Question on the Lorentz force: Why is the force not F=q(v×B) = F=qv×qB
The discussion revolves around the Lorentz force equation, specifically questioning the representation of the force acting on a moving charge in a magnetic field. Participants explore the mathematical formulation and properties of vector cross products and scalar multiplication.
  • Some participants question why the force is expressed as F=q(v×B) rather than F=qv×qB, suggesting that q should be multiplied to both components of the equation.
  • Others clarify that the multiplication by a scalar is not distributive over the vector product, indicating that the correct interpretation involves performing the cross product first before applying the scalar multiplication.
  • A participant provides a graphical perspective, concluding that scalar multiplication of both vectors prior to the cross product is incorrect.
  • Further elaboration on the properties of scalar multiplication and vector products is presented, emphasizing the distinction between distributive properties in different contexts.
Participants express differing views on the application of scalar multiplication in the context of vector cross products. There is no consensus reached regarding the initial question about the Lorentz force equation.
Participants reference mathematical properties and operations that may depend on their prior educational experiences, which could influence their understanding of the topic.
unplebeian
TL;DR
Why is the charge not multiplied to the cross product
Background:
cb96d860cadff3d60e8ffb90b067b7f2b453c8e1
is the equation of Lorentz force for the force acting on a moving charge in electric and magnetic field.
For the magnetic field only it is : F=qv×B.
Question:
For magnetic field only why is the force not F=q(v×B) = F=qv×qB
unplebeian said:
TL;DR Summary: Why is the charge not multiplied to the cross product
Background:
Question:
You are only multiplying by q once, so
##q \textbf{v} \times \textbf{B}##
##= q ( \textbf{v} \times \textbf{B} )##
## = (q \textbf{v} ) \times \textbf{B}##
##= \textbf{v} \times (q \textbf{B})##
-Dan
Hi, Dan,
I'm sorry I didn't get it. That is a scalar multiplication so q should be multiplied to both. Generally a(bxc)= abxac.
Why are we multiplying only once?
This is wrong.
$$a(\mathbf b \times \mathbf c) = a\mathbf b \times \mathbf c = \mathbf b \times a\mathbf c$$You must be thinking of:
$$a(\mathbf b + \mathbf c) = a\mathbf b + a\mathbf c$$
unplebeian said:
Hi, Dan,
Is ##2(3 \times 4 ) = (2 \cdot 3) \times (2 \cdot 4)##?
-Dan
PeroK said:
This is wrong.
Easy to make mistake if in elementary school you learned the order of operations as "Dot (##\cdot## and ##\colon##) before stroke (##+## and ##-##)", because that's how the basic operators are written in your country.
Thank you, Dan. I thought about it graphically and it's evident that the scalar multiplication to both vectors prior to the cross product operation is incorrect. Rather take the cross product and then perform the scalar multiplication or simply any one vector like you suggested.
Thank you.
## \vec F = q ( \vec E + \vec v \times \vec B ) ##
## q ( \vec E + \vec v \times \vec B ) = q \vec E + q ( \vec v \times \vec B ) ## – the distributive property of scalar multiplication over the vector addition
## q ( \vec v \times \vec B ) = ( q \vec v ) \times \vec B = \vec v \times ( q \vec B ) ## - the multiplication by a scalar property of the vector product (the multiplication by a scalar is not distributive over the vector product)
:welcome:
  • · Replies 25 ·
