RC Circuits, time to charge a capacitor
13 replies · 23K views · last reply
iiiiaann
Switch S in the figure below is closed at time t = 0, to begin charging an initially uncharged capacitor of capacitance C = 13.0 µF through a resistor of resistance R = 24.0 . At what time is the electric potential across the capacitor equal to that across the resistor?
i = dq/dt
q = CE(1-e^-t/RC)
I really don't even know where to start with this one
I assume that E is the EMF of the battery.
Is q the charge on the capacitor at time, t ?
How much charge would be on this capacitor of the potential difference across it was E ?
the charge on the capacitor would be
Q = CV = (13e-6)(E)
if the potential difference were E
iiiiaann said:
... At what time is the electric potential across the capacitor equal to that across the resistor? ...
At the above time, how do these two potentials compare with E , the electric potential provided by the battery?
I'm not sure i follow what you are saying? Would the combination of the 2 be equal to E?
Yes, according to Kirchhoff.
Since the two are equal, what is the electric potential across the capacitor ?
If the electric potential on the capacitor is E/2, then how much charge is on the capacitor?
So, solve this equation for t when q = C(E/2)
q = CE(1-e^-t/RC)
C(E/2) = CE(1-e^-t/RC)
1/2 = 1 - e^-t/RC
e^-t/RC = 1/2
-t/RC = ln(1/2)
-t = ln(1/2) * RC
t = -1 * ln(1/2) * RC
t = -1 * -.6931 * 24 * 13e-6 = 0.000216 s = 0.216 ms
Thanks again for the help, these forums (you especially) are fantastic
Hello, may I ask what kind of equation q = CE(1-e^-t/RC) is? Does the problem give it as the equation which determines the time to charge of the capacitor through this RC circuit? How do they get to such an equation?
If you check your capacitor equations you will find a more convenient expression for the voltage across a capacitor during charging.
V = Vmax(1 - e^-t/RC) so you can calculate the voltage across the capacitor t sec after switch on.
The charge equation is the same exponential form
Q = Qmax(1-e^-t/RC)
hope this helps
