltages. Why is this, and is it actually necessary for an operating circuit, since the circuit example with the Dip package has no such requirement? You can see what I am talking about on pg. 6 in the linked pdf.
http://www.chem.duke.edu/~boris/datasheets/INA101.pdf"
Thanks,
-Scott
Thanks,
-Scott
They provide paths to ground for (possible) crap riding on the power supply voltages.
Look at the second sentence under APPLICATION INFORMATION.
Sorry about that.
Thanks for the quick reply.
-Scott
And in general, decoupling power supply input pins is good practice, both for analog and digital devices.
The bypass capacitors also help to keep the demons of oscillation at bay...
Hey another quick question, for the power supply voltage, how close to +/-15 volts do I need to be to have the instrument work right? Is it correct that the op amp will work w/ a +/-5 volt to a +/-20 volt supply?
Thanks,
-Scott
The datasheet states that the minimum supply voltage is +/-5V and the maximum supply voltage is +/- 20V.
Therefore, you may assume that the device will operate within its stated parameters over that range of supply voltages.
Interestingly (?) enough, the Absolute Max supply voltage is +/-20V too, which would appear to be sailing a bit close to the wind... I suppose it depends on how absolute that max is.
Keep in mind that not many opamps will let you take the inputs to the rails, and not many will be able to drive their outputs to the rails. Look in the datasheet for the specifications for how close the inputs and outputs can go to the rails, and keep that limitation in mind in your design.
10K
