Question about how collisions deal with force.
  • Thread starter Thread starter zeromodz
    Collisions Force
In collisions, momentum is crucial for determining post-collision velocities, but understanding the forces involved is complex. The force experienced by an object, like a wall, during a collision depends on the change in momentum, which is influenced by the mass and velocity of the colliding object. Since acceleration is often not constant or linear during a collision, calculating the exact force can be challenging. However, the relationship between momentum and force remains central to analyzing collisions. Ultimately, momentum provides a comprehensive framework for understanding collision dynamics.
zeromodz
Well, I know we use momentum to determine the velocities after a collision, but what about forces. Say a 1000kg car going at 20 m/s hits a wall with a mass of 500kg. What determines how much force the wall will experience by the car if there is no acceleration in the horizontal direction? Only velocity and mass.
There is always a force if there is a change in momentum. The problem with determining the forces in collisions is that the acceleration is not constant or even linear in most cases .The cool thing is that you can find just about everything you want to know about a collision using momentum
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
