Why Must the Wavelength Be Smaller Than the Interplanar Spacing in Bragg's Law?
  • Context: Undergrad
  • Thread starter Thread starter Roula
    Bragg Law
The discussion revolves around the conditions necessary for Bragg's Law to apply in the context of Bragg Diffraction, specifically focusing on the relationship between the wavelength of radiation and the interplanar spacing in materials. Participants explore the physical reasoning behind the requirement that the wavelength must be smaller than the interplanar spacing.
  • One participant, Roula, questions the physical reason behind the requirement that the wavelength (λ) must be smaller than the interplanar spacing (d) for Bragg's Law to be applicable.
  • Another participant suggests that waves do not scatter unless the wavelength is on the order of or smaller than the feature being investigated, using the analogy of radio waves and wall thickness.
  • Roula seeks a proof related to this requirement and inquires whether it connects to the Huygens–Fresnel principle.
  • A different participant argues that the wavelength does not necessarily have to be smaller than d for Bragg's Law to be valid, stating that if λ is less than d, the only solution to the equation is an unscattered wave.
  • Another participant references Newton's book on scattering theory for further insights.
Participants express differing views on the necessity of the wavelength being smaller than the interplanar spacing for Bragg's Law to hold. Some argue that it is a prerequisite for scattering, while others contend that the law can still be valid without this condition.
There are unresolved assumptions regarding the physical interpretation of scattering and the implications of the mathematical conditions of Bragg's Law. The discussion reflects varying interpretations of the relationship between wavelength and interplanar spacing.
Roula
Hello everyone
I would like to ask you something related to the investigation of materials depending on Bragg Diffraction (Bragg Law).
It is a prerequisite, that the wavelength of the used radiation must be smaller than the dimension of the sample, by the meaning λ ≤ d , where λ is the wavelength and d is the interplaner spacing .
I know from Bragg law nλ=2dsinθ, that wavelength must be smaller than d in order to apply this law. But i can not understand physically the reason of that.
What is the physical reason that λ ≤ d ?
I am thankful for you all.
Roula
simply, waves do not scatter unless the wavelength of incident wave is on the order or smaller than the feature you want to investigate.
if that were the case, you would not be able to listen to the radio in your house because the radio waves would be scattered by your wall thickness...
Dear Dr. Transport.
i am thankful for your response.
You are right that the wavelength must be smaller than the dimension to get scattered. And that was my question.
Could you please prove it for me ?
does the proof relate to Huygens–Fresnel principle ?
thanks again.
Roula
No answer :(
The wavelength don't has to be smaller than d for Bragg's law to be valid. It's just so that for λ<d the equation has the only solution n=0 and θ=0, i.e. the only possible solution is an unscattered wave.
Check Newton's book, scattering theory of particles and waves.
11K
  • · Replies 18 ·
