React - load new image - error - part 2
  • Thread starter Thread starter mathmari
    Error Image Load
The discussion revolves around how to properly display an image alongside text in a React component, focusing on layout techniques and HTML semantics. Participants explore various methods for achieving the desired alignment and presentation of the image and text, considering both HTML structure and CSS styling.
  • Some participants suggest using a simple
    structure to place an image next to text, while others propose alternatives like using
    or for inline text.
  • There is a discussion about the use of block-level tags like
    , and
    , which start on a new line and take up full width, affecting the layout.
  • One participant mentions that CSS can be used to control the layout and suggests using inline-block styles for better alignment.
  • Another participant proposes using a table for layout, which is met with resistance from others who argue against using tables for non-tabular data.
  • Some participants emphasize the importance of using CSS frameworks like Bootstrap for responsive design and layout management.
  • There are suggestions for using flexbox properties to align items vertically and horizontally, with examples provided for Bootstrap classes.
  • One participant mentions the need for vertical alignment of text relative to the image, suggesting various HTML and CSS approaches to achieve this.
Participants express differing opinions on the appropriateness of using tables for layout purposes, with some firmly against it. There is no consensus on the best method to achieve the desired layout, as multiple approaches are discussed and debated.
Participants reference the need for CSS knowledge and the potential use of frameworks like Bootstrap, indicating that the discussion may depend on specific styling preferences and project requirements.
mathmari
MHB
pbuk said:
However you can also do this, described at https://create-react-app.dev/docs/adding-images-fonts-and-files, which has advantages (notably if logo.png is small enough it will be inlined instead of referenced which makes your site load faster).
Code:
# Set up your files like this
assets/img/logo.png
src/ui-component/Logo.js
Now write your component as:
JavaScript:
// Not sure if you need this but it is in the boilerplate in the docs.
import React from 'react';
// We need a relative reference from the location of this file.
import logo from '../assets/img/logo.png';
function Header() {
  return <img src={logo} alt="Logo" />;
export default Header;
It works with this code! If I want to write a text next to the image do I use <div> ?
I mean :
Code:
    return <div><div><img src={logo} alt="Logo" width="40" /></div><div>Title</div></div>;
Technology news on Phys.org
Code:
That should work yes.
The inner <div> around the <img> seems a bit redundant though, and as an alternative for the title you might also use <p>Title</p>. 🤔
Laying out text and images depends on what CSS framework you are using (Bootstrap?) so you would be best to check out the documentation for that. If you do want to ask here you could start a new thread but I really think you would be better off learning some more of the basics first. You could try starting with the links in this blog post https://blog.logrocket.com/using-bootstrap-with-react-tutorial-with-examples/
It doesn't work, the text appears under the image.
I changed it now to :
Code:
const Logo = () => {
    return (
        <div>
            <img src={logo} alt="abc" width="30" />
            <h3>Titel</h3>
        </div>
export default Logo;
but again the titel is under the image. What am I doing wrong? 🤔
but again the title is under the image. What am I doing wrong?
Where do you want the title? I assumed you wanted it below the image.
The tags <div>, <p>, and <h3> are all block-style tags, which means they always start on a new line and can take up all of the horizontal space.
If you want the title to be to the right, you can use <span> or no tag at all.
The behavior of any of those tags can also be overruled with CSS. You can then use for instance the style inline-block. 🤔
I wrote now:
Code:
    return (
        <div lass="box">
            <img src={logo} alt="logo" width="35" vertical-align="middle" />
            <span>TItel</span>
        </div>
The titel is now next to the image, but is it possible that the Titel is next to the center of the image and not at the bottom? 🤔
mathmari said:
I wrote now:
Code:
    return (
        <div lass="box">
            <span>TItel</span>
        </div>
Then the title must be in a container with the same height as the image, and it must be vertically aligned to the middle.
We can achieve that with for instance <table><tr><td><img src={logo}></td><td>Title</td></tr></table>. 🤔
No, please not a table. Tables are used for tabulating things, not laying them out.
