Question about Momentum and torque
The discussion revolves around a mechanics problem involving momentum and torque, specifically focusing on a system of two sticks forming an hourglass shape with a ball on top. The original poster seeks to determine the force exerted by a rope that holds the structure together, while grappling with the complexities of forces that are not perpendicular to the moving arm.
  • Mixed
  • Participants discuss the need to analyze forces and torques, with suggestions to draw Free Body Diagrams (FBD) to clarify the situation. There is a focus on the symmetry of the system and the components of forces that are not aligned with the axes.
The conversation is ongoing, with participants providing guidance on using FBDs and considering moments about the center of the sticks. However, there remains confusion regarding the angles of the forces and how to effectively combine them in the analysis.
Participants note the challenge of dealing with forces that are not perpendicular to the moving arm, specifically mentioning angles that complicate the calculations. There is also reference to external resources that may assist in understanding common errors in mechanics.
kozmosnak
Thread moved from the technical forums to the schoolwork forums
The force on the rope
Momentum and Troqhe balance equations
TL;DR Summary: I have this Question, and I have no idea, how am I supposed to set the Forces to create a balance since they are not perpendicular to the moving arm.
I have this question I have spend a lot of time on. It basically shows two sticks which are connected in the middle to create a Hourglass shape and on the top side there is a ball which has the mass of 1G (it is known just not a number)
Each of the sticks has their own mass which is G2. Right at the top there is a rope that holds two ends of the stick together so it won’t collapse. All the measurements that was given is on the attachment file.
What I need to figure out is how much Force the rope has. Even though one can see the answers right below it doesn’t make it understandable. Thank you everyone for helping <3
Fixing your diagram:
  • Love
So take the components which are perpendicular to the arm.
You can assume there is no friction and that the system is symmetric.
Draw the Free Body Diagram for one stick and post it.
I have drawn it but cant get any further
Use the FBD of the ball to determine ##F_k##.
Use the symmetry to determine ##A_y##.
So the force Fk is Fg1 which is to see G
G1/sin(30)*2=Fk
@kozmosnak, if you take moments (torques) about the centre (where the sticks cross) you don't need ##A_x## or ##A_y##.
Yes but the problem I’m facing is that the forces are not perpendicular to the moving arm. They have angles that’s why I am confused. For example the rope force is horizontal but the axis is there with a 60 degree angle how can I add them up
Yes but the problem I’m facing is that the forces are not perpendicular to the moving arm. They have angles that’s why I am confused. For example the rope force is horizontal but the axis is there with a 60 degree angle how can I add them hp
Look at the diagram carefully:
If you are unfamiliar with this try watching the video:
G1/sin(30)*2=Fk
Yes.
See if https://www.physicsforums.com/insights/frequently-made-errors-mechanics-moments/ helps.
  • · Replies 25 ·
  • · Replies 25 ·
