Radioisotope-induced radioactivity in a protein molecule
In summary: Thank you for your input.Since we can't directly visualize the interaction between the transport protein and the substrate, we would like to learn more about how it happens. Does the transport protein physically attach to the substrate? Does it bind to another molecule that is present on the substrate? Does it somehow interact with the substrate in a way that allows it to move more easily through the membrane?These are all questions that we would like to answer in order to better understand the mechanism of substrate transport.
Igor 77
Dear Forum Members,
I am a molecular biologist. One of my projects is focused on the identification of a protein that interacts with a known organic molecule. Namely, I try to chase a transmembrane protein that is known to transport one organic acid. If possible, I would like to get an idea on whether it is possible to induce measurable radioactivity in a protein molecule by subjecting it to a radio-labeled interacting substrate. My idea is to label the transport substrate with a radioisotope, then isolate the whole spectrum of proteins from a given biological membrane, and finally identify the protein that physically interacted with the radiolabeled substrate (namely, transported it) by tracing the induced radiation in that protein.
Specifically, my questions are as follows:
1. Would the strength of the induced signal be measurable?
2. If yes, which method would be the most sensitive?
3. Which isotope would be the most efficient in the induction (out of N, C, O, or H)?
Finally, do you see any alternative way of inducing a measurable change in a target protein?
Thank you in advance!
Igor.
No this is not practicable. AFAIK all radioisotopes used for labeling emit gamma/x-radiation or beta particles which will not induce radioactivity in other atoms. The reasons being that they are usually too low in energy and way too low in intensity. Another issue might be if the intensity and appropriate decay products where available the radiation level would probably damage the target material (radiolysis).
Likes Igor 77
If your protein doesn't pick up atoms from the substrate it won't get radioactive. If it picks up some atoms you can work with them.
If the protein deposits some atoms you can do the reverse, mark the protein.
A sketch of the system would help.
Likes Igor 77
Dear Gleem, dear Mfb,
Thank you for your informative replies.
Since in our system the transport protein does not chemically react with the transport substrate, we have no means to transfer the radiolabel from the substrate to the transporter. Currently I try to figure out if chemical cross-linking between the protein and the transported organic acid would do the trick. The problem in this approach is unspecific cross-linking of the radio-labeled organic acid to many other proteins on the membrane surface. There is hope that the preferential interaction of the acid with its dedicated transport protein would result in measurably higher radioactivity associated with that particular protein.
Kind regards,
Igor.
What does that interaction do then?
If your protein spends more time at the substrate (migrates slower across the surface?) this would also be something you could look for.
Likes Igor 77
Dear Mfb,
Essentially, the substrate passes through a channel-like protein embedded into a lipid bi-layer (cell membrane). The substrate spends only very short time in the protein, but is physically very close to its surface. Also, more than one molecule passes through in a short period of time, which resembles a steady flow.
Thank you,
Igor.
What do you want to learn? Which protein let it flow through? Can you prepare substances with a different concentration of different proteins?
Likes Igor 77
A candidate would be hydrogen.
Marking C, N or O would usually be hard, because changing C, N or O requires breaking the molecular backbone.
What is slightly easier is marking hydrogens. There are several hydrogen exchange regions that do not break the molecular backbone and are not visible when all are H.
Note that it is not necessary to use a radioactive marker here (T). D is stable and can be traced by infrared and NMR spectroscopy - and IR or NMR observations of D show its location in molecule, not just its existence as radioactivity of T.
In case of organic acid, though...
Acid hydrogen is promptly exchanged in water. How about oxygen? How quick is the reaction
R-CO(17)O(17)H+H2O(16)=R-CO(17)O(16)H+H2O(17)?
O(17) should be conspicuous because unlike O(16) and O(18) it has a spin (although also a quadrupole moment).
Likes Igor 77
Dear Mfb, dear Snorkack,
Unfortunately, for my application, it would be insufficient to visualize the interaction between homocitrate and its transport protein in the membrane. My goal is to tag the transport protein upon contact with its substrate, so that it can be recognized from thousands of other proteins after the purification step. Actually, isolation of this protein is needed for learning its polypeptide sequence. This way we can see which gene in our model organism codes for this important protein.
