Question of units of B, H in Gaussian system
Master J
In "Classical Theory of Fields", by Landau & Lifgarbagez, they give, for example, the force on a charged particle by a magnetic field as:
F = \frac{ev}{c} x H
where H is the magnetic field intensity. Now, normally written in SI units, this expression would use B and no factor of 1/c.
So how are B and H related here? I'm a bit confused over the units in use (which I think may be Gaussian)!
In Gaussian units, B and H have the same units (gauss), and are identical in free space.
For sonme historical reason (and a bit of confusion) H was originally given the unit 'Oersted' with 1 Oersted = 1 Gauss.
For some historical reason (and a bit of confusion) H was originally given the unit 'Oersted' with 1 Oersted = 1 Gauss.
So in Gaussian units, B and H are entirely interchangeable?
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
