Question about Lagrangian Mechanics.
The discussion focuses on solving a particle motion problem using Lagrangian mechanics, specifically under the constraint that the particle moves along a parabolic path defined by y = (x(t))^2. The participant initially struggles with formulating the Lagrangian correctly, particularly in incorporating the kinetic energy terms and handling the Euler-Lagrange equations. It is emphasized that the constraint reduces the degrees of freedom, allowing for a simpler one-dimensional equation of motion. Correctly applying partial derivatives and understanding the relationship between the coordinates are crucial for deriving the accurate equations of motion. The conversation highlights the importance of proper setup and mathematical rigor in Lagrangian mechanics problems.
Timothy S
This is not a homework equation at all, however I have devised my own example problem in order to convey my misunderstanding. (My question is at the end of the problem)
Question that I had come up with:
A particle's motion is described in the x direction by the equation x = x(t). The particle's motion in the y direction is given by the constraint equation, y = (x(t))2. This particle's motion is on Earth and is acted on by the force, -mg. Find the equation of motion.
Attempted solution:
because of the constraint equation for y, I did not write the lagrangian in terms of either x-dx/dt-y, but with just the coordinates x-dx/dt. Because of this logic, my Lagrangian was:
http://www.sciweavers.org/upload/Tex2Img_1428780064/render.png
Plugging into the Euler-Lagrange, I obtained the Equation of Motion to be:
http://www.sciweavers.org/upload/Tex2Img_1428780484/render.png
This is undoubtedly wrong as the equation of motion is one dimensional while the actual motion of the particle is in two dimensions. What did I do wrong? And more importantly, how would you guys solve this type of problem?
When you have constraints there are many methods of taking care of them. I think that in this case, the simplest is to first write the Lagrangian in terms of x and y, then substitute your constraint equation y(x).
The resulting ODE is for x(t) of your particle. If you want a position function of your particle i.e. r(t) then use your constraints again to generate it. I.e. you know x(t), then y(t) = y( x(t) ) then r(t)= x(t) i + y (x(t)) j
makes sense?
What the constraint equation does is it reduces the number of degrees of freedom. While the particle can move in two dimensions the changes in one co-ordinate can be described by the changes in the other co-ordinate. This means that you can completely describe the particle's motion by describing it's motion only in terms of one of these coordinates. This makes solving the problem easier as now you have only one equation to solve, instead of two.
From your set up you have a horizontal and vertical coordinates x and y and gravity that acts in the negative y-direction. This is all well and good. You have added the constraint that the particle must move on some parabola y=x^2. This is an arbitrary addition to the problem, maybe the particle is stuck on the surface of some parabola shaped bowl and is unable to leave it's surface. That is the sort of situation where constraint equations come into use. Since you know the shape of the bowl and that the particle must be on the bowl's surface, if you know it's horizontal position you know it's vertical position. The exact shape and size of the bowl would be determined by the initial conditions you prescribe.You appear to have made a small mistake in setting up your Lagrangian as well.
The kinetic energies in this case should also be ##\frac{m}{2}(\dot{x}^2 + \dot{y}^2)## So your second term should be positive but other than that your Lagrangian is correct.
When computing your partial derivatives for the Euler Lagrange equations you have to remember a few maths things. This is especially important when you have an interesting lagrangian which has a term with both ##x## and ##\dot{x}## in it. Remember that all the other variables are treated as constants when taking a partial derivative. This means that this middle term should appear in both your partial with respect to ##x## and your partial with respect to ##\dot{x}##. You should have ##\frac{d}{dt}(m\dot{x}+4m\dot{x}x^2) - 4\dot{x}^2 x-2mgx = 0##. Also, when computing the total time derivative you have to use both the product rule and the chain rule as both ##x## and ##\dot{x}## are functions of t so your final expression is a bit more complicated than you might expect.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
