R = cos(theta) in polar coordinates?
7 replies · 78K views
merry
r = cos(theta) in polar coordinates??
Hullo everyone!
Hows it going?
I am confused with how to interpret the graph of r = cos(theta) in polar coordinates.
I tried graphing it manually. and this is how I interpreted it:
r(0) = cos(0) = 1
r(pi/2) = 0
r(-pi) = -1
r(3pi/2) = 0
r(2pi) = 1
This gives me three points in a line @.@ with one on the negative x axis, one on the origin, and one on the positive x axis. But apparently, its supposed to be a circle; how so?
Could someone please explain where I am going wrong?
Thanks v. much!
Mathematics news on Phys.org
hullo merry! :smile:
it's going fine, thanks for asking! :biggrin:
yes, it is a circle, with diameter from (0,0) to (0,1) …
a little bit of geometry will enable you to confirm that :wink:
your mistake was that you can't have negative values of r! :redface:
If you multiply both sides of [itex]r= cos(\theta)[/itex] by r you get
[itex]r^2= rcos(\theta)[/itex] which is the same as [itex]x^2+ y^2= x[/itex] or
[tex]x^2- x+ 1/4+ y^2= 1/4[/tex]
[tex](x- 1/2)^2+ y^2= 1/4[/tex]
a circle with center at (1/2, 0) and radius 1/2 so it is tangent to the y-axis.
While you can have r negative in the equation, that is interpreted in polar coordinates as the radius going the other way. With [itex]\theta= \pi[/itex], [itex]r= -1[/itex] which gives the point (1, 0) on the positive x-axis. Note that [itex]cos(\theta)[/itex] goes from 0 to 0 as [itex]\theta[/itex] goes from 0 to [itex]\pi[/itex] and again as [itex]\theta[/itex] goes from [itex]\pi[/itex] to [itex]2\pi[/itex].
As [itex]\theta[/itex] goes from 0 to [itex]2\pi[/itex], the point goes around the circle twice.
HallsofIvy likes coordinate equations, and I like geometry! :biggrin:
I totally disagree.
"r", in this case is measured from the origin, theta the angle the radial vector makes with the positiv x-axis.
Thus, we have the bounds:
[tex]0\leq{r}\leq{1},-\frac{\pi}{2}\leq\theta\leq\frac{\pi}{2}[/tex]
If we instead have the equation,
[tex]r=|\cos\theta|, 0\leq\theta\leq{2\pi}[/tex]
then this is a double circle, joining at the origin.
Thanks guys! It makes more sense now =D
Sorry for not replying! I didnt think my question would get noticed, so I gave up!
I don't quite understand what this means tho:
HallsofIvy, doesn't [itex]cos(\theta)[/itex] go from 1 to -1 as [itex]\theta[/itex] goes from 0 to [itex]\pi[/itex]?
I am confused with arildno's statement as well @.@
hi merry! :smile:
(just got up :zzz: …)
(have a theta: θ and a pi: π :wink:)
not quite … θ goes from -π/2 to π/2 as r goes from 0 to 1 and back to 0 (as arildno said);
between π/2 and -π/2, r doesn't exist (because r can't be negative)
arildno is saying that r = cosθ is one circle
but r = |cosθ| is two circles, touching at the origin :smile:
Notice the absolute value in arildno's "[itex]r= |cos\theta|[/itex]". If [math]-\pi/2\le \theta\le \pi/2[/math] then [itex]cos(\theta)[/itex] is positive so [itex]r= cos(\theta)[/itex]. That is the circle with center at (1, 0) and radius 1. If [itex]\pi/2\le \theta\le 3\pi/2[/itex] then [itex]|cos(\theta)|[/itex] is still positive so we have the circle with center at (-1, 0) and radius 1. The area tangent at (0, 0).
I said earlier that r< 0 is interpreted as 'the opposite direction'. Arildno disagrees with that but I consider it a matter of one convention rather than another.
