Question that has me stumped. Need an answer to make an A
  • Thread starter Thread starter tdcman92
The discussion revolves around a physics problem involving a skier descending a hill inclined at 10.5 degrees, with a friction coefficient of 0.075. Participants emphasize the importance of applying the conservation of energy principle and correctly accounting for forces, particularly friction, to determine how far the skier travels on a horizontal surface after descending. Key insights include that mass cancels out in the equations, allowing for the calculation of distance without needing the skier's mass. The final velocity at the bottom of the hill is calculated to be 26.72 m/s.
  • Understanding of Newton's Second Law of Motion
  • Knowledge of conservation of energy principles
  • Familiarity with frictional forces and coefficients
  • Basic trigonometry for calculating height and distances
  • Study the application of conservation of energy in mechanics
  • Learn how to derive equations of motion for inclined planes
  • Explore the relationship between frictional force and normal force
  • Practice solving problems involving kinematics without time variables
High school students studying physics, particularly those preparing for exams involving mechanics and energy concepts, as well as educators looking for problem-solving strategies in physics education.
tdcman92
this straight from a textbook.
A skier starts from rest at the top of a hill that is inclined at 10.5degrees with the horizontal. The hillside is 200.0 m long, and the coefficient of friction between the snow and the skies is 0.075. At the bottom of the hill, the snow is level and the coefficient of friction is unchanged. How far does the skier move along the horizontal portion of thesnow before coming to rest?
i tried different thing but i can't enderstand how the problem can be solved without the mass of the skier.
I think you can find a and v of skier at the end of a hill without m. You should rewrite 2nd N's law eq. and you will see that m will be omitted automatically.
I think you need mass to calculate both final speed and how far this will get the skier - trick is, if you combine both things, m should cancel out. Could be it cancels out even earlier, just start assuming mass m and see where it gets you.
methods
This question had you stumped? its a very simple one for a undergrad student...like 2+2=4...
in fact we used to do these in 10th grade :P...
Anyway,
Just Assume Mass as 'm'...you'll see why you don't need to worry about it :)
Try Applying conservation of energy ;)
involve Change in PE n work due to friction
Remember W due to friction is frictional force*dist...
Come on..its not hard at all :)
Anyway,
im a senior in high school.
and my teacher is a ratard
can i do this
using trig to find that the skier is 36.44m high and 196.65m away from the base of the hill?
work=force x distande
Force=0.075 x weight
36.44W=0.075W x d
36.44W/0.075W = d
d= 485.866
485.866m - 196.65m = 289.21m
does that make sense at all?
tdcman92 said:
can i do this
36.44W=0.075W x d
36.44W/0.075W = d
d= 485.866
No, particularly the bold part. It looks like you are calling the coefficient of friction and the position work, and this is just plain nonsense (ie: the units do not match at all).
i didnt think it sounded right. but i was trying.
i redid it and i figured that the vf is 26.72m/s at the bottom of the hill
now I am on the horizontal part of the equation.
the skier starts from 26.72m/s and the coefficient of friction is 0.075
i still need help i feel so dumb
You do always have this:
<br /> \sum_i \mathbf{F}_i=m\mathbf{a}<br />
So can you relate a velocity to an acceleration without time? Then it should just be a matter of adding (or subtracting) the correct forces to equal mass times that relation.
but i don't have the mass.
You don't need it:
<br /> F_{friction}=\mu N=\mu mg<br />
where \mu is the coefficient of friction. Since you have a mass on both sides of the equation, it does drop out.
jdwood983 said:
You don't need it:
is N the net force
how do i find it?
i can't understand it at all?
tdcman92 said:
is N the net force
how do i find it?
N is the normal force, it is given by N=mg.
wait
i think i got but
how do i relate velocity to accelration without time?
tdcman92 said:
wait
i think i got but
Sorry for the late response, I had to take care of my fussy son then went off to bed last night.
Finding the acceleration without time is one of your kinematics equations:
<br /> v_f^2=v_0^2+2a\Delta x<br />
So if you solve this for acceleration,
<br /> a=\frac{1}{2\Delta x}\left(v_f^2-v_0^2\right)<br />
But you know that the final velocity is zero (this is when the skier stops), so you should end up with a negative acceleration (that is a deceleration, he's slowing down).
Well...err..i wouldn't say "N=Mg"...
"my teacher is a retard." i thought teachers in the US were pretty good...8|
anyway...
its like..one advice...always feed in numbers in the end only...i often find that people start substituting values from beginning...that can mess things up..
write a simple equation in terms of variables first...
Here...
Law of conservation of energy
Choosing base of slope as reference level...
Initial Potential Energy of skier + Work done by friction as man moves down slope
=Work done by friction as man moves on level ground
Take initial height as h, length of slope traversed as l, distance covered on level ground as s, angle of slope as @
Now frame the equations and show them to me :)
Btw remember...
N on the slope will be Mg cos@ (please try to derive this)
while on level surface = Mg
oh yeah..use trigo to find h...u know l
Do tell me if you get it =)
Replying a day before my Maths I Test II (25% wtg) >.< ..spent the whole day with Thomas' Calculus..so sorry if i made a mistake due to Math Overload :P..
anyway...
Here...
Btw remember...
Since he had found the velocity of the skier after going down the hill, at this point, we can say N=mg because the skier is on horizontal ground and there \cos[\theta]=1.
Yes...But there is no need to bring velocity into the picture...
tdcman92..dude..just try my method once..you'll get the answer...
No gossip about teachers/instructors here please...
Masses will be cancel out if you right the right equation,
Consider it as an inclined plane problem, where skier is an object and mountain is the inclined plane.Angle is also provided to you so you can express the force that puts the skier to motion by using trigonometric values(Sin,Cos etc)...
