Question about extreemly large black holes.
  • Thread starter Thread starter mrspeedybob
    Black holes Holes
As black holes increase in mass, their density decreases, potentially aligning with the ambient mass density of the universe. This raises the question of whether we could consider ourselves within such a black hole. There may be a theoretical upper limit to black hole size where gravitational forces are balanced by cosmological expansion. The average density concept is misleading when applied to event horizons, as spacetime geometry becomes non-Euclidean under extreme mass density. The Tolman-Oppenheimer-Volkoff limit suggests that neutron stars must exceed about 3 solar masses to become black holes, emphasizing the complexity of black hole physics.
mrspeedybob
If we define the density of a black hole to be it's mass divided by the volume within it's event horizon then as the mass of a black hole increases it's density decreases. At some point the density would be equal to the ambient mass density of the universe. Can we correctly consider ourselves to be in such a black hole? Or is there a balance point where gravitation is balanced by cosmological expansion that represents a theoretical upper limit to the size of a black hole?
Astronomy news on Phys.org
Density is not a useful way of looking at event horizons. The mass density inside the event horizon can be naively approximated this way using the Schwarzschild metric, but, you will get a nonsensical answer. Spacetime geometry is obviously non-euclidean in the presence of extreme mass density. Otherwise, any neutron star in excess of about .25 solar masses should be a black hole. If you apply the Tolman [TOV] limit to account for spacetime curvature it increases to around 3 solar masses.
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
