Random Photos
  • Thread starter Thread starter Point Conception
    Photos Random
3,884 replies · 241K views
Fantastic photos of the insides of instruments:
Probe lenses and focus stacking: the secrets to incredible photos taken inside instruments
(DPReview)
Example:
The inside of a double bass. Photo: Charles Brooks
Reply
  • Wow
  • Love
Reply
More from the U. S. Space and Rocket Center: Space Camp students doing a microgravity training experience.
No, I wasn't in the tank with them. See the porthole windows?
Reply
Likes   Reactions: pinball1970, collinsmark, Point Conception and 1 other person
Repairing the car AC air mixer motor.
The HVAC system is all analog.
Reply
Another attempt at an aphid:
Better lighting and improved technique holding and steadying the camera.
Reply
  • Love
  • Wow
Reply
  • Love
My cat doing what she does best... being cute :smile:.
Reply
  • Agree
morrobay said:
Well this is the first time I can question your photos: There is not very good image resolution regarding the cat fur/whiskers
The photos were taken with different lenses, and one was taken with a smartphone.
They were also taken indoors, so the lighting is not optimal, I just used what I had :smile:.
Photo 1 was taken with the Soviet Industar 61 lens, which is far from optical perfection :smile:.
Though it can give a quite special, grainy, "analog photo" vintage look, which I sometimes like.
Photo 2: I don't remember which lens I used.
Photo 3 was taken with a smartphone.
Photo 4 was taken with the Chinese 7Artisans 35mm f/0.95.
Experimental photography, part 1
Some more recent ventures into experimental photography... and this time I will also report on a thing I have tried which I actually haven't seen anyone else do (but I wouldn't be surprised if someone has done it before, though):
1. Round aperture modification
This was an idea I had been toying around with, and now I've tried it. The idea was to modify a lens by inserting a fixed round aperture covering the original aperture blades. Why?
Well, the reason was to make a "better" stopped down bokeh quality (background blur) on a lens that may not have that quality originally.
First, when it comes to sharpness, most/all lenses have their sweet spot at f-stops a couple of notches above completely open aperture. Let's say we have a lens that goes from f/1.9 (open aperture) to f/16 (max stopped down); the lens will likely be a bit softer at completely open aperture and then increase in sharpness as you stop it down to, let's say, f/2.8 or f/4.
So stopping down a lens generally gives sharper photos, but there's another effect you get by stopping down: the bokeh (background blur) starts to get more in focus, i.e. less "creamy", which may be something you don't want if you are doing close-ups or portraits and want good subject isolation.
Furthermore, the background blur may get distracting if the aperture blades do not form a reasonably round aperture stopped down. That's why lenses with more aperture blades and/or rounded aperture blades generally give more pleasing bokeh stopped down; though some photographers sometimes like the bokeh that e.g. hexagonal apertures generate.
Example: A photo I've taken that has hexagonal bokeh balls.
The round aperture modification is an attempt to provide a "perfectly" round aperture close to the sweet spot of the f-stop that also gives better sharpness than shooting with the lens wide open. The downside with this modification is that you lose aperture control, i.e. you will not be able to shoot wide open anymore without reverting the modification.
The lens I selected for this modification was the Chinon 50mm f/1.9 which has got six aperture blades, and the lens was manufactured in Japan during the 1970s/1980s.
Here we've got the lens disassembled. You can see in the photo that the six aperture blades form a hexagon (bottom left). Above the lens are three metal washers I picked out as possible contenders for providing a round aperture.
Chinon 50mm f/1.9 disassembled.
After a suitable washer was selected I painted it black so there would be less internal reflections from it when it is inside the lens. When the paint had dried I put a couple of small pieces of blu tack on it so I could fix the washer inside the lens.
Left: The washer painted black. Right: The washer with some pieces of blu tack.
And then I inserted the washer inside the lens, placing it on top of the original aperture blades:
Left: Original hexagonal aperture. Right: Round aperture modification.
And here is the lens out in the sunny weather, showing the round aperture modification:
Well, does it work?
Yes, it does :smile:.
The effect is not obvious in every photo you take, but here are two photos taken with the modified lens:
Close-up of a forget-me-not (scorpion grass) with a very blurry background.
On the next photo we can clearly see that the bokeh balls in the background are "perfectly" round:
Close-up of a forget-me-not (scorpion grass) with "perfectly" round bokeh balls.
So, all in all it was a successful modification and maybe it can be an inspiration for others to try more experimental photography :smile:.
Reply
Nicely done! I'm not so bold as to disassemble my lenses like that :) I have put apertures on the front of the lens, but no results worth sharing.
Reply
Andy Resnick said:
Nicely done!
Thanks!
I understand! 🙂
The advice I got in the beginning was to start with a lens that's simple and comparatively easy to disassemble/reassemble, and I followed it. Another advice is to allow yourself the possibility of failure, and think that the lens can be replaced with another one if you fail. But, of course, if the lens is rare and/or expensive, the stakes get much higher. 🙂
Reply
Crow stuff...
Two crows engaging in some unknown behavior (at least to me).
I don't know what they were doing, it didn't seem as if one was feeding the other.
Maybe the left one expected some food from the right one, perhaps? I don't know :smile:.
This barren top of a tree seemed to be a favorite spot for them.
At one point there were three of them hanging around there.
Original photo:
Converted to black and white (grayscale):
A photo version with extreme contrast, making it into "pure" black and white (no grayscales):
Lens used: Canon nFD 50mm f/1.8.
Shot in the early morning with pretty bad lighting, which means less good photo quality.
This barren tree top is close to where I live, so I'll go there today with my zoom lens
and see if I can get closer to this group of crows :smile:.
Reply
@DennisN it might be parent offspring behavior after leaving the nest.
Reply
Hyde town Square yesterday. Some brass bands. The drummers all used match grip. Sacrilege.
Audley.
Leyland.
And Ashton.
From Hyde to Gee Cross and the Chapel graveyard. I tried to image a wren but he was too quick for me. The light and trees gave some nice effects.
This fellow was wealthy to have a family monument like this. Sad reading the inscriptions though. He out lived his wife, son and two daughters. The children all died young, typical for the 1800s.
This caught my eye when I was walking back.
Reply
You actually got sunstars (diffraction spikes) in photo 2 (tubas) and 3 (drum).
I am surprised you got that effect from photographing with a tablet (if you did use a tablet).
I don't think I've ever seen it in a photo from such a device.
The sun was behind me in photos two and three. You can see the sun in the first tuba, I think it's above the dark part which is the town hall.
The bass drum polished lugs catch it as well.
So the sun behind you with a very shiny surface in the image.
Reply
Captured on my way home 07:00
Reply
  • Love
Incredible atmosphere! Lovely!
I've been on the road again the past few days, this time to Ohio for my 50-year college reunion. Today in Warren, Ohio I passed a little park honoring Neil Armstrong.
Reply
  • Love
Some more plants...
Pink tulips (quite heavily edited to get a black background)
A linden branch (also with a black background)
Summer snowflake
A red tulip and white daffodils
...and a colorful pink tulip:
(all shot with the lens Jupiter-37AM 135mm f3.5 MC + CPL filter)
Reply
  • Love
  • Wow
DennisN said:
Some more plants...
Beautiful photography! Thanks. :smile:
Reply
There is something for everyone here
Reply
