Random Thoughts Part 5: Time to Split Again
2,662 replies · 216K views · last reply
BornCane said:
I don't understand Boolean algebra
hasn't there been binary systems before Boole
China had a binary system, even Ancient Africa had a binary system
Africa had the Odu of Ifa system
Egypt, India etc. had the binary system as well
what made Boolean logic so different?
I can't speak for the history. "Boolean" algebra is not synonymous with a mathematical, base-2 system. They are different things.
Boolean algebra deals with concepts of True, False, not And and Or (among a few others). One can use Boolean functions to construct binary components. For example, in your computer's CPU in its arithmetic logic unit (ALU), things like binary adders can be broken down into many AND, OR, NOT, and XOR gates (including NAND and NOR gates, etc.)
These logical gates (AND, OR, etc.,) can be constructed out of transistors.
rootone said:
Boolean is not just a means of counting as are other binary systems, it is also a formal system of logic,
so is that what separates it from other ancient binary systems?
Boolean this:
Row of young girls with shoulder-length brown hair in matching grey dresses sitting side by side against a white wall, with reflections appearing to repeat them in a mirror-like illusion.
How many different girls are in this photo?
http://www.dailydot.com/lol/instagram-girls-mirror-photo-optical-illusion/?fb=dd
After much puzzlement, I think I found the answer.
this is the ancient africa Ifa system
https://en.wikipedia.org/wiki/Ifá that is binary
so you would differentiate this from Boolean Algebra?
rootone said:
Two? - and two mirrors?
but how can a mirror give reflection to another mirror?
IMO, the answer certainly must be found by thinking in terms of mirrors. The alternative, no mirrors, would require that it either be photoshopped, which would make it a stupid waste of time, or that the photographer had access to extremely rare phenomena.
I don't even know where to start.
Let me repeat, Boolean algebra, in and of itself, is not a binary counting system. However, it can be used for many things from such things as analyzing somebody's argument to determine if it is a valid argument, to building hardware based, binary systems such as the one you used to write your post on or read this post on.
Ifá, on the other hand (If I understand the link correctly) is a system for performing religious, psychic divination. They are in completely different realms.
I see two.
There's a mirror perpendicular to the wall they're leaning against, sticking out where there is a black line. There is a second mirror just out of shot on the left. Probably the easiest way to visualise this is one of the booths where you can try clothes on in shops. There are mirrors on both side walls; the girls are sitting on a bench on the back wall using up all the space; the camera is pretty much pressed up against one wall near the door, looking across the booth on a slight diagonal.
That's my take, anyway.
Let me make up a quick example of what a Boolean expression is. For the purpose of this post I'll spell everything out instead of using symbolic shorthand.
Below represents a single Boolean expression that I just made up now, but for clarity, I'll break it up into several smaller expressions:
A, B, D, and E are input variables:
C is true if both A and B are true.
F is true if either D or E is true.
G is true if both E and A are true.
H is true if either "A is true" or "F is not true", but not both (if both "A is true" and "F is not true" are true, H is false).
J is true if C is true, G is false, and H is true.
So here is a question you can use Boolean algebra to help solve:
If we have:
A: True
B: True
D: False
E: False
What is J (True or False)?
That's a very simple Boolean problem. They can get a lot more complicated. This was just for a simple example.
Two is certainly the minimum number of different girls there could be.
According to my wife, anymore than one is big trouble.:wink:
BornCane said:
Four small figurines of famous scientists in cartoon style: one with wild grey hair and a yellow sweater, one in a white wig holding a red apple, one with a long white beard holding a skull, and one holding a tennis ball and a wooden stick.
name the 4 scientists left to right
I get to name them? O.K.: Larry, Moe, Curly, Shemp.
BornCane said:
Four small toy figurines of famous scientists in a row: one with wild grey hair and a moustache, one in a white wig holding a red apple, one with a long white beard holding a skull, and one with dark hair holding a tennis ball and a stick.
My guesses are
In order from left to right,
Albert Einstein
Isaac Newton
Charles Darwin
Nikola Tesla
collinsmark said:
My guesses are
Albert Einstein
Isaac Newton
Charles Darwin
Nikola Tesla
correct :)
the first 3 are pretty easy...but Tesla i thought would of been more tricky
BornCane said:
correct :)
Because Tesla seems to be holding a slim jim which has nothing to do with anything.
What the hell is that floppy stick thing supposed to be?
For consistency's sake, determine x in the following:
Apple:Newton = Scull:Darwin = x:Tesla
and
Apple:Newton = Scull:Darwin = x:Einstein
Sepia black-and-white portrait of a man with a mustache and dark suit, touching his temple with one hand while holding a glowing spherical glass globe in the other, against a dark background.
i think its suppose to be a lightbulb he is holding or whatever the heck this is
He has something like that in his other hand. I'm asking about the thing in his left hand (far right in the picture) that looks like the meaty snack treat, a Slim Jim.
Good question. My guess is a cane, like this one from a statue of him (statue is displayed in Niagara Falls). I guess he's holding the cane in the middle in the miniature figurine.
Bronze statue of a standing man in a long coat and vest, holding a cane in one hand and a top hat in the other, set on a curved stone plinth amid green trees.
[Source: http://www.teslasociety.com/niagarafalls_tesla.htm]
collinsmark said:
Good question. My guess is a cane, like this one from a statue of him (statue is displayed in Niagara Falls). I guess he's holding the cane in the middle for the miniature figurine.
Plausible.
But, I think a cane would not be a proper icon-object for him the way Newton's Apple is for Newton. What would a proper icon-object for Tesla be? And for Einstein?
It looks like a squash.
Photo of a pale yellow butternut squash with a bulbous base, narrow neck and small stem on a white background.
Psinter said:
Two, but the bracelets confuse me. I can't see the bracelet of the girl who is looking directly into the mirror.
It could be that the bracelets, in any given reflection, are ultimately hidden from view due to being blocked by another wrist (or two). Since each reflection can be characterized by having its own perspective and angle (relative to the camera), this seems plausible. I.e., in some reflections the bracelets are blocked from view, but not in others.
It's tough to tell just by eyeballing it though.
Without detailed analysis though, I would guess there are just two girls.
Sophia said:
... I don't know what's wrong with holding hands. I think holding hands is awesome. That's a question for some men.
Not really, A handshake between men is a very common gesture indicating agreement.
zoobyshoe said:
... it either be photoshopped ...
The background wall gets greener for the more distant girls which could be expected from multiple reflections through glass.
I don't think somebody 'shooping' would think about doing that.
WWGD said:
Can't see how Lewis Carroll got a hold of a camera.
HG Wells did.
