How Does Integration by Parts Prove This Real Analysis Identity?
The discussion focuses on proving the identity \(\int_a^b xf(x)f'(x)dx = -\frac{1}{2} \int_a^b [f(x)]^2 dx\) using integration by parts. The function \(f\) is continuous and satisfies boundary conditions \(f(a) = f(b) = 0\). Participants suggest starting with integration by parts, noting that the presence of \(f'\) in one integral and its absence in the other is crucial. The integration by parts leads to evaluating the boundary term, which simplifies to zero due to the boundary conditions. Ultimately, this confirms the identity as required.
steelphantom
Let f be of class C1 on [a, b], with f(a) = f(b) = 0. Show that \int_a^b xf(x)f'(x)dx = -1/2 \int_a^b [f(x)]^2 dx.
If F is an antiderivative of f, then \int_a^b f(t)dt = F(b) - F(a)
I'm just really not sure how to begin this one. I know that because f is of class C1 that f' is continuous. Maybe change of variables?
Use integration by parts!
Less dogmatically... one of the major differences between the two things you're trying to show equal is that one has a derivative in it, and the other doesn't. And what methods do you know that can increase/decrease how derivated a part of your integrand is?
u=x, du=dx, v=\int f(x)f'(x)dx
v=\int f(x)f'(x)dx, t=f(x), dt=f'(x)dx=>\int tdt=\frac{1}{2}t^2=\frac{1}{2}[f(x)]^2
\frac{1}{2}x[f(x)]|_a^b-\frac{1}{2}\int_a^b [f(x)]^2dx=-\frac{1}{2}\int_a^b [f(x)]^2dx
Because:\frac{1}{2}x[f(x)]|_a^b=0
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 21 ·