In short, we try to learn which protein out of very many (over 100,000) present in a given plant organism can transport homocitrate. So far, no protein with the ability to transport homocitrate has been described in nature. But we know that it exists and we know in which part of the cell it is located. We just need to learn its polypeptide sequence.
Thank you,
Igor.
Found out that carboxylic acid oxygen exchange in water is in a decent timescale... of days.
And can be measurably catalyzed by enzymes.
Oxygen 17 natural concentration is 0.037 %.
Given surplus of water with 100 % oxygen 17, it should be easy to produce homocitrate which is 90+ oxygen 17.
Put it in ordinary water, say 1 % - well, a few days later you might have 50 % oxygen 17 homocitrate dissolved in water that is now 0,5 % oxygen 17. But if your experiment with membrane is done in hours?
You might identify, say water that is 0,05 % oxygen 17 (up from the 0,037 before you added homocitrate) and uninvolved enzymes which are 0,04 % oxygen 17 (exchanging oxygen from water into enzymes takes time in its turn) - and one enzyme, one position in molecule, which is 0,06 % oxygen 17.
Is that the correct approach?
Likes Igor 77
Dear Snorkack,
Thank you for this suggestion. Since our unknown membrane protein does not exchange atoms/groups with the transported substrate (homocitrate), I consider cross-linking radio-labeled homocitrate to all proteins which it encounters while on the way to its "gate" trough the membrane. Maybe we can detect the cross-linked product and sequence it, to learn its molecular identity.
Just for the case, I attach a figure that explains the situation in the living system. It is from the following paper:
Hakoyama T, Niimi K, Watanabe H, Tabata R, Matsubara J, Sato S, Nakamura Y, Tabata S, Jichun L, Matsumoto T, Tatsumi K, Nomura M, et al (2009). Host plant genome overcomes the lack of a bacterial gene for symbiotic nitrogen fixation. Nature 462: 514-517
Igor.
1. What is radioisotope-induced radioactivity in a protein molecule?
Radioisotope-induced radioactivity in a protein molecule is a process in which a radioactive isotope, also known as a radioisotope, is incorporated into a protein molecule. This can occur naturally or artificially through laboratory techniques. The radioisotope emits radiation, which can be detected and measured to study the behavior and function of the protein.
2. How does radioisotope-induced radioactivity affect the structure of a protein molecule?
The incorporation of a radioisotope into a protein molecule does not significantly alter its structure. However, the radioisotope can affect the chemical properties of the protein and may cause changes in its stability or function. It is important to carefully select the radioisotope and its placement within the protein to minimize any potential structural changes.
3. What are the benefits of using radioisotope-induced radioactivity in protein research?
Radioisotope-induced radioactivity allows for the precise labeling and tracking of specific proteins within a complex biological system. This can provide valuable insights into the function and interactions of proteins, as well as their role in various biological processes. Additionally, radioisotopes can be used to study the metabolism and turnover of proteins in living organisms.
4. Are there any risks associated with using radioisotopes in protein research?
Radioisotopes can be hazardous if not handled properly. They emit radiation, which can be harmful to living organisms, and must be used with caution and proper safety measures in place. Additionally, the use of radioisotopes in research may require special permits and regulations to ensure proper disposal and minimize any potential environmental impact.
5. Can radioisotope-induced radioactivity be used in medical applications?
Yes, radioisotope-induced radioactivity has various medical applications. For example, radioactive tracers can be used in imaging techniques to diagnose and monitor diseases. Radioisotopes can also be used in targeted therapies for cancer treatment. However, strict regulations and safety protocols must be followed to ensure the safe and effective use of radioisotopes in medical applications.
  • Chemistry
  • Biology and Chemistry Homework Help
  • Quantum Interpretations and Foundations
  • STEM Academic Advising
9K
  • General Discussion
14K
