Ratio Test for Sum $\tiny{206.10.5.84}$
In summary, we discussed the convergence of a series, particularly using the ratio test. We found that the given series converges absolutely for $|4x|<1$. We also used integration to find the sum of the series, which is $-\frac{1}{5}\log(1-4x)$ for $|x|<\frac{1}{4}$. The help given in this section was greatly appreciated.
karush
MHB
3,269
\begin{align*}
\displaystyle
S_{84}&=\sum_{k=1}^{\infty}
\frac{(4x)^k}{5k}\\
\end{align*}
$\textsf{ ratio test}$
$$\frac{a_{n+1}}{a_n}
=\frac{ \frac{(4x)^{k+1}}{5(k+1)}}{ \frac{(4x)^k}{5k}}
=\frac{4xk}{k+1} $$
$\textsf{W|A says this converges at $4|x|<1 $ so how??}$
The ratio test says a sum converges absolutely if
$$\lim_{n\to\infty}\left|\frac{a_{n+1}}{a_n}\right|<1$$
We have
$$\lim_{k\to\infty}\left|\frac{4xk}{k+1}\right|=4|x|$$
so the series converges absolutely if $4|x|<1$.
$$\sum_{k=1}^\infty\frac{(4x)^k}{5k}=\frac{4x}{5}+\frac{16x^2}{10}+\frac{64x^3}{15}+\frac{256x^4}{20}+\frac{1024x^5}{25}+\cdots$$
$$\frac{\text d}{\text{d}x}\left(\sum_{k=1}^\infty\frac{(4x)^k}{5k}\right)=\frac45+\frac{16x}{5}+\frac{64x^2}{5}+\frac{256x^3}{5}+\frac{1024x^4}{5}+\cdots$$
$$S=\int\frac45\left(\sum_{k=1}^\infty(4x)^{k-1}\right)\,\text{d}x,\quad\text{ which converges for }|x|<\frac14$$
$$S=\frac45\int\frac{1}{1-4x}\,\text{d}x=\frac45\cdot-\frac14\log(1-4x)+C=-\frac15\log(1-4x),\quad|x|<\frac14;\,C=0$$
this has been a difficult section so the help here has been very appreciated..
1. What is the Ratio Test for Sum 206.10.5.84?
The Ratio Test for Sum 206.10.5.84 is a method used in mathematics to determine the convergence or divergence of an infinite series. It involves comparing the ratio of the terms in the series to a specific value, known as the limit ratio.
2. How is the Ratio Test for Sum 206.10.5.84 used?
The Ratio Test for Sum 206.10.5.84 is used by taking the limit of the absolute value of the ratio of successive terms in a series. If the limit is less than 1, the series is said to converge. If the limit is greater than 1, the series is said to diverge. If the limit is equal to 1, the test is inconclusive and another method must be used to determine convergence or divergence.
3. What is the formula for the Ratio Test for Sum 206.10.5.84?
The formula for the Ratio Test for Sum 206.10.5.84 is:
limn→∞ |an+1/an| = L
where an represents the terms in the series and L is the limit ratio.
4. What is the significance of the limit ratio in the Ratio Test for Sum 206.10.5.84?
The limit ratio in the Ratio Test for Sum 206.10.5.84 is crucial in determining the convergence or divergence of a series. If the limit ratio is less than 1, the series is convergent, meaning that the terms in the series approach a finite value as the number of terms increases. If the limit ratio is greater than 1, the series is divergent, meaning that the terms in the series do not approach a finite value and the series does not have a sum.
5. What are the limitations of the Ratio Test for Sum 206.10.5.84?
While the Ratio Test for Sum 206.10.5.84 is a useful method for determining the convergence or divergence of a series, it has its limitations. It can only be used on series with positive terms and does not work on alternating series. Additionally, there are some cases where the test is inconclusive and another method must be used to determine convergence or divergence.
  • Calculus
  • Calculus
  • Calculus
  • Calculus
