Ratio control for multiple streams
The discussion revolves around controlling the flow rates of three streams entering a vessel, where two streams depend on the flow rate of the third stream in a specific ratio. Participants explore how to configure control loops and represent them in a P&ID (Piping and Instrumentation Diagram).
  • Some participants inquire about how to represent the control loop for three related streams in a P&ID.
  • There are suggestions that the flow rate of the third stream can be described as a function of either of the other two streams, with a preference for using the second stream due to its fixed ratio.
  • Participants discuss the necessity of having two control loops: one for streams 1 and 2, and another for streams 2 and 3.
  • Questions arise regarding the feasibility of connecting one flow transmitter to two flow controllers, with considerations about the configuration of control valves and ratio stations.
  • Concerns are raised about potential issues if one stream is left as an "open loop," such as it getting plugged or running dry.
  • There is a suggestion to use a flow transmitter (FT) on the primary stream as a set point for the dependent streams, along with flow controllers (FC) and feedback mechanisms.
  • Participants discuss whether one or two flow transmitters are needed on the primary stream, with a cautionary note about potential conflicts between multiple transmitters.
Participants express varying opinions on the configuration of control loops and the number of flow transmitters required. There is no consensus on a single approach, as multiple configurations and considerations are discussed.
Limitations include the need for clarity on the specific ratios and dependencies between the streams, as well as the potential for operational issues in open loop configurations.
Engineers and technicians involved in process control, particularly those working with fluid dynamics and control systems in industrial applications.
princessme
I have 3 streams entering my vessel and 2 of the streams are dependent on the 3rd stream's flow rate in a certain ratio. Is there a way to control the flow rate of the 2 dependent streams using the flow rate of the 3rd stream and show it in my P&ID?
Yes. "... and show it in my PID?" Not clear what you're asking here.
What I meant was how should the configuration of the control loop be in my P&ID? I'm aware of how to show the control loop for 2 streams, but I'm having issues for 3 related streams to be controlled. Any references that I could refer to for this?
You've a couple possibilities: the third stream flow rate can be described as a function of the flow rate of either of the other two; pick one.
For instance, both the first and third stream are dependent on the flow rate of the first, both in different ratios. Does it mean that I need to have 2 control loops - one for streams 1 and 2, and another for streams 2 and 3?
princessme said:
2 control loops
Yup. Third stream as fnn of first, or of second; of second is easier since it's a fixed ratio.
Noted. Thanks for the help.
Can one flow transmitter be connected to two flow controllers?
What I'm thinking is that i have a flow transmitter on second stream, then one flow controller each on first and third stream connected to the FT on second stream. Does it work that way? Or do I need to have separate flow transmitters for each loop?
... and, when the third stream "runs away," how do you sense that upset condition?
My plan was to put a control valve on stream 1 and 3, which are connected to a ratio station each. Each ratio station is connected to the FT on stream 2. Does that make sense?
Makes sense if you can be certain that which ever stream you leave as an "open loop" doesn't get plugged up, run dry, or otherwise fail.
So I should consider doing 2 closed control loops instead?
In that case, for each control loop, I will have a FT, followed by FC, which is connected to the ratio station and a control valve on the stream. Then another FT after the control valve to send the signal back to FC? Does it sound right?
FT on primary stream (set point) to "ratio" for two dependent streams, and FC plus FT sensing output for each dependent stream is the way I'd do it.
Alright, thanks for the suggestion.
Will I need two FT on my primary stream or would 1 be sufficient?
princessme said:
1 be sufficient?
One does the trick --- two can have a nasty tendency to start calling each other liars.
  • · Replies 30 ·
  • · Replies 18 ·
