Rate of change of angular velocity
The discussion centers on understanding the relationship between angular velocity, angular momentum, and torque when a particle's radius of rotation decreases to zero. It highlights that while angular momentum is conserved (dL/dt=0), angular velocity can change due to the centripetal force acting on the particle. The participants derive equations to express the rate of change of angular velocity in terms of the radial velocity and radius, concluding that angular acceleration is inversely proportional to the radius. A key point raised is the contradiction that arises when considering a point mass, which theoretically leads to infinite angular velocity as the radius approaches zero, while practical scenarios suggest a finite value. The conversation emphasizes the complexities of classical mechanics and the distinctions between point particles and those with physical dimensions.
deep838
Let a particle of mass m be rotating in a circle, radius be r, axis of rotation through the center and perpendicular to the plane of motion.
Now if the radius is made decrease somehow at some rate until it get's zero, how do I find the rate of change in angular velocity?
Also, the angular momentum being conserved, dL/dt=0, ie, no torque acts on it. Yet since the angular velocity is changing, there has to be an angular acceleration. So how can there not be a torque? Is it because w*dI/dt exactly cancels I*dw/dt?
I haven't studied this yet but I'll give it a shot
Using L=rmv you can work out \frac{dv}{dr}, since L and m are constants.
Using that equation and a given rate of change of the radius (\frac{dr}{dt}) you can work out \frac{dv}{dt}.
Edit: As for your other questions ... idk what torque or interia are :3
dv/dr works out to -v/r...
dv/dt works out to -v/r(dr/dt)...
is that it?
i really don't think that's all!
let's wait for some other opinions!
is that it?
That really is pretty much about it.
If you want to visualize what's going on better, and see exactly how the angular velocity can change without any torque being applied, consider a single moment frozen in time. The mass is moving with linear velocity v in a direction perpendicular to the radius. Apply more centripetal force to reduce r, and v doesn't change.
ok got it... thanks to both of you.
In the diagram the dotted line represents a section of a typical trajectory when a circling mass is pulled closer to the central axis.
The dark grey arrow represents the centripetal force.
To understand the angular acceleration it helps to think of that centripetal force as decomposed in two perpendicular components:
- one at right angles to the instantaneous velocity
- one parallel to the instantaneous velocity.
The parallel component increases the angular velocity.
The general expression is 'contraction of a rotating system'. The example you ask about, a mass circling a central point, is a specific case of that.
When a rotating system is contracting the centripetal force is doing work, and the overall kinetic energy of the system increases.
The only case where the centripetal force is not doing work is when the motion is perfectly circular.
To find the angular acceleration as a function of the velocity in radial direction. First some remarks:
I will use the following names:
v_r velocity component in radial direction
v_c velocity component at right angles to the radial vector (circling component).
\omega Angular velocity
As pointed out earlier in this thread:
Angular momentum L is given by:
L = mv_{c}r
So you can compare two states:
1 - before contraction
2 - after contraction
You start with circular motion (state 1), you reduce the radial distance by half, from there onwards circular motion again (state 2). Then the following applies:
v_{c,1}r_{1} = v_{c,2}r_{2}
From state 1 to state 2:
- when the radial distance is halved the tangential velocity is doubled.
- when the radial distance is halved the angular velocity is quadrupled.
In reply #4 Nugatory offered the suggestion that 'the angular velocity changes because the tangential velocity stays the same'. Obviously that suggestion is wrong, as it violates v_{c,1}r_{1} = v_{c,2}r_{2}.
We know that \omega r^2 is a constant, so the derivative of that expression with respect to time is zero:
\omega r^2 = constant \qquad \Rightarrow \qquad \frac{d(\omega r^2)}{dt} = 0
Differentiating:
r^2 \frac{d\omega}{dt} + \omega \frac{d(r^2)}{dt} = 0
I want to work towards an expression with the radial velocity component (dr/dt) so I use the chain rule.
r^2 \frac{d\omega}{dt} + 2 r \omega \frac{dr}{dt} = 0
Dividing both sides by r2, and rearranging:
\frac{d\omega}{dt} = - \frac{2 \omega}{r} \frac{dr}{dt}
that's understandable... but tell me this... if the angular acceleration, α\propto-r-1, then what will happen th it at r=0?
in that case, α approaches ∞ and the angular velcity, ω, should also become ∞.
but seeing this problem using our 'common sense', isn't it so that ω will have a finite value? the radius from the axis becoming 0, the motion then transforms to pure rotation... with K.E. \frac{1}{2}Iω2 being equal to \frac{1}{2}mv2 plus the work done to reduce r!
the two solutions appear contradicting...
Hello?? Anyone there?? It's been a long time with no replies.
The math applies to a point mass. A mass sphere will have a finite ω when pulled to the center.
A hypothetical point particle has no angular moment of inertia which is why ω goes to infinity.
I don't get that. I thought all particles have moment of inertia.
A classical point particle has no intrinsic spin in the way,for example, a sphere can have a spin angular momentum about its center of mass. If a classical point particle is in say a circular orbit of radius ##r## then, after orienting the coordinates as needed, its orbital angular momentum can be written in coordinates as ##L = mrv\hat{z} = mr^{2}\omega \hat{z}##. It doesn't of course have a spin angular momentum in the above sense, on account of it being a classical point particle.
I was thinking along the lines that his imaginary particle had no dimensions, so it wouldn't have any angular inertia. What happens at a quantum level is another story.
hmm... pretty complicated stuff! will get back to these things when i'll get to know all these things.
  • · Replies 34 ·
  • · Replies 16 ·
  • · Replies 60 ·
