B Questions about the relativistic kinetic energy expressions
Ricardo
<Moderator's note: Moved from New Member Introduction.>
I am asking assistance in addressing several questions I have with the relativistic kinetic energy expressions given as {I am sorry for the format of the notations. It was inadvertently distorted.}
KE=mc2 [1/sqrt(1-(v2/c2)) -1] (1)
and its equivalent presented in the form of a series
KE= mc2 +m (v2/2) + (3/8) m (v4/c2) +(5/16)m(v6/c4) (2)
The following inconsistencies are observed
#1
Because the Eq. 2 does not lead to infinity, even with v approaching c, the question arises about the validity of the inference from Eq. 1 that [1] “This expression approaches infinity as the velocity v approaches the velocity of light c. The velocity must therefore always remain less than c, however great may be the energies used to produce the acceleration.”
Please explain the contradiction.
#2
Einstein states [1] that “In accordance with the theory of relativity the kinetic energy of a material point of mass m is no longer given by the well-known expression m(v2/2) but by the expression (1).” Further, by explaining Eq.2, Einstein [1] notes that “The first term mc2 does not contains the velocity, and requires no consideration if we are only dealing with the question as to how the energy of a point-mass depends on the velocity.” To my mind, this statement essentially nullifies any use of the Eq. 1 for the calculation of the kinetic energy of the point mass because both v and c have to be used in this expression to carry out the calculation.
REFERENCES:
1. Einstein, A. “Relativity. The special and General Theory.” Barnes & Noble, 2004.
I am a mechanical engineer who is looking to advance himself in the relativist mechanics.
Almost, the series continues with an infinite number of terms, but for velocities that are sufficiently smaller than c, the truncated series is a good approximation. Also, the second expression is an expression for the total energy, not the kinetic energy. You need to remove ##mc^2## (i.e. the rest energy) to get the kinetic energy.
Likes Ibix
Note that these two equations are inconsistent. The first is the kinetic energy, ##K=(\gamma-1) mc^2##. The second is a Taylor expansion of the total energy ##E=\gamma mc^2##.
Doesn't it? The truncated series you've shown doesn't, but the infinite series does.
There isn't a contradiction. Einstein is just saying that you can ignore the first term when considering how energy changes with velocity since it doesn't change. It's only the later terms that matter. Or you can just use equation 1.
Thank you for the response. Yes, my Eq. 2 meant to be an infinite series. I just missed adding signs of + and... . I would dispute that it is for the total energy. My opinion is based on a) It has been given in some sources as an approximation of the kinetic energy; b) on my superficial analysis, and c) It was shown in Einstein [1] as an expression of the kinetic energy. My main point is that per E. explanation, "...mc2 does not contain the velocity, and requires no consideration if we are dealing with... the energy of a point-mass ..." It is clear. However, one cannot ignore this term in his original expression for the kinetic energy with mc2/sqrt(1-v2/c2). So, this is a conundrum.
Then you would be wrong. Sorry to put it so bluntly, but that is the case.
I happen to have [1], although in a Swedish translation, since many years ago when I was a teenager and started getting interested in physics. Where it talks about the series expansion, it most certainly is talking about the expansion of the expression
\frac{mc^2}{\sqrt{1-v^2/c^2}} = mc^2 + \frac{mv^2}{2} + \frac{3mv^4}{8c^2} + \ldots,
the total energy, not the expansion of
mc^2\left[\frac{1}{\sqrt{1-v^2/c^2}} - 1\right],
the kinetic energy.
Einstein does call the first expression "kinetic energy", but in modern terms that would be a misnomer.
You would be wrong to do so. Look up the Taylor series expansion for ##1/\sqrt{1-x}##.
I would also note that [1] was written by Einstein in 1916 as a popular account of his theories. Although Einstein does better than most in not dumbing things down to an extreme level, it is still a popular account and not a textbook. Furthermore, it was written a very long time ago and naturally the modern perspective on relativity is completely missing. I would not read it as a means of learning relativity, but rather as a means of understanding a little bit of how Einstein thought about relativity.
Thank you very much for your clarifications. Please bear with me. I usually come up with correct results at the end. (There is the famous expression of Churchill that Americans usually do wright things after they did everything wrong:-). However, my main point is still there (regardless which expression we call the total or kinetic energy). Albert clearly says that at the calculation of kinetic energy one should not use the term mc2 because it does not contain velocity. However (as I mentioned before) one cannot avoid it when using the original (not expanded) energy equation. At a present time, I cannot devote myself to delve in the advanced/modern review of the relativity, but I will try to do a calculation to verify if the series equation leads to infinity. At first glance, I thought it shouldn't. I will be back in a couple of days with more questions. I envision that my brief interaction with the topic of relativity may help me in some of my engineering endeavors.
