Questions on Entanglement and Double-Slit Experiment
169 replies · 23K views · last reply
RProgrammer
Ok, I have a handful of questions:
1. Particles A and B are entangled, measuring A colapses the wave function of B, right?
2. The double-slit experiment produces different outcome based on whether or not a particle has been measured, right?
I am a student of these things also, but if welcome here would like to explore them along with you.
1. that is my reading also, altho I am uncertain of the meaning of the collapse of the wavefunction. Yes, yes, I am aware that the measurement causes the eigenvalues to take on a single measured value. In this entanglement, I should like to know, physically, what is going on, as I expect should many other people. Shall we assume that the entangled particles inhabit linked timespace, or is the connection more intimate? Is it even possible that the entanglement is some kind of identity, and our notion of separation is an illusion?
2.That is also my understanding. I have read that Feynman irritated his lecturers by presuming that there could be three slits, or four, or an infinite number. In this logic he formed his famous path integral formulation, and the basis of QED. IIRC I read this in a paper of John Baez. I could find the link if anyone is interested.
S.
NO
Your have a few ideas just tossed together there. Look up the detail on a few of the words I capitalize here. Use a thread search here where you can review the debate (and there is an ongoing debate) on these matters. Or use Google, library, WikiP etc.
You need to understand what these things are and where they apply, before you understand the debates, so take your time in looking them up.
By the way welcome to the forum, - you will find it works best for you if you take the time to understand an issue or term as clearly as you can, so you can ask an informed more specific question.
#1
ENTANGLEMENT is part of both A & B together the WAVE FUNCTION COLLAPSE doesn’t just go in one because of the other, it is that they are somehow part of each other.
That part is what is being affected.
How can two different things have a common part??
Try SUPERPOSTION – the idea that each A & B are made up of a SUPERPOSTION and a part of that remains common to both of them as long as they are ENTANGLED.
That shared part of SUPERPOSTION is what will collapse if either A or B is “touched” in a way that could result in a measurement.
#2
Has nothing to do with entanglement because it is just one photon at a time going by that still manages to create the pattern. Here again is SUPERPOSTION but not entangled just somehow working within the one particle to act as if it were a wave approaching two slits. BUT IF you disturb it near just one of the two slits, even if doesn’t go though the slit where you place the disturbance (measurement) it will not produce the pattern of a wave. How? SUPERPOSITION! Or some other interpertation (that how you get debates!).
Are these “Correct” descriptions of the reality of physics??
Can’t say but you can form an opinion as you learn the details of those terms.
Welcome to PhyscisForums, RProgrammer!
1. Yes, this is correct.
2. The different outcomes are triggered by whether you know - or could know - which of the 2 slits the particle traveled through.
Both of these experiments exhibit properties of the Heisenberg Uncertainty Principle.
Two more questions
Thanks for your responses, and RandallB: I worded my first question poorly, I know entanglement can apply to many more aspects than location or physical properties.
And I know my second question didn't have anything to do with entanglement, I just didn't want to post two separate threads.
I said I had a handful, I was just waiting for some answers to the first two.
These two are about electron spin.
C. Can someone entangle two electrons by their spins, (Google didn't yield very promising results so if someone could point me a link..)
D. If no one measured the results of a Stern-Gerlach experiment, would the input electrons be in a superposition of both deflected paths?
NB: I also know that other particles besides electrons have quantized spins, I just picked electrons because of their popularity.
I don't think they know how to do this technically yet. When someone discovers how, you will see a ton of expermints based on it, and he current photon experiments will become less key for showing quantum reality. What you need is something functionally equivalent to "Parametric Down-Conversion" but for electrons/spin rather than photons/phase.
How would you ever know? It's long been observed that automatic recording of data works to make quantum things happen. Suppose no-one looked at the photpaper target of the double slit experiment till the next day. The spots or interference patterns would still be there. Or look at the thread https://www.physicsforums.com/showthread.php?t=135098" on the attempt by the desigers of the delayed choice quantum eraser to remove the decision making from human control. No reason to think it wouldn't work the same way for Stern-Gerlach.
