KarenRei
- 99
- 6
If we had a solid object of 1 square meter surface area, its maximum rate of radiation would be that of a blackbody of the same surface area, correct?
Now, if we had a cloud of ultrafine (<100nm) dust wherein the surface area of the *cloud* was 1 square meter, would it be similarly limited? Or would it be capable of significantly exceeding this, depending on the circumstances, due to the vastly increased surface area of the individual dust particles?
Now, obviously the dust particles aren't just going to be radiating their heat to the exterior - there's also going to be radiative exchange with each other, as particles both give off heat but also receive them from each other. If they were equally effective at radiatively emitting heat as they were at receiving it, one would expect the cloud to have the same limits as a solid 1-square-meter blackbody, since the only true radiative heat loss would be done at the surface.
However, is it possible that the particles could be effective emitters at a given frequency without being effective absorbers of that frequency? If that would be the case, then it would seem that the dust could emit at a greater rate than that of a solid 1-square-meter blackbody. But is that even possible?
If the above is not directly possible, the other thing that seems like it could distort the situation is if the emission of a photon cooled the dust particle enough to change its optical properties. After all, if a dust is fine enough and contains a small enough number of atoms, a single photon emission could have a relevant impact on its temperature. However, if this was the case we'd expect to see this effect most pronouncedly with the smallest possible "particles" - that is, simple gases. Do we? Are there gases that emit at a given frequency than they absorb it? But that would seem to imply a gas which emits faster than its blackbody temperature, which I've never heard of. Yet conceptually, if a material is changing in temperature, it only seems logical that it should be able to change in optical properties...
Just trying to get a better handle, conceptually, on these aspects of radiative heat transfer. :)
