Question about measuring the internal resistance of power supplies
The internal resistance of a power supply is crucial for understanding its load regulation and performance. A low resistance load is used during measurement to maximize voltage drop, allowing for accurate determination of internal resistance by observing voltage changes under varying loads. This concept applies to all electrical sources, including non-battery power supplies, which also possess internal resistance that can affect output stability. The measurement technique involves calculating the difference between open circuit voltage and test voltage while accounting for the current supplied.
  • Understanding of Thévenin's theorem
  • Basic knowledge of voltage and current measurements
  • Familiarity with electrical circuit analysis
  • Knowledge of power supply design principles
  • Research methods for measuring internal resistance of batteries and power supplies
  • Learn about the implications of internal resistance on power supply performance
  • Explore the design characteristics of constant voltage and constant current power supplies
  • Investigate the relationship between load resistance and voltage regulation in power supplies
Electrical engineers, technicians, and anyone involved in power supply design or analysis will benefit from this discussion, particularly those focused on optimizing performance and understanding internal resistance effects.
yubson
In measuring the internal resistance of a power supply, why is a resistor with low resistance used?
Who says that it is? You need to be more specific in your question. I think you have misunderstood something.
I don't know exactly how you are using the low resistance here, but speaking generally,
the internal resistance of a power supply is a low value to give good load regulation, so to measure it by measuring the change in voltage at varying loads, you will see the biggest voltage drop when you draw the maximum current. That means using the lowest load resistance that will not overload the supply.
Are you talking about an ammeter? Could you be more clear?
no
he's referring to the actual internal resistance
We say a battery has an internal resistance, the value of which is determined by the chemical composition etc
it is what limits the short circuit current value
from Wiki
  1. Internal resistance
    th?id=Ab781aa03e80935df37f9252f5181a278&w=110&h=110&c=7&rs=1&qlt=80&pcl=f9f9f9&cdv=1&pid=16.jpg
    A practical electrical power source which is a linear electric circuit may, according to Thévenin's theorem, be represented as an ideal voltage source in series with an impedance. This impedance is termed the internal resistance of the source. When the power source delivers current, the measured voltage output is lower than the no-load voltage; the difference is the voltage drop caused by the internal resistance. The concept of internal resistance applies to all kinds of electrical sources and is useful for analyzing many types of electrical circuits.
how to measure internal resistance of a battery ...
I never really hear anyone talking about the internal resistance of a non-battery PSU ... I would assume it would also have one
ahhhh here's some info...
https://forum.allaboutcircuits.com/threads/output-resistance-of-dc-supplies.54138/
Dave
  • th?id=Ab781aa03e80935df37f9252f5181a278&w=110&h=110&c=7&rs=1&qlt=80&pcl=f9f9f9&cdv=1&pid=16.jpg
I think you are just asking why they use a low resistance load on the power supply. The reason is that the voltage drop with a high current is greater and easy to measure. If you know the Voltage lost (open circuit volts minus test volts) and the current being supplied, it will tell you the value of the Series Resistance that's in the box.
It's only an approximate answer because many power supplies will not have an unvarying internal resistance.
Some power supplies have virtually no internal impedance within their design operating range. The voltage stays the same no matter the output current.
For the regulation to be stable, a PSU would need a finite internal resistance, I think but that could be very low.
yes, that will be the case for specifically designed constant voltage or constant current supplies
but for general supplies, internal ( output ) resistance is a factor and is discussed in the link I providedDave
  • · Replies 30 ·
  • · Replies 19 ·
