(radiation) monpoles vs. dipoles
  • Thread starter Thread starter lion8172
    Dipoles Radiation
Griffiths explains in Chapter 11 that an electric monopole, such as a stationary point charge, does not radiate energy. In contrast, a point charge with an electric dipole moment radiates power, calculated using the formula P = μ₀ q² a²/(6πc), where a(t) is the acceleration of the dipole moment. The term "monopole" refers to any charge distribution that produces a spherically symmetric electric field outside a defined region. This distinction highlights the differences in radiation behavior between static and dynamic charge configurations. Understanding these concepts is crucial for grasping the principles of electromagnetic radiation.
lion8172
In the chapter on radiation (Chapter 11), Griffiths notes that an electric monopole does not radiate, but also that a point charge of electric dipole moment \mathbf{p} (t) = q \mathbf{d} (t) (where \mathbf{d} (t) is the instantaneous coordinate of the charge with respect to a fixed origin ) radiates with power
P = \mu_0 q^2 a^2/(6 \pi c), where \mathbf{a}(t) = \ddot{\mathbf{p}} (t). By "monopole," does he simply mean a point charge that doesn't move?
Science news on Phys.org
That would be one case. Any distribution of charge which gives a spherically symmetric field outside of a certain region is an electric monopole.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
