Question About Long Division of Polynomials
In summary, in this conversation, the topic of adding 0x^n to a polynomial dividend was discussed. It was explained that this is done to help perform the subtraction in polynomial long division and does not affect the final answer. This is similar to the use of zeros in regular long division to indicate place values. It was also noted that this step may be more for avoiding errors, especially for students learning the process.
kyphysics
676
436
Dividend: 4x^3 - 6x - 11
Divisor: 2x - 4
In this problem above, the dividend lacks a variable to the second power, so we have to add a 0x^2 to make it:
4x^3 + 0x^2 - 6x - 11
Question:
Why do we add 0x^n? (n = missing powers)
In regular long division, we do no such thing. Why do we have to add these extra variables into the dividend in polynomial long division?
TVM!
Mathematics news on Phys.org
I don't know. I don't.
Edit: It is probably to help perform the subtraction. If you don't add it you subtract from zero anyway. So writing it might help to avoid mistakes.
Like the post above says, I think it's only to avoid error ( especially while learning it as a student). Wouldn't actually affect your answer in any way.
You "add" 0, which means you do not change anything. In regular long division, the 0 would be there already to indicate the right places, in polynomials, you don't need to write +0x2 explicitely because every term has its meaning independent of where it is located.
Divisor: 2x - 4
Question:
TVM!
Sure we do. That's what zero is for.
If you want to do long division of 3065 by 42, the place value system we use to write decimal numerals is as follows:
3065 = 3 × 103 + 0 × 102 + 6 × 101 + 5 × 100
or
3065 = 3x3 + 0x2 + 6x + 5, where it is understood x = 10.
It's a similar situation when certain terms are missing from a polynomial dividend.
Likes jenniferAOI
or
Got it! Thanks.
or
wow. Did not see that either. thank you
1.
What is long division of polynomials?
Long division of polynomials is a method used to divide one polynomial by another polynomial to find the quotient and remainder. It is similar to long division of whole numbers, but instead uses variables and powers of variables.
2.
Why is long division of polynomials important?
Long division of polynomials is important in simplifying and solving polynomial equations. It also helps in finding the roots of polynomial equations, which are the values of the variable that make the equation equal to zero.
3.
What is the process for long division of polynomials?
The process for long division of polynomials involves dividing the highest degree term of the dividend by the highest degree term of the divisor to get the first term of the quotient. This term is then multiplied by the divisor and subtracted from the dividend. The resulting polynomial is then used as the new dividend, and the process is repeated until there is no remainder or the degree of the remainder is smaller than the degree of the divisor.
4.
Can long division of polynomials be done with different types of polynomials?
Yes, long division of polynomials can be done with different types of polynomials, including monomials, binomials, and trinomials. The process is the same regardless of the degree of the polynomials.
5.
Are there any shortcuts for long division of polynomials?
Yes, there are some shortcuts for long division of polynomials, such as factoring the polynomial first to simplify the division process. Also, if the divisor is a binomial of the form x+a, where a is a constant, then the remainder can be found by substituting -a for x in the dividend.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