They are I believe the lightest particles that are
- Fermions, so quantum spin can be observed
- Charged, so that they can be manipulated with electromagnetism (the only force we really control)
- Observable in isolation (isolated quarks, for example, aren't)
selfAdjoint said:
I don't think they know how to do this technically yet. When someone discovers how, you will see ...
You may want to double check me on this but Stern-Gerlach experiments on electron spin were the fist Bell tests. PDC’s just make Bell tests much easier to do, so much so you don’t see much of the Stern-Gerlach spin tests.
Oddly enough one of the best short layman’s explanations of this can be found in “The Dancing Wu Li Masters”.
But be warned, this book is full of philosophical non-science interpretations (entanglement comes under Enlightenment – The End of Science) and does little to separate the two. So it’s a bit of a chore to be sure you just pick out just the science in the book.
Also, RProgrammer, when you do learn how to separate Science from the philosophical you will see your question “D” doesn’t belong here but in one of the Philosophy Forums.
By my understanding, quantum entanglement requires two events that may be spatially separate, but connected in a way that allows them to be described as one event.
I would submit that the twin slit experiment does provide evidence of entanglement.
Consider: a particle has been fired and the resulting interference pattern surrounds both slits. The moment you take a reading at one slit, the interference pattern will vanish at both simultaneously - regardless of the distance between them.
Now although we are only talking about one particle here, the collapse of it's wave function in respect to it's possible location does seem to make this a demonstration of both the uncertaintly principle and quantum entanglement.
If this is the case, then I believe the twin-slit experiment may offer possiblities for faster than light communication via entanglment - more so than the example of measuring two particles with different quantised spins.
Simon
Simon
A couple of points:
1. By definition, entanglement is where multiple particles are sharing a single wave function. Entanglement has been demonstrated with 2, 3, 4 and I think even more particles. But a single particle cannot be entangled, even though it is in a mixed state.
2. There is no known mechanism for transmitting information FTL, either with a double slit setup or by entangled particles. All the schemes you can develop have some catch that ultimately leaves you with nothing. But trying never hurts... :smile:
I think you need to consider more carefully exactly what you’ve said here and the impossible things you have assumed within the statement.
1 - How does the interference pattern get established by just one particle hitting your observation screen just one time – it cannot.
2 - A interference pattern of many hits does not “vanish” at a “moment” you start taking readings at one slit – a future pattern fails to build as long as you are disturbing the area of one of the slits enough to be able to take a reading, but you do not have to actually take the readings.
The idea that resolves the paradox of how an individual particle can participate in building up a pattern without knowledge of or help from other particles is called SUPERPOSITION.
No other experiment outside of Bell implies Entanglement.
But, it is not hard to argue that Entanglement and Superposition must somehow be related, but they are not the same thing.
Last question.. (Hopefully)
One (hopefully) final question:
E. In the double slit experiment, would an interference pattern develop if a third party knew, or could know which slit the particles went through?
If the wave function was reduced, whether in the retina of a human being or in some abiotic interaction, then the ambiguity would be resolved and the interference wouldn't happen. This covers all machines, transmissions, third parties, presumably teleportation of photons etc. Although I'll bet experimenters would love to try that last one, just to show they could, and rule out the possibility that there was non-QM physics there.
Dr Chinese and RandalB:
Yes I'm aware that the cited examples of entanglement involve two or more particles quantised in spin-up and spin-down positions.
Nevertheless, Wikipedia defines entanglement as a phenomenon
"in which the quantum states of two or more objects have to be described with reference to each other, even though the individual objects may be spatially separated."
If this description is accurate, it may open the door to interpreting twin slit superposition as an example of such entanglement. I completely recognise that this is debateable and the two are not usually classed together.
