Raising a complex number to the nth power
The discussion revolves around the computation of raising a complex number to the nth power, exploring methods such as De Moivre's theorem and the implications of raising complex numbers with a modulus of one to higher powers. The scope includes theoretical understanding and mathematical reasoning.
  • One participant seeks an algorithm for computing a complex number raised to the nth power, suggesting it might relate to the formula (x+y)^n.
  • Another participant proposes converting the complex number into polar or exponential form and applying De Moivre's theorem.
  • De Moivre's theorem is defined, explaining how to compute z^n using its modulus and argument.
  • A question is posed regarding the behavior of a complex number with a modulus of one when raised to higher powers, prompting further exploration.
  • A participant expresses uncertainty about the outcome of raising a complex number of modulus one to higher powers, indicating a lack of familiarity with the concept.
  • Examples of raising complex numbers to powers are suggested, including specific cases for exploration.
  • Another participant emphasizes that if the modulus of z is one, all powers of z will also have a modulus of one, and they will lie on the unit circle in the complex plane.
  • A later reply suggests that understanding this concept is more about knowledge than intelligence, reinforcing the idea that numbers with modulus one remain on the unit circle.
Participants express varying levels of understanding regarding the implications of raising complex numbers to powers, with some uncertainty and differing perspectives on the outcomes, particularly for complex numbers with a modulus of one. No consensus is reached on the specific behavior of these numbers.
Limitations include the lack of exploration into the implications of specific examples and the dependence on definitions of modulus and argument in the context of complex numbers. Some mathematical steps remain unresolved.
magda3227
I was looking around a little bit for an algorithm that would compute a complex number to the nth power.
Can anyone supply me a resource that covers this? I wouldn't imagine it being different than some sort of (x+y)^n formula.
Thanks in advance.
You can convert the complex number into either polar form or exponential form and then use De Moivre's theorem.
DeMoivre's theorem:
If [itex]z= r e{i\theta}[/itex], then [itex]z^n= r^ne^{i n\theta}[/itex].
r is the "modulus" or absolute value of z: if z= x+iy then [itex]|z|= \sqrt{x^2+ y^2}[/itex].
[itex]\theta[/itex] is the "argument" or angle the line through 0 and z in the complex plane makes with the real-axis: if z= x+ iy, then [itex]\theta= arctan(y/x)[/itex].
@Magda:
Here's a question for you to ponder: if you take a complex number, z, that has length 1 (a^2 + b^2 = 1 for z = a+bi), then what happens when you keep raising it to higher and higher powers: z^1, z^2, z^3, ... z^100000, ...
Thank you all very much. I was not familiar with DeMoivre's Theorem at all. I have seen Euler's identity, however.
In response to maze, I have no idea what happens when you raise a complex number, z = length 1 to higher and higher powers. I can't even begin to make an assumption of what would happen.
I'm not smart. :/
Try some examples!
Here are the most obvious ones:
1 1 1 1 1 1 1 1 ...
i -1 -i 1 i -1 ...
Here are some for you to try:
1/sqrt(2) + i/sqrt(2)
-1/2 + i*sqrt(3)/2
maze said:
@Magda:
I'm not smart. :/
It's not a matter of being smart, it's a matter of having specific knowledge. It is true, generally, that |xn|= |x|n. In particular, if |z|= 1 then every power of z will also have absolute value 1. In the complex plane, the absolute value of a number is its distance from the origin. Every number with absolute value 1 lies on the unit circle. If z is on the unit circle, the so is zn for all n, although they may move around the unit circle.
was hoping he would figure this out on his own...
  • · Replies 19 ·
  • · Replies 22 ·
  • · Replies 0 ·
