Rate of revolution for a dryer?
  • Thread starter Thread starter pcandrepair
    Rate Revolution
The discussion centers on calculating the rate of revolution for a home laundry dryer with a cylindrical tub. The correct approach involves using the equation derived from centripetal acceleration, specifically sin(62.5°) = v²/(gR), where g is the acceleration due to gravity (9.8 m/s²) and R is the radius of the tub (0.385 m). The correct velocity calculated is approximately 1.9424 m/s, leading to a final rate of revolution of 48.178 revolutions per minute (rev/min). The initial misunderstanding stemmed from the incorrect application of the cosine function instead of sine in the context of the angle.
  • Understanding of centripetal acceleration
  • Familiarity with trigonometric functions (sine and cosine)
  • Basic knowledge of physics concepts related to motion
  • Ability to perform calculations involving angular velocity
  • Study the derivation of centripetal acceleration formulas
  • Learn how to apply trigonometric functions in physics problems
  • Explore the relationship between linear velocity and angular velocity
  • Investigate common errors in physics problem-solving and how to avoid them
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of common misconceptions in rotational motion calculations.
pcandrepair
Rate of revolution for a dryer?!?
In a home laundry dryer, a cylindrical tub containing wet clothes is rotated steadily about a horizontal axis as shown in the figure below. So that the clothes will dry uniformly, they are made to tumble. The rate of rotation of the smooth-walled tub is chosen so that a small piece of cloth will lose contact with the tub when the cloth is at an angle of 62.5° above the horizontal. If the radius of the tub is 0.385 m, what rate of revolution is needed? (revs/min)
2. The attempt at a solution
First I found the velocity of the dryer tub:
Cos(62.5) = (v^2)/gR
Cos(62.5) = (v^2)/9.8(.385)
v = 1.32m/s
Then I used that velocity to find the rate of revolution:
(v/2(pi)(.385)) * 60sec = 32.74 Revolutions/min
I submitted this answer and it said it was wrong. I can't seem to see what I did wrong. Any help or suggestions would be appreciated. Thanks.
Where does the Cos(62.5) come from?
mgCos(62.5) = m(v^2)/R
mgCos(angle) is the horizontal component of mg
The masses would cancel and divide g by both sides to get:
Since mg acts downward, it has no horizontal component. Find the component of the weight in the radial direction--that's where the centripetal acceleration points.
That was the equation that our professor lead us up to in class to find velocity. Wouldn't the component of the weight in the radial direction just equal mgCos(62.5)?
I believe your professor made an error. 62.5 degrees is the angle between the radial and the horizontal, not between the radial and the weight.
so to find the velocity i would take the square root of g*R?
v = sqrt(9.8*.385)
v = 1.9424 m/s
then,
(v/(2pi*R)) * 60 = revs/min
(1.9424/(2pi*.385))*60 = 48.178 revs/min
No. Follow my advice in post #4.
sin(angle) = v^2 / gR ?
Yes.
Ok. The answer was correct. Thanks Doc Al!
Good! (Mark this problem "solved".)
There is no option in my "thread tools" to mark problems as solved. That's where the option should be right...?
Yes, that's where it should be. You are not the first to state that can't find that option. (Question: Was this thread moved from another forum into this one? That might explain it.)