Yes you can, you just subtract it if you want what is called the "kinetic energy" in modern terms. That term itself is referred to as "rest energy", i.e., the energy the object has in an inertial frame where it is at rest.
It is quite clear that it does, since it is the expansion of an expression that does diverge as ##v \to c##. If it did not diverge, then it would not be the correct series expansion.
Why not just derive the Lorentz transformation from the two postulates, then use proper time to get an expression for relativistic momentum, and then
W = ∫(dP/dt) dx ? Seems a lot cleaner, IMHO.
V. Dunaevsky: According to the literature I have, the expression (1-x^2)^-1/2, to which (1-v^2/c^2)^1/2 can be reduced, converges at abs x<1.
Yes? This has nothing to do with what you quoted, which discussed the limit ##x \to 1##, not the value of the series for ##|x| < 1##. It is perfectly possible for a function that has a finite value for all ##x \neq a## to diverge in the limit ##x \to a##.
You are missing a minus sign in your second exponent but, assuming that's a typo, agreed (Edit: writing maths is a lot easier with LaTeX - there's a tutorial linked below the reply box). The series converges to a finite sum for all ##|x|<1##. This is not what is meant by diverging as ##x\rightarrow 1##. That means that the sum of the series grows without limit as ##x## approaches 1 - which it does.
Physically, this means that the energy has a finite value for all ##|x|<1##. If it didn't, it would be impossible for a massive object to reach some speed less than ##c##. However it diverges (grows without bound) as we approach ##c##, with the result that ##E\rightarrow\infty## as ##v\rightarrow c##. The series sum also grows without bound as ##x## approaches 1.
Once ##x\geq 1##, the series does not converge to a finite value. Since the original function is either undefined or imaginary, that's not surprising.
Likes Sorcerer
I am sorry. I don't follow your logic. If we agree that the series converges for all abs x<1, how then the sum of a series can grow without limit (as you suggests) when x approaches 1?
Once we said that the series converges to a finite sum for all abs x < 1, than to me it means that no divergence could take place as x approaches 1.
What then to your mind means all abs<1? To me, it means that if one takes x=0.1 (v=0.1 c) or x=0.999 (v=0.999c), there will be a finite sum for each respective series.
The type of convergence you are talking about is the series convergence - as you increase the number of terms, ##n##, in the series you are summing for some fixed ##x##, does the sum tend towards a finite value? Yes it does, as long as ##|x|<1##. This is true, and is an important part of showing that the series remains a valid approximation for the function when ##x## is close to 1, but it is not relevant to the point @Orodruin and I are making.
The point is that for a given ##x##, where ##x<1##, the series converges to a finite value (##1/\sqrt{1-x^2}##, obviously). For ##x'##, where ##x<x'<1##, it converges to a larger value (##1/\sqrt{1-x'^2}##). For ##x''##, where ##x'<x''<1##, it converges to a still larger value (##1/\sqrt{1-x''^2}##). These values do not tend towards a finite value as you continue using larger and larger ##x##. So the value of the infinite series sum grows without bound as ##x## (not the number of terms you sum) increases.
Sum the series to as many terms as you can for x=0.9. Then x=0.99. Then x=0.999. Keep adding as many nines as you like, and you'll find the value continues to rise - it never stops as you add nines, and the sum doesn't tend towards a finite value. The sum rises without bound (Edit: by which I mean that there is no value you cannot reach by picking a large enough ##x##, ##x<1##) as you increase x. It reaches infinity in the limit of infinite nines, which is a long-winded way of writing x=1. This is exactly the same behaviour as ##1/\sqrt{1-x^2}##.
Yes, bit that is irrelevant with regards to the limit as ##x\to 1##. What is relevant for that limit is that this finite value grows without bound the closer you get to x=1.
You expect the sum of the series to be some finite value as long as ##|x|<1##, yes?
So, as ##x \to 1## that value increases. The closer ##x## gets to ##1## the larger the value.
So, indeed, there are no problems finding a finite value as long as ##|x|<1##.
But there is a problem finding a finite value when ##x=1##; the nature of the problem being that there is no finite value.
