fluidistic
- Messages
- 3,934
- Reaction score
- 286
A ring with radius R has a constant current and is rotating around a diameter with constant angular velocity omega.
1)Calculate the radiation fields far from the ring.
2)What's the direction of the polarization for an observer along the axis of rotation?
3)What are the directions corresponding to maximum and minimum radiated power?
4)Calculate the force required to maintain a constant angular velocity.
That's one big problem, I don't find any helpful equation whatsoever despite efforts.
I am completely stuck on part 1, I've been skimming through both Jackson's and Zangwill's books as well as searching the web (found https://www.physicsforums.com/threads/electric-dipole-radiation-from-a-spinning-current-loop.800676/).
I am not really understanding the proceedure for part 1). The true expressions for the E and H fields are too complex to calculate so we make an approximation for far fields and we also make another approximation? I.e. we will consider only the electric dipole radiation assuming it is different from 0. If it is worth 0, then we will consider the magnetic dipole radiation assuming it is different from 0. If it is worth 0, then we will consider the radiation from the electric quadrupolar term? Is this all correct?
So I start with the electric dipole term, ##\vec p = \int \vec r ' \rho (\vec r ' ) d^3 r'##. In my problem there's no explicit rho (only J) but I'm not sure it's enough to conclude that ##\vec p=\vec 0##. I don't find any definition of the electric dipole term in terms of the current.
Now for the magnetic dipole term, it's worth ##\frac{1}{2}\int (\vec r \times \vec J)d^3r##. My problem is that I couldn't find out how to write the current in neither spherical nor Cartesian coordinates. I'm currently at page 413 of Jackson's 3rd edition and I'm at a loss. Even if I had calculated ##\vec m## I wouldn't know how to proceed.
Thanks for any help, really.
