What is the RATE of Rotation help
  • Thread starter Thread starter 8parks11
    Rate Rotation
The discussion revolves around calculating the rate of rotation of a tumble dryer basket with a diameter of 0.65m. The clothes tumble out at an angle of 60 degrees from the vertical, prompting participants to explore the relationship between velocity, radius, and angular motion.
  • Mixed
  • Participants discuss various equations related to centripetal force and angular motion, including the use of tangents and cosine functions. There are attempts to derive the velocity and convert it to revolutions per minute, with some questioning the assumptions made about the relationships between the variables.
Multiple interpretations of the problem are being explored, with participants providing different equations and methods to arrive at the rate of rotation. Some guidance has been offered regarding the correct use of radius and conversion factors, but confusion remains about the calculations leading to different results.
Participants note the challenge of working with the diameter and the implications it has on the calculations. There is also mention of missing information or assumptions that may affect the understanding of the problem.
8parks11
What is the RATE of Rotation! help!
An automatic tumble dryer has a 0.65m diamter basket that rotates about a horizontal axis. As the basket turns, the clothes fall away from the basket's edge and tubmle over. IF the colthes fall away from the basket at a point 60 degrees from the vertical, what is the rate of rotation in units of revolutions per minute.
i thought this problem would be extremely simple.
I was wrong :)
First i get
V^2 / rg = tan theta
so i get
Vc^2 = rg tan theta
soif ifind Vc i get 1.785
Now this wouldn't make snese...
does someone else have a different Apporpach
ok i can't get mass from anything. what do i do?
it has tobe something like 0.65 / x = tan theta or something?
F=mv^2/r
At sixty degrees the vertical part of this centripetal force is provided solely by the weight of the clothes ie mg.
thus mv^2/r*cos60 = mg, am I wrong?
v= sqrt(r*g/cos60) = 2.53m/s? Then remember you have to make it revs/min
cannot see why you are using tan
the answer is 37revs/minute
i did get 2.53m/s and then multiplied it by 60/2pi
wrong wrong :(
Yeah I get 74 revs/minute =/
I did 2.53/r to get it in rads/sec and then /2pi * 60 = 74...
2 times 37, strange
maybe because the problem gave it in diameters and u used that.
i'm still trying to get it
wait i still don'tget how uget 2.53m/s to 74rev/min
2.53 / (2pi x 60) doesn't work nor (2.53/2pi) x 60
no i used radius and I told you 2.53/r to get radians per seconds.
2.53/2pi*60 doesn't mean anything. What you want is
2.53/r/2pi*60 to get 74
ok so any idea why it is 74 instead of 37?
Unfortunately no clue =(
can you give me the exact equation that gives 74.
ive tried so many.. it's so weird.
so 2.53m/s is in seconds so i multiply it by 60 to make it in minutes.
so it turns 2.53x60 m/minutes
now since its in meters i have to divide it by 2pi to make it by revolutions
this gives me 24... Not 74... :(
am i looking for r? what did i do wrong?
What is 2.53 it is velocity, IE m/s
why would 2.53/2pi give you revs/s? It does not. However 2.53/r gives you rads/s which divided by 2pi gives you revs/s
The exact equation as stated before is!
(2.53 x 60) / (2 * pi * .65) = 37.1688006
I think you're forgetting r.
But r is .65/2 is it not?
"0.65m diamter", you are correct.
16K