So we have an issue about two different convergence questions: one being about the infinite series as the number of terms n approaches infinity, and one talking about what happens as the value x approaches 1.Correct?
In any event, the latter diverging seems pretty intuitive as you are approaching division by zero when x approaches 1, and the smaller the denominator the larger the fraction in general, and there seems to be nothing in this case that would limit the size.Does this sound fairly close to right? I’ve been following along here and want to make sure I’ve understood.
I don't see that the sums will rise without bound for these series
Close to x=1, four terms is nowhere near enough for precision, so your result is nowhere near correct. No time at the moment to do a proper analysis so, back of the envelope, you are going to need at least a hundred terms to get anywhere near precise results for x=0.99. (Edit: commuter trains are quieter than libraries. The rule seems to be that you need approximately ##1.7\times 10^k## terms to get within 1% of ##\left(1/\sqrt{1-x^2}-1\right)## when ##x=0.999\ldots## with ##k## 9s - so x=0.99, you need 170 terms, x=0.999 you need 1700, etc.)
Edit 2: Notice that your own graph is showing you this. Only the black line is beginning to flatten out - so you don't have a good approximation for any of them. I expect you need around 17 terms to get a decent "final" value for the black line. But you need around 1700 to be able to see your upper two lines separating.
The series expansion of ##\gamma## is usually used when x is very close to zero, to show that Newton was approximately correct for v<<c. For that purpose, four terms is more than enough. You are trying to do something else, and I'm not sure what your goal is - to show that Taylor series expansion is wrong, or something?
Say
\gamma=\frac{1}{\sqrt{1-x^2}}
\gamma^2=\frac{1}{1-x^2}=1+x^2+x^4+x^6+x^8+x^{10}+...
x\rightarrow 1-0,\ \ \gamma^2\rightarrow 1+1+1+1+1+1+...= +\infty, \ \ \gamma\rightarrow +\infty
Likes Sorcerer and stevendaryl
Since I have been working on calculating higher derivatives for another purpose, here are the first six derivatives of ##\frac {1} {\sqrt{1 - v^2}}## evaluated between ##v = 0.1## and ##v = 0.9##.
Key: black = value, red = f', green = f'', blue = f''', yellow = f'''', cyan = f''''', magenta = f''''''.
Ricardo said:
Would you be able to demonstrate an expression for the sum of the series?
I sincerely hope it sums to ##1/\sqrt{1-x^2}##, given that that is what we are approximating. It's a standard result - the Taylor series expansion of a binomial can be found in many places. For example, the expansion can be found in the "List of Maclaurin series of some common functions" section of Wikipedia's page in Taylor series. Use ##\alpha=-1/2## (which is actually worked out for you) to get the expansion of ##1/\sqrt{1+x}## and replace ##x## in the result with ##-x^2##.
NEW
Hello Ibix,
Thank you for the comments. I am certainly aware that using more terms of the series will provide a more precise outcome. I definitely know that the expansion leads to the Newton formula ar v<<c.
It is not clear to me how closely the expansion series we use, see below, approximates the original, not expanded, KE formula. Would you be able to demonstrate the expression for the sum of the series?
The series you refer to here is for the total energy, not the kinetic energy. To get the kinetic energy, you have to subtract ##1##; this is equivalent to subtracting out the rest energy ##mc^2##. If you subtract ##1##, that eliminates the first term of the series, so the leading term is now ##\frac{1}{2} x^2##, which is the equivalent of the "original KE formula" you refer to.
Likes Sorcerer
The relation of kinetic energy and momentum in non relativistic mechanics is
\frac{1}{2}mV^2=\frac{p^2}{2m},\ p=mV
So momentum as well as kinetic energy should be corrected in SR. The energy momentum relation of energy and momentum is a kind of Pythagolean theorem, i.e.
E^2=m^2c^4+p^2c^2=\gamma^2m^2c^4 referring ##\gamma## in py post#22 for x=v=V/c. So,
p^2=m^2c^2(v^2+v^4+v^6+v^8+v^{10}+...)=m^2V^2+m^2c^2(v^4+v^6+v^8+v^{10}+...)
The second term of RHS is correction to approximation of non relativistic mechanics.
The expansion series is not intended to approximate the expression ##\frac{1}{2}mv^2##. It's intended to approximate the expression ##(\gamma-1)mc^2## where ##\gamma=\frac{1}{\sqrt{1-(v/c)^2}}##. The latter expression being the one with limits of validity that are greater than, and entirely subsume, the limits of validity of the former. We often refer to the latter as the expression for the relativistic kinetic energy and the former as the expression for the Newtonian kinetic energy.
