Question of units of B, H in Gaussian system
Master J
In "Classical Theory of Fields", by Landau & Lifgarbagez, they give, for example, the force on a charged particle by a magnetic field as:
F = \frac{ev}{c} x H
where H is the magnetic field intensity. Now, normally written in SI units, this expression would use B and no factor of 1/c.
So how are B and H related here? I'm a bit confused over the units in use (which I think may be Gaussian)!
In Gaussian units, B and H have the same units (gauss), and are identical in free space.
For sonme historical reason (and a bit of confusion) H was originally given the unit 'Oersted' with 1 Oersted = 1 Gauss.
For some historical reason (and a bit of confusion) H was originally given the unit 'Oersted' with 1 Oersted = 1 Gauss.
So in Gaussian units, B and H are entirely interchangeable?
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
