Chriz3223
- 2
- 1
- TL;DR
- Robot project building, and need help for calculation.
Hi Physics! And again, thanks for the membership!
I’m about to build a robot just with some old parts I have. The main thing is the motors. I have 2 DC Motors
Specs below. (It’s a MFA975D Series with gear ratio 49:1)
Operation range(Voltage): 12V
No load = 147RPM
Nm = 1,8
Stall Torque = 4290 g*cm
Approx weight 40kg
Gear/wheel diameter 15cm
The tracks of the robot will be caterpillar from old tires, driven by chains.
The main things I need help to, is how is it possible to calculate the speed the robot might be traveling at + acceleration fra zero to top speed?
It's only horizontal no degrees inclined for the machine and surface will only be asphalt. (Friction rubber vs asphalt).
Br Chris
No load = 147RPM
Nm = 1,8
Approx weight 40kg
Br Chris