The series expansion you refer to is an expansion of ##\frac{1}{\sqrt{1-x^2}}##. If you want it to coincide with the expression for the relativistic kinetic energy you will need to change it to ##\frac{1}{\sqrt{1-x^2}}-1##, set ##m=1##, and let ##x=\frac{v}{c}##.
PS to post#27
Kinetic energy KE is given by
KE:=E-mc^2=\sqrt{m^2c^4+p^2c^2}-mc^2.
The square root here is not easy for expansion to p. Instead subtraction of squared quantities,
p^2c^2=E^2-m^2c^4
is easier to handle in investigating kinetic contribution to energy in SR.
Thank you Ibix, PeterDonis, and sweet springs. It was a typo in the series that I presented above. Sure, the term with 1 should be kicked out for KE.
I still have some skepticism regarding the mass growing with speed and the energy going infinitely with v approaching c. Do we have any experimental data? In turn, I know that the calculations demonstrating that a parameter rises to infinity are often a result of a poor model. Take for example contact mechanics, it has been shown that the stress at the edges of the roller of the rolling bearing increases infinitely. A paradox was resolved by understanding that with a stress increase the deformation transforms from elastic to plastic thus removing the artificial infinite stress.
  • #31
The concept of relativistic mass has been deprecated for decades now. I am not sure how it persists still. The energy increases without limit as v approaches c.
Sure. Every high energy particle accelerator experiment ever conducted. The accelerators wouldn’t even work otherwise.
It is certainly possible that some future experiment will show a Lorentz violation, but so far there is none. This is despite a recent experimental renaissance on the topic.
  • #32
Yes, there is experimental data. Nowadays, people prefer the term "energy" for what you are referring to as "mass".
  • #33
"Mass growing with speed" is an old interpretation in the beginning of last century. Mass is constant.
"Energy going to infinity with v approoaching c" is right with relation
E^2=m^2c^4+p^2c^2
p=mc\frac{v}{\sqrt{1-v^2}}=mcu where v=V/c and instead of v
u:=\frac{v}{\sqrt{1-v^2}} is often used in SR as velocity instead of v.
V\rightarrow c, |u|\rightarrow +\infty, |p|\rightarrow +\infty, E\rightarrow +\infty
Peculiar case ##m=0## is experienced daily.
E=|p|c for photon. The relation
p=mcu does not work here due to m=0 and u=infinity.
  • #34
Thanks, everybody for a quick response. I am getting rusty in general science and am trying to clean up. I am delighted with your confirmation that the mass does not grow with speed. Accordingly, should we consider to be obsolete the statement of Einstein that "...If a body [moving with velocity v] takes up an amount of energy Eo, then its inertial mass increases by the amount Eo/c^2; the inertial mass of a body is not constant, but varies according to the change in the energy of the body." Einstein talks here about the energy absorbed in the form of radiation. As a counterargument to this, I may invoke a situation when the mass is actually reduced when it absorbs the radiation." A good example of the situation is warming up of a substance in the microwave oven. The liquid in the substance will evaporate (while energy is absorbed) thus reducing the mass of the substance, which may or may not be in a state of rest. Instead of the microwave oven, one may think about energy transfer by any kind of electromagnetic waves. At the very list, the energy balance should be considered when talking about the mass increase via energy transfer.
  • #35
That statement is still valid. The mass increase referred to there is the invariant mass, not the relativistic mass.
  • #36
This is because the system is not closed; you are allowing material to escape by evaporation, and not counting the mass of the evaporated material in the mass of the system. All of the statements from relativity that you have been quoting assume that the system is closed; if the system is not closed, the analysis gets more complicated, and you need to get clear about the simpler case of a closed system first.
  • #37
I see some caveats in the closed system as well.
1. If the system is completely closed, then, I guess, it wouldn't be able to absorb the external radiation.
2. If it still somehow absorbed the radiation and its mass increased, then it is not completely closed and thus its temperature will increase and it may start to emit thermal radiation losing its mass.
3. If, however, a mass of the body increased through irradiation, then its velocity should go down, which is a situation that contradicts to the main premise that the velocity wouldn't increase.
  • #38
That's correct. Either that, or you count the radiation as part of the system from the beginning, and add its energy in accordingly.
Yes.
