Rate of change of angular acceleration?
The discussion revolves around the calculation of the rate of change of angular acceleration, denoted as ψ, in the context of an object falling 90° about an axis of rotation in the x-y plane. Participants explore various equations and methods related to angular acceleration, integration, and the implications of using degrees versus radians.
  • One participant calculates ψ as approximately (0.1578 rad/s²)/θ, where θ is in degrees, and discusses the implications of this value on angular acceleration.
  • Another participant questions the integration method used, noting that α depends on θ and asks for clarification on the meaning of S.
  • There is a suggestion that the rate of change of angular acceleration might be related to energy conservation principles, with a proposed relationship involving ω and gsinθ.
  • Some participants assert that the rate of change of angular acceleration is constant at 0.157 rad/s² for each degree of rotation, while others challenge this interpretation.
  • Disagreement arises over whether the calculations represent ψ as α/ω or dα/dθ, with multiple interpretations being presented.
Participants express differing views on the nature of ψ and its relationship to angular acceleration, with no consensus reached on the correct interpretation or calculation methods. Disagreements persist regarding the use of degrees versus radians and the implications for the rate of change of angular acceleration.
Limitations in the discussion include unclear definitions of variables such as S and the dependence of α on θ, which complicate the integration process. The relationship between angular acceleration and the chosen units (degrees vs. radians) remains unresolved.
risecolt
I am calculating the time it takes for an object to fall 90° about an axis of rotation in the x-y plane. I have managed to calculate the rate of change of angular acceleration, which will be represented by the symbol ψ.
Unfortunately it is not rad/s^3, but (rad/s^2)/θ or [itex]\alpha[/itex]/θ.
The value of ψ ≈ (0,1578 rad/s^2)/θ.
θ represents 1 degree or ∏/180 in radians.
The following equation applies for finding the angular acceleration at any given point.
(1) M = I*[itex]\alpha[/itex] = mgrcosθ, where rcosθ is the arm from the center of rotation to the center of the mass.
I have tried to come up with an equation by integration, but I guess that won't be possible since ψ I've designed is not rad/s^3. Regardless, this is my progress:
[itex]\alpha[/itex] = [itex]\alpha[/itex]
ω = [itex]\alpha[/itex]t + ωo
S = 1/2 [itex]\alpha[/itex]t^2 + ωot + So
S is always S+So, so So can be excluded from the equation.
So I thought that if I (virtually) integrated this equation once more, I would be allowed to include the rate of change of angular acceleration.
S = 1/6ψt^3 + 1/2 [itex]\alpha[/itex]t^2 + ωot + So
[itex]\alpha[/itex] would be replaced by using equation (1) from above.
S = 1/6ψt^3 + 1/2 (mgrcosθ/I)t^2 + ωot + So
For this example I'll set the moment of inertia I = mr^2, giving me:
S = 1/6ψt^3 + 1/2 (gcosθ/r)t^2 + ωot + So
This tells me that the angular acceleration is independent from the mass of the object.
If this is correct, I need to use the cubic root and I'll have to cross my fingers and hope that I won't get any complex numbers.
Is this a correct way to implement the rate of change of angular acceleration?
Do you have any other suggestions?
Spoiler
ψ is not constantly ≈ (0,1578 rad/s^2)/θ. It is actually a sine wave.
http://cognitivenetwork.yolasite.com/resources/Diagram.png
I have discovered a new method that I might be able to use.
How about preservation of energy?
If mgh = mv^2 is true then
mgsinθ = mω^2, and there is that beautiful sine wave you see in the diagram.
I'm not sure if they are related, but there it is anyway.
gsinθ = ω^2
ω = sqrt(gsinθ)
Then I can set up the standard equation for ω
sqrt(gsinθ) = [itex]\alpha[/itex]t
t = sqrt(gsinθ)/[itex]\alpha[/itex]
Then I'm just missing one thing, and that is ψ... and I'm lost again.
WARNING:
ψ = [itex]\alpha[/itex]/θ = rad/s^2 / degree = rad/s^2 / (π/180) = 9.0467 rad/s^2/rad = 9.0467 rad/s^2.
This does not change the fact that it is the rate of change of angular acceleration.
Then you might have calculated ##\frac{\alpha}{\omega}##.
What is S?
α depends on θ, how does your integration work?
What is S?
S is the distance or the arc length.
The rate of change of angular acceleration only depends on θ.
I integrated by starting with ψ instead of [itex]\alpha[/itex].
ψ = ψ
[itex]\alpha[/itex] = ψt + [itex]\alpha[/itex]
etc.
Where is the difference between S and θ, apart from constant factors?
ψ depends on S, so your approach does not work.
What is S?
I might not have calculated ##\frac{\alpha}{\omega}##.
The rate of change of angular acceleration IS 0.15789473684210526315789473684211 rad/s^2 for every degree it turns, not radians, but degrees.
Degrees are evil. And I think you are describing α/ω Or dα/dθ.
NO! For every degree that it turns, the angular acceleration is changed by 0,157 rad/s^2.
So if the angular acceleration is 2 rad/s^2 at an angle of 46 degrees, then it is (2 + 0,157) at 47 degrees.
I know, and it does not influence the possible interpretation of this value.
  • · Replies 21 ·
20K
  • · Replies 138 ·
9K
