Question: Solving for Accelerations in an Atwood Machine System
The discussion revolves around solving for the accelerations in an Atwood machine system with three masses. The user initially struggles with the equations of motion, particularly regarding the accelerations of m2 and m3, and whether they should be considered the same. Participants emphasize that the acceleration of m2 should be expressed as a'-a, while m3's acceleration is -(a'+a), highlighting the need to correctly assign directions to the forces. Ultimately, the user clarifies their misunderstanding about the relationship between the accelerations and acknowledges the guidance received. The conversation concludes with the user expressing gratitude for the clarification.
Asterast
Summary:: I have solved the question but I'm getting answers wrong, some reaction equations seems to have trouble.
Question: Let m1 = 1 kg, m2 = 2 kg and m3 = 3 kg in figure. Find the accelerations of m1, m2 and m3. The string from the upper pulley to m1 is 20 cm when the system is released from rest. How long will it take before m1 strikes the pulley?
here's what I did:
Assuming acceleration of m1 be a
Assuming acceleration of m2 and m3 be a'
Tension in string between mSUB]2[/SUB] and m3 be T
so tension in upper string connected to m1 is 2T
So equations I made for the bodies:
equation for m1
2T-m1g = m1a
2T-g=a ...
equation 1
equation for m2
T-m2g = m2(a'-a)
Since m2 will be going up because of weight of m3 and system of mm2 and m3 will be going downwards.
T-2g=2(a-a') ...
equation 2
equation for m3
m3g-T = m3(a'+a)
since m3 will be going down simultaneously with m2 and m3
3g-T=3(a'+a) ...
equation 3
_________
Eliminating T from equation 1 and 2
3g = -3a+4a' ...
equation 4
_________
Eliminating T from equation 2 and 3
g = 5a+a' ...
equation 5
Solving equation 4 and 5 I get a' = 18g/23
Which is wrong.. please help. :3
Solved ?
Do you really think they undergo the same acceleration ?
Your conclusion must then be: lower pulley does not move ?:)
BvU said:
Solved ?
I assigned a' for the lower string system since motion of the rate of motion of m2 will be equal to m3
their final accelerations will be a'-a and a'+a for m2 and m3 respectively.
How come? lower string has tension T and T on each side so upper string will have 2T.
Also check the equations of m2 and m3, their final accelerations are a-a' and a+a'
Sounds much better than
My bad: it is massless.
Back to my drawing board o:)
Likes Asterast
And a' is different from a ? Still ambiguous
With respect to what ?
Shouldn't it be different because m2 and m3 will be moving wrt to each other because m3>m2 with acceleration a'
The system of m3 and m2 will be moving wrt m1 with acceleration a.
And their final accelerations are equated in eq1,eq2 and eq3
Asterast said:
equation for m1
2T-m1g = m1a
2T-g=a ...
equation for m2
T-m2g = m2(a'-a)*****
T-2g=2(a-a') ...*****
The equations with stars contradict to each other,
The first one is correct. The right side of the upper string goes downward, m2 goes up with acceleration a' with respect to the pulley, so its upward acceleration is a'-a.
Check also the equation for m3.
Likes Asterast
I'm sorry must have been typing mistake. Let me fix it and check the solution I've solved on paper real quick.
Hello
So the first starred equation was a typo for me. Actually I didn't know that acceleration for m2 should be a'-a, I have been trying to solve the problem by taking the acceleration a-a'; because m2 will be going down even though it is moving upwards hence I took a-a' can you please explain me why it shouldn't be a-a'
Asterast said:
Hello
Ser picture
It is sure that m1 accelerates upward, with a. The moving pulley accelerates downward with a. m3 accelerates downward with a' with respect to the moving pulley , as it is heavier than m2, and . m2 accelerates upward with a' with respect to the moving pulley. Taking upward the positive direction relative to the ground, acceleration of m2 is a'-a , and that of m3 is -(a'+a).
You can not know beforehand if m2 moves up or down.
Likes Asterast and BvU
ehild said:
Ser picture
Isn't m2 actually going downwards overall, even though it's moving upwards wrt m3.
So direction of acceleration of m2 should be downwards??
Asterast said:
Isn't m2 actually going downwards overall, even though it's moving upwards wrt m3.'
You can not know. and it does not matter. The acceleration of m2 with respect to the ground is a'-a., it goes upward if a'>a and goes downward if a'<a. In this case you can say that m2 accelerates downward with a-a'. You can not decide with logic alone. Solve for a and a' and you will see.
You have to fit the sign of the forces to the direction of acceleration.
Likes Asterast
Thank you so much I got it. :smile:
