Question between friends - How long to travel 1 light year?
The discussion revolves around calculating the time it would take for a human to travel one light year, using the distance of approximately 9.46 trillion meters and a maximum speed of 11,068.3 meters per second. Initial calculations yielded an estimate of around 27,084 years, but further discussions highlighted the importance of significant figures and accurate conversions from seconds to years. The final refined answer suggested a travel time of approximately 27,103 years, emphasizing the need for precision in calculations. Participants also noted discrepancies in answers due to rounding and the accuracy of their initial assumptions. Overall, the conversation underscores the complexities of astronomical calculations and the significance of using precise values.
MartinButler88
Question between friends! -- How long to travel 1 light year?
Me and a few friends were trying to work out how long it would take a human to travel one light year. We were using the these variables.
Distance = 9.4605284 × 1015 m
Fastest speed for manned space travel = 39,846 kph or 11068.3 m/s
I was using the equation of speed = distance/time, rearranged to solve for time. T = D/S
My attempt brought me back the answer of 27084 years.
I was doing this.
9.46 x 1015 =854716299241 seconds or 27084 years
11068 m/s
If there is any other variables I have left out, could you please write back. Me and my friends have used different speeds, different units and our heads are now fried!
Thank you
about 27,000 years looks good!
Did your friends get the same answer?If you are rounding the numbers,then you would get different answers.Your conversion of seconds to years is wrong!
Your absolutely correct for the seconds to years conversion! Last time i'll ever use Google as a calculator!
New answer is 27102.876054065195 or 27103 years.
Actually, Google's answer is fine. The length of the year is approximately 365.24 days.
In any case, since you rounded off the distance to only three sig figs in the beginning, your final answer is only good to two or three sig figs as well. So answers like 27084 years or 27103 years are not really correct because the last two digits aren't significant.
There are 365.25*24*3600 = 3.15576 x 107 seconds in a year.
The speed of light is 2.99792458x108 m/sec
So there are 2.99792458x108 x 3.15576 x 107 = 9.4607 x 1015 metres or 9.4607 x 1012 km in a light year.
If the spaceship can travel 11.068 km/sec. then in 3.15576 x 107 seconds it can travel 3.8659 x 108 km.
So it would take: 9.4607 x 1012 /3.8659 x 108 = 2.4472 x 104 = 24,472 years to make the journey.
AM
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