What I've been arguing is that, through the occurrence of an interference pattern, the two slits now qualify as spacially separate objects whose quantum states have to be described with reference to each other.
Really?
I may be misunderstanding you, but it sounds as though you are rejecting the very quantum dillemma that lies at the heart of twin slit superposition.
We're agreed that the twin slit experiment is performed by projecting a beam of particles, usually photons. However, the interference pattern is the result of the superposition of each individual particle and its potential journey through one slit or the other - not by one particle interfering with another. Indeed, the projecting beam can be dimmed so the photons enter the slits one at a time. The interference pattern still occurs.
Agreed, the wave function doesn't have to be collapsed by a measurement. Just blocking off one slit will do it. But as I understand it, a photon detector that isn't powered can be placed close to one of the slits and still not eliminate the interference. Once activated, however, the pattern dissappears - regardless of whether it detected a particle there or not. It's potential to detect a particle was enough to collapse the wave function and force the particle to 'decide' exactly which slit it entered - even if it went through the other one. Thus, a photon detector at Slit A, by not getting a reading, establishes by default that the photon entered Slit B. This eliminates the interference pattern.
RProgrammer: this probably answers your question too. Knowledge and detection seem inseparable. If an observer knows that a particle entered one slit, it can only be because it was detected.
What might be interesting is to imagine a microbe sized observer by one of the slits, who does have such knowledge. From his perspective, there is no interference pattern. From the human observer's viewpoint there is. This ties in with a slightly Einsteinian idea that wave functions and their collapse may be observer dependent.
As regards faster-than-light transmissions, I think the jury is still out on that one.
Then could you please write down the entangled wavefunction of the double-slit experiment?
Zz.
The analysis of the double-slit experiment does not even consider the state of the slits, you only consider the state of the photon, the slits represent restrictions on the allowable paths for the photon.
Interference is not observer-relative in this way; if at any point the photon interacts with another system (a detector, a microbe, whatever) such that an examination of that system could in principle tell you what path the photon took, then all observers will see the interference destroyed. For example, in the version of the double-slit experiment which uses electrons instead of photons, the experiment must be done in a vacuum or else the electrons' interactions with the air destroy the interfarence, in spite of the fact that in practice no human experimenter could deduce the path the electron took by examining all the air molecules immediately after the electron passed through them.
I believe it's actually been proven that according to the known laws of QM, entanglement can never be used for FTL transmissions.
Your still dealing with some kind of philosophy answer, like maybe the moon isn’t there if you don’t take the time to look at it. Measurement is not the point, it is whatever is used to effect that measurement that matters. A rain shower or a beam of light in front of just one slit, that will cast a trail of water or detectable shadow on the floor but still allow the particle to go through the slit to mark a spot on the wall. It still doesn’t matter if you, a 3rd, 100 or zero that look at the shadow on the floor to take a measurement. The fact the something was crossing the opening that can be affected by the particele as it pass is all it takes to stop the pattern from building up. Not that any actual measurement of any effect is made let alone known by anybody.
As to Simon 6 thinking that slits need to be entangled (?), not that a particle that has Superposition, is so far off the mark – all I can suggest is go back and keep reading.
And both of you need to remember, you are trying to understand an interpretation of what is happening here – superposition & entanglement have not been proven to be facts.
My point
So, what all this has been leading up to is this:
I have heard numerous places that Faster Than Lishgt information transfer cannot be achieved.
So, I would like to further my understandings of quantum physics from someone explaining to me what prevents this scenario from succeeding:
Given that you can entangle two electrons by their spins, you do.
The two Electrons (Signal and Recipient) are sent their separate ways, to the transmitter (signal) and to the reciever (recipient).
On the transmitter's side, he either measures or does not measure the spin of the signal, based on the value of the binary bit he wishes to transfer.
On the recievers side, there is an apparatus similar to the Stern-Gerlach experiment, which changes the course of an electron based on its spin.
There is also a double slit setup, which the previous device is connected to.
