Rate of heat loss ramining constant
The discussion centers on whether the rate of heat loss remains constant during a lab experiment comparing heat loss in an aluminum soda can with and without insulation. It is clarified that the rate of heat loss is not constant, as it is proportional to the temperature difference between the object and its surroundings, according to Newton's law of cooling. The relationship between heat loss and temperature change is exponential rather than linear, meaning that as the temperature difference decreases, the rate of heat loss also decreases. The participants emphasize the importance of analyzing experimental data to determine how heat loss varies over time. Ultimately, it is concluded that the rate of heat loss should not be considered constant.
copitlory8
Does the rate of heat loss remain constant during any period. I'm doing a lab on heat loss where I'm comparing the loss of heat in a aluminum soda can with hot water to a aluminum can with hot water covered with insulation material.
I believe the only time it will stay constant, is if the change in temperature remains constant with time. Otherwise, it will not be constant.
what does that mean ?
could i say at The rate of heat loss cannot be constant because the relationship is not linear but rather exponential.
Well it depends on how your results say that the heat loss varies with time.
so does being proportional mean that the heat loss is constant. i really have no idea how I am going to explain this.
Well it shows that your rate of heat loss is directly proportional to the change in temperature function.
You cannot say from the equation what this function unless your experimental data can be analyzed to find it.
so can i just say that the rate of heat loss should not have been constant.
Yes.
  • · Replies 17 ·
  • · Replies 33 ·
