3,884 replies · 241K views
DennisN
- 10,287
More Helios magic shot today...
Believe it or not, but these are pretty much straight out of camera (just minor edits done)...
The vivid colors are thanks to (1) the subject, (2) good sunlight, (3) CPL filter and
(4) the strangeness of a modded Helios 44 lens...
Lens: Helios 44M7 with reversed front element + CPL filter
Edit: Just some added contrast in Photoshop
Edit: Some gamma correction done in Photoshop
And also... a cat head:
Lens: Meyer Optik Lydith 30mm f/3.5
Staff Emeritus
Homework Helper
2025 Award
- 16,110
- 8,419
First photo with my new iPhone 16 Pro, looking out the window into my back yard.
Definitely a step up from my iPhone XR, which will drop off Apple's iOS upgrade list this fall. 24MP instead of 12MP, and a zoom lens that goes from 12mm (0.5x) to 120mm (5x), instead of a fixed 28mm. This photo used the 24mm (1x) setting, with some cropping before posting. Then of course the forum software resized it.
Homework Helper
Education Advisor
- 2,192
Fence lizard, afternoon time, camera on android smartphone. No treatments other than the second image done was magnification on the camera app.
I still fail to make my adjustment actions properly rotate the magnified photograph.
Homework Helper
Education Advisor
- 2,192
Did not work right when posting. I'll try to rotate that bigger one and repost if possible.
Looking at the image just on computer, should not need any rotating....
That's still wrong.
That's still wrong.
Homework Helper
Education Advisor
- 2,192
Rotation was done through Photos application on the mobile device, so hopes this looks proper. I may go back to previous post to remove the image.
Still wrong. Still WRONG!
I have no option here to remo,,........... I am removing the image.
Homework Helper
Education Advisor
- 2,192
A repost of upright image, magnified when recording. Hoping it is upright.
NoGood. I do not understand why.
Point Conception
- 1,934
I took screenshot, crop rotate in photos on oppo phone. Voila
Homework Helper
Education Advisor
- 2,192
morrobay
I do not know where my other post went, in which I had that one you show in #2769, with the correct orientation. Maybe moderator removed it.
- 10,062
You can rotate an image in two ways:symbolipoint said:NoGood. I do not understand why.
- By actually rotating the image;
- By inserting a "command" in the EXIF data to rotate the image when on display.
For example, I use your image and open it in one of my "image viewer" programs that I know rotates it with EXIF data when asked, and I overwrote the now "rotated" image. (Note that I converted your image to JPG because my "simple" program doesn't deal with WebP images.)
Then I open the image with a more complex program - GIMP - and it showed me this menu before opening it:
Now I have the choice of which version I want to open. If I choose "Rotate", it will actually rotate it. If I overwrite the image with the now "truly" rotated image, it will show as upright in every program (including the ones used by PF).
DennisN
- 10,287
Four shots of bees that turned out nicely, I think...
...shot three years ago but not edited until now (I'd actually forgotten about them
Nectar thieving...
Nice details on the wings...
Another sucker...
And one captured in flight, showing us the behind...
Lens used: Sony 55-210mm (with autofocus and image stabilization)
Nectar thieving...
Another sucker...
Staff Emeritus
Homework Helper
2025 Award
- 16,110
- 8,419
This prompted me to try rotating an image in the iOS Photos app, on an iPad. I started by duplicating an image, then cropping both of them approximately the same way, then rotating one of them using the 90-degree rotation icon (square with an arrow around one corner), not the free-rotation tool which lets you do an arbitrary angle.symbolipoint said:Rotation was done through Photos application on the mobile device, so hopes this looks proper. I may go back to previous post to remove the image.
Unrotated:
Rotated:
The Photos app on my iPhone seems to have the same options, but I prefer to use my iPad for photo processing because its screen is larger, making it easier to drag the crop boundaries where I want them.
For what it's worth, the iPhone camera produces HEIF images, and the Photos app stores them that way. When I transfer them to my iMac, they show up as .HEIC files which I can open in Photoshop. When I upload them to the forum using the "Attach files" button, they show up as .jpeg files, rescaled to maximum 800 pixels wide and 620 pixels high if they exceeded those dimensions to start with.
Homework Helper
Education Advisor
- 2,192
Left when I came around the other side for a different viewpoint but once done, something else was in view.
DennisN
- 10,287
DennisN said:Ok, I catched a bit of the antique bug and bought two old cameras on auction [...]
[...] I will put up photos of them here later, of course.
Old camera 1/2:
Voigtländer Brilliant
Year: 1936 (dated with help of the serial number)
Model: first metal body model (later models were made of bakelite)
Type: Medium format pseudo-twin lens reflex camera (TLR)
Shutter times: Just three to choose from (1/25s, 1/50s and B (bulb mode))
Apertures: Just three to choose from (f/7.7, f/11 and f/22)
Here it is. It looks a bit like a small lantern, but no, this is a camera.
It's pretty small and cute (dimensions: 11 cm (height), 7 cm (width), 7 cm (depth)).