They are set up in such a way that based on the spin of the electron, it will travel into a specific slit.
My hypothesis is that if the transmitter does not measure the spin (and thus know the recipient's spin) then an interference pattern will develop from the electron being in a superposition of both deflections.
And corrsepondingly the superposition would collapse if the transmitter measured his signal electron and thus cause a particle pattern, which would be observable by the reciever.
So, that being said, I would like to know why and how this setup cannot effect Faster Than Light transfer.
They are set up in such a way that based on the spin of the electron, it will travel into a specific slit.My hypothesis is that if the transmitter does not measure the spin (and thus know the recipient's spin) then an interference pattern will develop from the electron being in a superposition of both deflections.
Very clever, I think you've basically reinvented the delayed choice quantum eraser, unless you'd already heard of this sort of experiment before. The answer is somewhat subtle--basically, you'll never see any interference in the total pattern of electrons that go through the double-slit, but if you do a coincidence count between the subset of electrons on the screen whose entangled double was measured in such a way that it becomes impossible to tell which slit the first electron went through, you will see an interference pattern in this subset. But since you don't know in advance which electrons' doubles will be measured in this way and which won't (you could prearrange it, but that would defeat the purpose of FTL communication), you can't see this interference pattern in the coincidence count until the experimenter at the other end has sent you an ordinary message at light speed or slower telling you which electrons he measured in which way.
I remember some old threads from way back which had longer discussions of the same sort of idea:
https://www.physicsforums.com/showthread.php?t=106770
https://www.physicsforums.com/showthread.php?t=107134
https://www.physicsforums.com/showthread.php?t=108015
As JesseM points out, this gets a little tricky. But I had once proposed the exact same setup (using photons) previously, only to realize that you don't get interference from entangled particles! You can see this in this enlightening article by Anton Zeilinger, p. 290, Figure 2.
Experiment and the foundations of quantum physics
.....My hypothesis is that ....
... I would like to know why and how this ...
So you’ve been baiting us all along – just to give us THIS! (Lame)
Come on RP you can’t just ignore everything you were suppose to be learning from your “Lead up” questions just so you can reveal the great inspiration you’ve been holding back since the OP anyway. When what you should have learned was more than enough to tell you that this is just non-sense.
Take a good look at the links JesseM offered and you will see yours will not come close to matching a “delayed choice quantum eraser". You need to address losing the pattern by messing with just one side of the slit. Here you ask us to force feed the double slit by messing with both sides and only allowing selective photons to one slit or the other based on a measurement! It’s been well demonstrated that intervention of much small amounts is more than enough to void any possiblity of producing a pattern and you doing it on both ends of the “quasi entanglement test”.
The “delayed choice quantum eraser" test do not force such selections – there they duplicate a double slit using a half-mirror allowing the photon to go though or deflect. The experamantor does not select which way photons go though.
At least try to use or think about the information you’ve already been given - if you had you’d have figured this on your own easily enough.
Ah, I hadn't caught the fact that RProgrammer's use of a Stern-Gerlach device would mean you'd already be measuring the spin of every electron that went through the double-slit, regardless of what was done to its entangled twin, since sending an electron through a Stern-Gerlach device and observing which direction it's deflected is a textbook way of measuring the spin along whatever axis the SG device is oriented along. So you're right, this experiment isn't going to show anything interesting about entanglement, although I think the idea RProgrammer was aiming for was probably something more like the delayed choice quantum eraser setup where the which-path info for the particle that goes through the slit is either known or not known depending on what happens to the entangled twin.
Agreed. It is the two possible paths of the photon that are behind twin-slit interference. No dispute there.
What seems apparent, however, is that the photon's choice of paths means it will definitely have interacted with one part of the screen or the other. Such an interaction will, arguably, have a very tiny but still measurable effect. It remains a matter of indeterminacy, until an examination is made, which slit actually encountered the photon. Thus, I'm suggesting that what might be at stake is not just the path of the photon but the state of the screen as well.
