Rate Of Change Of Current In An Inductor
The discussion revolves around the behavior of current in an inductor when a DC voltage is applied. The original poster presents a scenario involving a coil with specific inductance and resistance values, aiming to analyze the rate of change of current at the moment of switching on and after a short time interval.
  • The original poster attempts to graph the current increase and calculate the rate of change using differentiation. They question whether their method of calculating slopes is sufficient for confirming their graphical results.
  • Some participants question the units used in the calculations, particularly regarding the rate of change of current, and suggest verifying the labeling on the graph.
  • Others suggest methods for graphically representing the initial rate of change of current and confirm that using secant lines is a valid approach.
The discussion is ongoing, with participants providing feedback on the original poster's calculations and suggesting clarifications. There is a recognition of the need to ensure correct unit usage and graphical representation of results. Some participants express confidence that the differentiation performed is adequate for the problem's requirements.
Participants note the constraints of the homework context, including the inability to seek help from college resources during a break. There is also mention of potential confusion regarding the interpretation of the initial rate of change of current and its graphical representation.
Spurs4ever
A coil has self inductance L of 2 Henrys, and a resistance R of 100 Ohms. A DC supply voltage E of 100 volts is applied to the coil.
Show graphically the approximate rate at which the current increases at the moment of switching on (t=0) and after 10ms.
Confirm your results by differentiation.
Instantaneous current: i=(E/R)(1-e^-Rt/L)
Slope of a tangent: y2-y1/x2-x1
di/dt: i(b)-i(a)/t(b)-t(a)
Sorry guys, would not normally ask for help but I am stuck here and we have broken up for Xmas so I cannot ask anyone at the college I go to. Anyway if someone could have a quick look over this and point me in the right direction I would appreciate it.
* I worked out the time constant to be L/R = 20ms
* I worked out the maximum circuit current to be E/R = 1A
* I created an exponential growth curve showing the inductor current as a function of time using the instantaneous current equation above and taking points at every ms to 15ms then every 5 to 45ms (to show at least 2 time constants on the curve)
* Using the curve I plotted a tangent line across the point at 10ms. I took two points and used the slope equation y2-y1/x2-x1 to calculate the approximate slope at 10ms (30.8A/s)
* I took point A at 10ms and point B at 15ms. I took the co-ordinates for A & B and worked out the average rate of current change between the two points as di/dt = 26.8A/s. I then moved B closer to A and re-calculated. I did this for lesser and lesser values of B and created a table. As B approached A I could confidently predict through di/dt that that A would equal 30A/s at the point of 10ms.
My questions...
1) Can I assume that the simple operation of dy/dx above is enough in regards to differentiation to confirm the graphical approximation I made before it? Or am I looking for another method? (Relating to the 'confirm your results by differentiation' comment in the question)
2) Its asks for the rate of change of current at t=0. I am aware that there is no current through the inductor at t=0 due to the inductor opposing the current change (back emf etc) but there IS a current rate of change at t=0 and it can be calculated as: initial di/dt = E/L Amps. If I use this I get 50A/s as an initial current rate of change. How can this be shown graphically on the growth curve and is the above initial di/dt equation enough to satisfy the 'confirm by differentiation' statement in the question?
Thanks in advance.
Simon
* Using the curve I plotted a tangent line across the point at 10ms. I took two points and used the slope equation y2-y1/x2-x1 to calculate the approximate slope at 10ms (30.8mA/s)
* I took point A at 10ms and point B at 15ms. I took the co-ordinates for A & B and worked out the average rate of current change between the two points as di/dt = 26.8mAs. I then moved B closer to A and re-calculated. I did this for lesser and lesser values of B and created a table. As B approached A I could confidently predict through di/dt that that A would equal 30mA/s at the point of 10ms.
My questions...
Thanks in advance.
Simon
You are probably in the wrong forum here. I think Introductory Physics would be better. The only problems I see is with the units you are getting for the graphical approximation. For example you predict the dI/dt at 10ms to be 30mA/s. I get approximately 30A/s. Can you check how you are getting units like mA/s? I'll bet you've got the time axis labelled in seconds instead of milliseconds.
Thank you for your responses, maybe a mod could move the question elsewhere if this is not the correct place?
As for answering the question in your reply...
I am an idiot its official! Schoolboy error!
The graph is labelled in ms, but I was taking the reading on the calculator to be mA/s not A/s. No idea why, probably due to the fact that I have been trying to work this out for 4 days now.
That now explains how there is an initial di/dt of 50A but again how to show this graphically? Or is it a case of creating the old right angled triangle and di/dt from the two points again?
Right. The same way as you did before. Pick a point close to the initial point and find the slope of the secant line connecting the two points.
Excellent, thank you ever so much. I know I was on the right lines, just needed pointing in the right direction.
Just to clarify, is the differentiation I have included enough to cover that part of the question would you think?
I think so. Graphing gives you approximate numbers for the rate of change. Differentiation gives you exact ones. You calculated di/dt at 10ms and got about 30A/s, right?
Yes, calculated di/dt from 10.25ms in increments to 10.001ms and was presented with 30A/s every time so took that to prove that 10ms would equal 30A/s too.
  • · Replies 49 ·
