A Raising and lowering operators
  • A
  • Thread starter Thread starter John Finn
    Operators
John Finn
Suppose you take a Schroedinger-like equation $$-\psi''+F(x)\psi=0$$. (E.g. F(x)=V(x)-E, and not worried about factors of 2 etc.) This is positive definite if $$\int \left( \psi'^2+F(x)\psi^2 \right)dx>0$$. Is so, you can write this as the product $$(d/dx+g(x))(-d/dx+g(x))\psi=0$$, i.e. as $$a^{\dagger}a=0$$ for $$a=-d/dx+g(x)$$ [its adjoint is $$a^{\dagger}=d/dx+g(x)$$] if $$g(x)$$ satisfies a Riccati equation, $$dg/dx+g^2=F$$. So raising and lowering operators hold for any potential.
Is this true? Is it useful? Is it well known?
MENTOR NOTE: Post edited changing single $ to double $ for latex/mathjax expansion.
That you can solve second-order differential equations (of the Schrödinger type) using "raising" and "lowering" operators has been well known for many years now, and the general method for factorizing the equations into products of such operators can be found in this nice paper:
L. Infeld and T. E. Hull, "The Factorization Method", Rev. Mod. Phys. 23, 21 (1951)
If you prefer more accessible explanation of the method before jumping straight into this paper, I suggest that you check out the section in R. Shankar's textbook "Principles of Quantum Mechanics (second edition)" titled "The free particle in spherical coordinates" on page 346. The general techniques and many specific examples (as regards to your question about the validity for "any potentials") can be found in the paper by Infeld and Hull linked above.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