So with apologies to RandalB, I would ask a question that I hope is not too wide off the mark.
Before the wave function is reduced by examination, could it not be said that, due to the possible path of the photon, the condition of one part of the screen is interlinked in a quantum sense - dare I say even entangled - with the condition of the other?
The rebuttal to this would be that when a photon enters a slit, it has no measurable effect on the screen at all. If that is so, I accept that only the photon is in a state of indeterminacy. Nevertheless, I ask the question.
Yes indeed. I recall that version of the twin-slit experiment and don't dispute what you say.
I don't actually endorse the 1930s Copenhagen notion that sentient observers are required. 'Observer' is perhaps a misnomer, but I meant it in loose sense to include interaction with another system. 'Point of view' might be a better term.
Nevertheless, for me it remains an area of uncertainty exactly what level of interaction is required to reduce a wave function, and whether there are circumstances in which it may indeed be 'point of view' dependent.
As for FTL communication, I know it is the accepted wisdom in quantum theory that entanglement doesn't allow it. All the same, there are plenty still exploring this subject.
ZapperZ wrote:
Could you please write down the entangled wavefunction of the double-slit experiment?
No I can't. :smile:
Simon 6 said:
No I can't. :smile:
Then you have no business making such claims. The concept of "entanglement" starts from the mathematical description of the state of the system, NOT the other way around. You don't FORCE the concept onto something then then try to figure out if it is mathematically correct.
Go look EVERY single claim and work in this field. The state function is clearly written down so that everyone reading it can clearly see what is being "entangled" and how. This is the ONLY unambiguous part of this whole mess. The words you are using are, on the other hand, very ambiguous since they are clearly underfined, at least from the way you are using it (and please don't quote me some Wikipedia entry until you can tell me who wrote it).
Quantum mechanics may have differing interpretations, but what isn't ambiguous is the mathematical formalism that it uses to describe something. You ought to learn that FIRST before attempting to use it.
Zz.
I think "claim" is too strong a word. I submitted it as a proposition to be considered, even scrutinised. I knew it would not be endorsed as an authoritative statement - nor should it be.
I wouldn't accept that all ideas must be preceeded by equations, but I do accept that unambiguous formulas are usually required to promote a hypothesis to even a working theory.
In my defence, I have been using the subjunctive tense when crossing that difficult boundary between what has been established in quantum theory and what hasn't.
I retain it as a question: "Could twin slit interference also be an example of quantum entanglement"?
Admittedly, I did originally submit it as an argument rather than a question. Nevertheless, that is the spirit in which I meant it.
Can such a question be raised without formulating the precise equation to describe the wave function?
I hope so. I believe questions and ideas do have a role in science, even before theories are arrived at.
Simon
And my response to that is that you don't seem to appear to know anything about "entanglement". First of all, what PROPERTY is being entangled? You can't just say "I have these two things that are entangled". That makes zero sense. In a parametric down conversion generation of 2 photons, it is the spin of each of the two photons that are being "entangled" simply due to conservation of spins. Thus, people who claim such a thing can write down the state function of such a process, and the REST of us can say "Ah hah! We know what property we are looking at that is entangled".
You did no such thing. Not only are you not able to give us the mathematical description of the state of the system, you also didn't describe what particular property that is "entangled". Is it the location of the slit that is entangled? Is it the transverse momentum of the photon after it passed by that is entangled by the slits? What? What if I have 3, 4, 5, ... N number of slits? Do you then have the ablity to detect the GHZ inequality violation with such a configuration?
In physics, WHAT we ask and HOW we ask a question is often equally important as the ANSWERS that we get. We MUST be able to clearly ask a question before knowing the answers, because if not, we will be fighting with ambiguities on what exactly it is that we got. You'll have answers to something that could come from a number of non-unique questions.
Can a double slit be thought of as an example of quantum entanglement? Simple answer: NO.