Writing HTML like this for React would be like writing cuneiform on a word processor.
It works in that way! :smile:
So is it wrong to use tables there? 🤔
Yes it is wrong.
HTML 5 specification (current) said:
Tables must not be used as layout aids. Historically, some Web authors have misused tables in HTML as a way to control their page layout. This usage is non-conforming, because tools attempting to extract tabular data from such documents would obtain very confusing results. In particular, users of accessibility tools like screen readers are likely to find it very difficult to navigate pages with tables used for layout.
HTML 4.01 specification (1999) said:
Tables should not be used purely as a means to layout document content as this may present problems when rendering to non-visual media. Additionally, when used with graphics, these tables may force users to scroll horizontally to view a table designed on a system with a larger display. To minimize these problems, authors should use style sheets to control layout rather than tables.
pbuk said:
Yes it is wrong.
So what do you suggest using instead? 🤔
You could try something like this:
Note that the "guts" of this is the HTML shown below. You will need to include the CSS for Bootstrap 5 using instructions like the ones I linked to earlier: https://blog.logrocket.com/using-bo...ples/#add-bootstrap-react-using-bootstrap-cdn.
HTML:
<div class="d-flex my-4">
  <div class="flex-shrink-0">
    <img src="https://via.placeholder.com/100" alt="An example image">
  </div>
  <div class="flex-grow-1 ms-3">
    <h2 class="h5">Top aligned by default</h2>
    Smaller images can keep the description on the same row even on mobile.
  </div>
</div>
<div class="d-sm-flex my-4 text-center text-sm-start align-items-center">
    <img src="https://via.placeholder.com/320x180" alt="An example image">
  </div>
  <div class="flex-grow-1 ms-sm-3 mt-3 mt-sm-0">
    <h2 class="h5 d-none d-sm-block">Centered using
      <code>align-items-center</code></h2>
    Wider images should have a responsive layout so they move the description
    underneath on mobile.
  </div>
</div>
As an alternative, we can do:
HTML:
<div><img src={logo} style="vertical-align: middle;">Title</div>
The key is that the image itself must have a vertical alignment style. The text follows suit.
HTML:
  </div>
  </div>
</div>
  </div>
  </div>
</div>
Using this code the title appears under the image. But why? 🤔
HTML:
Using this code the broswer shows me just a white page. But why? 🤔
No idea. Clearly you have done something basic wrong, at a guess you have not closed a tag properly. Is there a message shown in the browser console?
I'm beginning to think that you are "in over your head" with this, you need to go back to the basics and do a course learning HTML and CSS before you start doing anything in React. What are you trying to achieve anyway: do you even need React?
Right-click and Inspect? 🤔
I believe the "point" of React is that it is easy to quickly create a website.
Of course React also has more advanced concepts, but it is not required to use them.
As for the CSS, it is not trivial to get a title vertically aligned to the right of an image, simple as that may seem at first.
HTML:
When I delete the part style="vertical-align: middle;" it works properly. 🤔
Perhaps a closing quote or an angled bracket was missing?
We can check if we inspect the generated html. 🤔
HTML:
The style must be in {{.}}, i.e.
style={{ verticalAlign: 'middle' }}
Now it works! :smile:
The point of React is that it is easy to quickly create a web application, or at least a website with dynamic content.
But before we can create a website with dynamic content we need to know how to create a website with static content.
And if we don't need dynamic content (there is nothing dynamic in what we have seen so far) then we don't need a front end framework.
Indeed. This is why I recommend a CSS framework.
Is there a way to make a word more bolder than " fontWeight: 'bold' " does? 🤔
pbuk said:
Your browser needs to have access to a font with an appropriate weight. This is often handled by the UI framework.
I haven't really understood what you mean. Could you explain that further to me? 🤔
Sorry, I hit post before I had added a link, look again.
  • · Replies 23 ·
  • · Replies 23 ·
13K
