Why is the change of enthalpy during a phase change equal to mL?
  • Context: Undergrad
  • Thread starter Thread starter Clara Chung
The discussion revolves around the relationship between change of enthalpy and latent heat (mL) during a phase change. Participants explore the underlying thermodynamic principles, definitions, and mathematical expressions relevant to this concept, focusing on the conditions of constant temperature and pressure during the phase change.
  • One participant questions why the change of enthalpy is equal to mL during a phase change, referencing the equation H=U+PV and the conditions of constant temperature and pressure.
  • Another participant seeks clarification on the definition of L, asserting that L is the energy needed to vaporize or fuse 1 kg of substance.
  • There is a discussion about the expression for dH, with one participant stating that if temperature and pressure remain unchanged, then dH simplifies to dQ.
  • One participant suggests that dQ could also be expressed as TdS, where dS represents the change in entropy, and emphasizes that the change in pressure, dp, is zero during the phase change.
  • Another participant agrees with the assertion that L = Q/m, noting that pressure is conventionally assumed to remain constant throughout the phase change.
  • There is a mention of integrating the relationship dH = dQ to arrive at ΔH = Q, which is identified as L for 1 kg of substance.
Participants express differing views on the derivation and interpretation of the equations involved, particularly regarding the treatment of dU and the implications of constant pressure and temperature. The discussion remains unresolved with multiple competing perspectives on the definitions and relationships involved.
Limitations include the dependence on the assumption of constant temperature and pressure during the phase change, as well as the need for clarity on the definitions and relationships among the variables involved.
Clara Chung
Why is change of enthalpy equal to m L during a phase change?
H=U+PV
dH=dU+pdV+Vdp
If temperature and pressure is unchanged during a phase change,
dH=pdV, how does it lead to m L ? Thank you
Science news on Phys.org
How is L defined?
Clara Chung said:
H=U+PV
dH=dU+pdV+Vdp
Correct.
dH=pdV [...]
That's not correct. How would you write dU in terms of temperature and pressure?
kith said:
How is L defined?
Correct.
dH= dU+pdV+Vdp
dH= dQ-pdV+pdV+Vdp
dH=dQ+Vdp
Is the pressure unchange?
L is defined as the energy need to vapourize/fuse 1kg of substance.
Clara Chung said:
dH=dQ+Vdp
Yes, that's better. (dQ could also be written as dQ=TdS where dS is the change in entropy)
In your first post, you stated that temperature and pressure should remain unchanged. This means that the change in pressure, dp, is equal to zero.
Therefore, dH = dQ.
Yes: L = Q/m (as a convention, pressure is assumed to stay constant throughout the phase change)
Therefore, dH = dQ.
Thanks for the explanation
dH=dQ
so if I integrate it, I can get
ΔH=Q which is L for 1kg of substance
  • · Replies 31 ·
  • · Replies 16 ·