Why?
What main premise are you talking about?
  • #39
Sure. The system would gain mass as it absorbed radiation and lose mass as it emits radiation. That is the point.
You should work out the math on this. It doesn’t work the way you think.
  • #40
Here I am trying to put one of the former questions somewhat differently.
If we all agree that the energy that is transferred to a substance by electromagnetic radiation converted to heat (for example, E = σTs^4, where σ is the Stefan-Boltzmann constant), then
>>>>. Where does the energy come from to increase the mass of the substance?<<<
  • #41
From the energy in the electromagnetic radiation that you said was converted to heat. Converting to heat means raising the temperature of the substance; that increases its rest mass.
  • #42
The energy came from whatever the source of the EM radiation was.
You may be thinking of mass as a form of energy and energy that is converted into mass is not available to be in other forms. That is incorrect: ##m^2 c^2=E^2/c^2-p^2## holds at all times regardless of the form of the energy.
  • #43
In SR mass is defined as energy measured in IFR called center-of-mass, COM, system where momentum of the system is zero. There mass is conserved before and after the interaction,so as for photon absorption case,
Mass of (Material + photons) = Mass of heated material
As another peculiar case, in electron and positron pair annhilation,
Mass of electron and positron = Mass of two ##\gamma## photons
with electromagnetic interaction and kinetic energy of electron and positron neglected.
Though photon has no mass, system of a photon and material or a group of photons has mass in general.
  • #44
sweet springs said:
Mass of electron and positron = Mass of two γγ\gamma photons
The KE is not neglected. It contributes to the energy of the photons.
  • #45
You are right. I mean I do not write them down in my formula for brevity in expectation that they are much smaller than ##m_e##. So for more detail,
mass of (electron, positron, their kinetic energy and their electromagnetic interaction)=mass of two ##\gamma## photons
Moreover, for absorption of photon case, it is usually so and convenient for us that photons around material have no momentum in total. If not, material is moving more or less in COM so its kinetic energy should be also involved in mass of the system.
  • #46
Thanks to everybody for a quick response. Your answers, some of which I expected, are definitely within the SRT orthodoxy.
To Dale. There is, perhaps, a typo in your expression
m^2c^2=E^2/c^2−p^2
I guess it should be
m^2c^4=E^2/c^2−p^2
To sweet springs:
Regarding your statement: Mass of (Material + photons) = Mass of heated material
Is this generalization truly justifiable? One can easily envision a situation when the mass of the heated material has remained heated even when the process of irradiation (associated with photons' interaction with the material) has ceased-- for a whatever reason- and the photons are no longer "stuck" within the material.
  • #47
Your use of the word "orthodoxy" here is not a good sign. We are using SR to make predictions about the scenarios you describe, yes. That's because, for scenarios like the one you describe, SR has massive experimental confirmation. There is no "orthodoxy" about it.
You need to decide what you are here for. If you are here to learn what SR, which has massive experimental confirmation, as I said just now, says about the scenario you describe, that's fine; but then you need to stop using words like "orthodoxy" and recognize that, if you don't quite understand something we're saying or it doesn't quite make sense to you, that's not a sign that SR might be wrong; it's a sign that you don't understand it well enough yet.
If you are here to push your own personal viewpoint, then this thread will be closed; that's not what PF is here for.
What photons are no longer "stuck" within the material? When photons are absorbed by a material and heat it up, those photons don't exist any more. They don't somehow stick around and escape from being "stuck" when the irradiation stops. Their energy is absorbed by the material and stays there.
  • #48
No, there isn't a typo in @Dale's expression; it is correct. Your expression is the one that's wrong; if you want ##m^2 c^4## on the LHS, then you would multiply @Dale's expression by ##c^2## to obtain
m^2 c^4 = E^2 - p^2 c^2
  • #49
I am sorry for the misunderstanding. My word "orthodoxy" is a positive sign in a context that your response helps me to refresh the knowledge that I received decades ago. I am quite appreciative for your responses. With my questions and your answers, I am trying to get some additional/advanced knowledge, which, I thought, I could apply in some of my professional fields, associated, particularly, with lubrication.
Now, this.
It bothers me that loss of heat/energy has not been considered as a natural outcome of the energy gain. As we agreed, even if the system closed, the radiation energy may penetrate the material and heat it. But by the same token, a portion of the gained energy will escape. A natural heat balance.
  • #50
To PeterDonis.
Yes. It is my typo. Thank you.