The left top lever controls the shutter; you pull it downwards to take a photo. It still works
The left bottom wheel sets the shutter time. It still works.
The right bottom lever sets the aperture. It also still works.
And you focus by turning the small ring around the lens. And you have to a guesstimate
when focusing (that's what the texts "Landscapes", "Groups" and "Portraits" are there to help with;
the viewfinder will not show how it looks through the lens, the viewfinder just shows a static view
(see down below).
Look, there's a small photo counter on one side of the camera. It's not digital
And to help with framing the photo you open the top to access the viewfinder.
When framing the shot, you look straight down with your eyes at ca 30 cm from the viewfinder.
If you look any closer you will not see a view in focus.
The viewfinder sees through the top lens on the front via a 45˚ mirror.
And here's the viewfinder. Not digital, but a pretty bright and nice analog preview
of a small fan on my table. It looks like the viewfinder needs a bit of cleaning, though
And inside the viewfinder box the serial number can be found.
H586461 means the camera was manufactured in 1936 (according to this page).
I'm not sure exactly how it works to load film, but I think you have to open both the bottom and the back to load the film:
And inside the camera, is there perhaps a digital sensor somewhere?
Nope, no digital sensor here
We shouldn't expect very much, this little thing has been through a lot.
It's 89 years old, and judging from my testing I think it still works.
That's pretty impressive.
I'm thinking about putting in some LEDs in it and turn it into a small lamp for fun,
positioning the LEDs so light shines out through the two lenses (the main lens and the viewfinder lens).
Flyboy
- 633
Mr. Toad! You have awoken from your winter slumber!
Prepare to be pet and booped and held a great deal, Mr. Toad. My girlfriend finds you adorable.
- 19,385
- 15,622
Don't you even THINK about messing with my fries (grandson, photo by son)
Point Conception
- 1,934
Party update for sacrificing tomorrow. BTW go go dancing is still on in Thailand. To Fingertips pt 2.
- 5,196
That looks great.
My nearly 50 YO SE Asia party cap.
We spent a few weeks off the coast and in Pattaya after a port visit at the Naval base in Philippines. At the time, we rescued a few loads of boat people on the high seas and sent them to the UN refuge camp in Thailand.
We had to anchor out and take a small boat to the beach.
Point Conception
- 1,934
Does this look familiar. Subic Bay, Phillpenesnsaspook said:That looks great.
- 19,385
- 15,622
It could be mashed up hamburger, but I'm just guessing.berkeman said:What do you suppose that is to the left of the fries? I'm not recognizing it/them...
Staff Emeritus
Homework Helper
2025 Award
- 16,110
- 8,419
That other stuff, on the other hand, whatever it is...phinds said:Don't you even THINK about messing with my fries (grandson, photo by son)
- 5,196
I was a field engineer working at the base in the 80's.morrobay said:Does this look familiar. Subic Bay, Phillpenes View attachment 360284
DennisN
- 10,287
Springtime... sunshine... lovely day... time for some macro fun...
First up we've got arrowwood:
...and here are Angel's Tears daffodils:
...and a strikingly yellow dandelion:
...and further down on the ground I found a cute little ladybird taking a stroll:
And last, we've got a colorful bishop's hat:
(Photo 1-4 taken with Vivitar 90mm f/2.5 Macro which is a very good and rather fast macro lens)
(Photo 5 taken with Chinon 50mm f/1.7 Macro which is a pretty remarkable lens I happened to find by chance; it is a very small, very fast macro lens (reproduction 1:3) that focuses as close as 27 cm, and it is quite rare.
I've only seen one ever - the one I've now got at home
Graduate Diffraction from a set of concentric rings with random phase
- Gezstarski
- · Replies 2 ·
- Optics
- Replies
- 2
Correct statement about random process of radioactive decay
- songoku
- · Replies 12 ·
- Introductory Physics Homework Help
- Replies
- 12
Sinusoidal sequences with random phases
- ashah99
- · Replies 1 ·
- Calculus and Beyond Homework Help
- Replies
- 1
Art Please rate my photos on a scale of 1-5
- BadgerBadger92
- · Replies 73 ·
- Art, History, and Linguistics
- Replies
- 73
Very cool factory production line photos
- berkeman
- · Replies 7 ·
- Mechanical Engineering
- Replies
- 7
Undergrad Do you have an example of a truly random phenomenon?
- The_Baron
- · Replies 122 ·
- Other Physics Topics
- Replies
- 122
Undergrad How does spontaneous emission start laser oscillation if photons have random phases?
- kelly0303
- · Replies 19 ·
- Atomic and Condensed Matter
- Replies
- 19
Looking for a reliable inkjet All-In-One printer for photos and docs
- yungman
- · Replies 27 ·
- Computing and Technology
- Replies
- 27
Undergrad Random variable vs Random Process
- fog37
- · Replies 2 ·
- Set Theory, Logic, Probability, Statistics
- Replies
- 2
Stargazing Question about my photos of a Full Moon -- What is this point of light?
- Graham 1956
- · Replies 5 ·
- Astronomy, Astrophysics, Cosmology
- Replies
- 5