Why? Because we currently know that the double slit is a clear illustration of the SUPERPOSITION principle of QM. This principle is an integral aspect of the "weirdness" of entanglement that isn't contained in a simple "conservation of angular momentum" classical scenario.
Zz.
Zapper, I totally accept the legitimacy of your answer - especially if it is correct.
I still defend the legitimacy of my question – certain aspects of which have yet to be dealt with.
I do have more than a passing interest in quantum theory. Our exchange has raised another question. Should a lack of expertise in this very controversial subject be considered good grounds not to ask certain questions until my knowledge reaches a certain level? That’s debatable in its own right. My only answer is, I’m too fascinated by the subject to be discouraged from doing so.
But back to the business at hand.
What you appear to be saying is that because twin-slit interference is already known to represent superposition - something we’re agreed on - it therefore cannot also be an example of entanglement. Or, if it is, I haven’t yet explained why.
My suggestion that it might be hinges on something that was discussed in another thread. It is whether a photon that traverses the slit actually interacts with an area of the screen or not.
If it doesn’t, then the concept of quantum entanglement does not seem applicable.
If it does, and an interference pattern still occurs, then that was the basis for my hypothesis.
If you collapse the position of the photon after it has traversed a slit, have you also collapsed the state of the screen – specifically the two areas of the screen where the photon traversed?
Now the wave function equation for the superposition of twin-slit particles has already been formulated. Is it possible that a similar wave function might be applied to the two alternative states of the screen, which may have been caused by the two possible traversions of the photon through the slits?
If so, I might be forgiven for suggesting that such a wave function could represent quantum entanglement. After all, two spatially separate areas of the screen would now appear to be in a state of indeterminacy until the path of the photon is established.
That, in any event, was where I was coming from.
Regards
Simon
There is a distinct difference between asking to learn and simply asserting something without any physical basis. You were doing the latter. Furthermore, and this is where you yourself have to understand, you are using concepts that have well-established definitions based on underlying mathematical formulation. In fact, in many parts of QM, it is the mathematical formulation that came FIRST, and then the normal human language and description that came second. So without understanding the mathematical aspect of QM, you are nothing more than a blind person being described the idea of "color". It doesn't mean that in your own way, you have no concept of color, but you certainly do not have the same concept in ways that the seeing-eye people do! This is the part that you seem to not have realized.
So when you talk about something being entangled, I have to ask exactly what property is being entangled. This is the requirement for everyone who either publish, or talk about entanglement, and thus, is a requirement of you also. If you cannot clearly write down and describe the state function of this entangled system, then we have nothing to talk about because your concept is either non-existent, or ambiguous. Now how productive of a discussion do you think that can lead to when the starting point is already questionable at best?
Regards
Simon
You seem to also not realize that this observation really has NOTHING to do with even the slit. For example, I could get the IDENTICAL interference pattern from a supercurrent going through two different paths and then meeting against at the same point. If I look at the current spectrum, I see the same Faunhoffer pattern. Don't believe me? Look at the superconducting quantum interference (SQUID) device that are already been widely used. If I apply the concept of superposition of all possible paths, I could explain the double slit, multi-slit, SQUIDs, the Delft/Stony Brook experiments, etc... etc. Now see if you can apply your double slit explanation too all these things? What are the "screen" equivalent in the SQUID device to be able to match the same observation? The supercurrent interacting with the "walls of the conductor"? That would be very odd and would require that you rewrite the entire description of superconductivity.
You can't do physics simply by looking at one specific example and tayloring your explanation ONLY to that example, while being ignorant to a whole zoo of phenomena that share the same principle, concept, and results. In every case, a description that has the widest, most general applicability will have a greater degree of validity that something that can only be valid with just one observation. Many people who do not understand physics are not able to make such generalized description, because it requires a mastery of a large body of evidence that are already out there. This is what I find missing in your attempt to re-describe the double slit.
Zz.
