Harald 1966
- 5
- 0
The discussion revolves around the center of gravity (CG) of two different speed boat designs, specifically comparing configurations with one fuel tank versus two fuel tanks. Participants explore the implications of CG on stability, theoretical considerations, and practical applications in boat design.
Participants express differing opinions on which boat design has the better CG for stability, with no consensus reached. The discussion includes multiple competing views and theoretical considerations, leaving the question unresolved.
Participants note that the discussion is theoretical and may not account for all practical factors affecting boat stability, such as environmental conditions and design choices. There are also references to the need for calculations that remain unaddressed.
This discussion may be of interest to individuals studying boat design, stability in engineering contexts, or those involved in maritime engineering.
Harald 1966 said:Yes, I mean lowest! (Best stability.)
Everything is off course theoretical.
The weight of the boat is the same in both examples.
The weight of the fuel is also the same, 2 lb. (Small RC boat)
The area of one big tank is the same as the area of the two small combined, meaning length of all tanks will be the same.
If you ballance on a thin rope, why do you lift arms up and out if best CoG is keeping arms down close to your boudy?
What do you think?
Harald 1966 said:but why do you take arms up and out to gain ballance and stability?
willem2 said:If you're walking on a rope your center of gravity will be above your feet, so you
will be unstable anyway. If you stand still you'll fall. To keep upright you have to
move your arms.
If you start falling to the right, you can stick an arm out to the right and move the
rest of your body somewhat to the left. This will move your center of gravity to the
left, so you can stop falling.
Why do you need a calculation? Is this a homework problem?Harald 1966 said:Can anyone please help me compare them by doing a simplyfied calculation?
