Real Analysis: Proving the Greatest Lower Bound Property
The discussion revolves around proving the relationships between the greatest lower bound and least upper bound of sets A and B in real analysis. It establishes that if A and B are bounded above, then the greatest lower bound of -A equals the negative of the least upper bound of A, and the least upper bound of A+B equals the sum of the least upper bounds of A and B. Participants are working through the proof of part (a) and express challenges in demonstrating that the least upper bound of A+B is indeed the sum of the least upper bounds of A and B. Additionally, there is a focus on using the Least Upper Bound Property to prove the Greatest Lower Bound Property for nonempty subsets of R that are bounded below. The conversation emphasizes the necessity of transforming infimum into supremum to complete the proof.
major_maths
(a) Suppose that A and B are nonempty subsets of R. Define subsets -A={-x: x\inA} and A+B={x+y: x\inA and y\inB}. Show that if A and B are bounded above, then the greatest lower bound of -A = - least upper bound of A and the least upper bound of (A+B) = the least upper bound of A plus the least upper bound of B.
(b) Use part (a) to prove the Greatest Lower Bound Property: Any nonempty shubset of R that is bounded below has a greatest lower bound.
If 0<a and 0<b, then there is a positive integer n such that b<a+a+...+a (n summands).
If A is any nonempty subset of R that is bounded above, then there is a least upper bound for A.
I've proven that first part of (a), that the greatest lower bound of -A = -least upper bound of A, but I can't figure out why the least upper bound of (A+B) would = the least upper bound of A plus the least upper bound of B. [or sup(A+B) = sup(A)+sup(B)]
Hi major_maths! :smile:
So you need to prove that
\sup(A+B)=\sup A+\sup B
Can you first prove that \sup A+\sup B is an upper bound of A+B??
That is, take an arbitrary element z in A+B, can you prove that z\leq \sup A+\sup B??
Thanks! I got through part (a) by proving (A+B) must be nonempty and then proving that there was an upper bound in (A+B) since both A and B had upper bounds, using the Least Upper Bound Property to prove that there must be a least upper bound since there was an upper bound to begin with.
I'm stuck again on part (b) though. I know that since inf(-A) exists, -sup(A) must exist as well. I don't know how to go about proving the Greatest Lower Bound Property from there though. I was thinking about using the Least Upper Bound Property somehow.
Yes, you proved that A+B has a least upper bound. But did you prove that sup(A)+sup(B) is that exact upper bound??
You do need to prove the least upper bound property! Just transform the inf into a sup and use the least upper bound property.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