There's nothing "controversial" about how the rules of QM are applied to a particular problem like the double-slit experiment, the controversy only arises in the interpretation of what these rules mean in terms of some underlying physical reality (like the question of whether particles might actually have well-defined positions and momenta at all times even though the rules say you can never measure them simultaneously). And no one's telling you not to ask questions, just to accept that if you are told that one of your sketchy ideas doesn't match how things actually work in the mathematical formalism, then your idea must be wrong (although I doubt anyone would mind if you continue to ask for more explanation of why it's wrong, as long as you are not trying to argue that your idea could actually be right when you have no expertise in the subject).
I'm sure he's not making any such general statement, since an entangled system can certainly be in a superposition of states.
Do you mean the screen which contains the slits, or the screen where the interference pattern is observed? If you mean the screen with the slits, I think the main ways for it to interact with the screen would preclude the photon going through the slits, like if the photon was absorbed by the screen or scattered back in the direction it was sent. The slit itself is simply an area where the screen is not present, so how could the photon become entangled with a slit itself, any more than any other region of empty space? It might be possible for it to scatter off the edge of a slit and still go through, so perhaps a really detailed analysis would involve the possibility of the photon becoming entangled with some atom on the edge of the slit, but my guess is that the usual analysis of the double-slit experiment does not need to take into account this possibility to get an accurate prediction about the probabilities that photons going through the slit will be detected at different positions.
... collapsed the state of the screen – specifically the two areas of the screen where the photon traversed?
As a novice you still need to think though your questions or statements to be sure they are rational to you. You seem to have convinced yourself there is some evidence of screen “entanglement” because of “specifically the two areas of the screen where the photon traversed” !
What two areas of the detection screen 2 feet or more away from the slits did any individual photon ever actually traverse?
There is only where the photon would have gone if the two slits were only one slit; and that is not to a second area but to a wide group of unknown spots that includes the spot it did hit having a chance of having being hit again.
All based on the uncertainty of the one photon – no uncertainty of the screen can be justified in affecting the result.
At a minimum when creating new ideas, apply the principle of parsimony (ockham's razor) before you start promoting them and be able to respond to it.
Bohr once said that anyone who is not shocked by quantum theory has not understood it.
For example, one point of division between quantum theorists I am familiar with is the single universe/many worlds debate about superposition and quantum indeterminacy.
Granted, these are interpretations. Nevertheless, the responses here indicate that my questions are considered irrational in so far as I am taking such interpretations seriously.
At the back of my mind, when I talk about a photon being in a state of superposition I’m aware that there is yet to be a consensus on what this represents. Is it one reality in which a photon has no certain position until measured (Bohr) or two realities in which the photon does have a certain position both before and after measurement (Everett)? The latter seems to rescue Einstein’s view that reality really is out there.
Zapper, you cited examples where twin path superposition of a particle can occur without interaction with anything. I accept that, just as I accept that a single particle cannot be said to be in a state of entanglement. What I was saying – rightly or wrongly – is that in cases where a particle is in a state of superposition and has interacted with other particles – it is those other particles that may be entangled. I based that on a working definition of entanglement, where “the quantum states of two or more objects have to be described with reference to each other, even though the individual objects may be spatially separated.” To me, this appeared to be the case in the original twin-slit set-up.
Jesse, you asked for clarification. What I would say is this. In so far as a given particle interacts with anything at all on it’s possible journeys through the slits, then surely any state of indeterminacy that applies to the photon must also apply to whatever it interacted with. When I first submitted my argument, I had in mind both the slit screen and the observation screen.
So yes Randall: I was suggesting that the uncertainty of a photon’s position transfers to whatever it interacts with on the two possible paths.
Whether I put it in the form of an argument or a question, the idea is the same. For each particle, are there now two spatially separate areas of the observation screen, and possibly the slit screen, that are now connected while the interference pattern occurs. Or to put it another way: are there two possible states in one area of the screen intertwined with two possible states of the other?
If this notion is indeed wide off the mark, then a little further explanation is required.
