Reasoning for circular/elliptical orbits
  • Context: Undergrad
  • Thread starter Thread starter Chenkel
    Orbits
58 replies · 5K views
Chenkel
TL;DR
I'm wondering how objects achieve circular/elliptical orbit.
Hello everyone! So I have a fairly basic question about orbits, if I launch an object vertically from the surface of the earth, for most velocities it will come back to earth, if I launch at an angle it will have a velocity tangential to the vertical velocity, and this vertical velocity will change due to the acceleration of gravity, but I don't see why this tangential velocity is changing direction to achieve a circular or elliptical motion, obviously I'm missing something and I'm trying to fill that gap in my knowledge, if anyone can provide that insight I will be grateful, thank you!
This is not specific to gravity. Any time that you have any force which is not parallel to the velocity then that force will cause the tangential velocity to change direction. That is simply how forces behave. If you wish, I can step through the mathematical derivation, but I don’t know a non mathematical way.
...and if the object doesn't have escape velocity, it has to come back. If it has enough tangential velocity to miss...orbit!
I suppose I can see how the velocity will change direction when taking into account your analysis, and also taking into account Newton's first and second laws, so a derivation of the changing velocity vector is probably not necessary (but I do appreciate your willingness to guide me in this regard.) I feel I do not have a full understanding of how orbits are achieved. I might lack a little intuition, and mathematical knowledge, but hoping I can improve on these aspects.
I suppose with a little imagination and intuition that makes some sense, but for me the overall picture isn't completely coming in. What makes something achieve a mostly elliptical orbit, like Halley's comet for example?
One thing I'm curious about is the following.. The tangential velocity vector is corrected by a small change in velocity each second due to the gravitation of earth, let's call it dV/dt. I imagine for a circular orbit, dV/dt would trace out a circle, would it also trace out a circle for a very elliptical orbit?
If the projectile is stays near the surface of the Earth which is approximated as flat, it will return to the same height from which it was launched. Give it more initial speed and it will land below the horizon. Give it even more speed and the Earth will curve away from it and the projectile will go into orbit (see picture).
What you're missing is that the tangential velocity IS changing. Let's set up an example:
Let's place a stationary point-mass (a mass with zero size) at the origin of a graph. Let's also place a point-particle with substantially smaller mass at (0,1), one unit above the mass, and let us also say that this particle is moving in the +X direction at 1 unit per second.
Our particle is attracted towards the mass via a force. This force itself is a vector that points from the particle towards the mass. Initially this force cannot act on the particle's X-velocity since it is acting solely in the Y-direction. But, if we advance by a second (ignoring the Y-acceleration that would happen in that second under the applied force) we find that the particle is at (1,1) on the graph and now the force vector CAN act on the X-velocity since the force vector now acts equally in the X and Y-directions.
But wait, we just skipped a whole second when advancing time. Perhaps things are different in a continuous world. As a test, let's see what happens when we only advance a half-second. Well, the particle is at (1/2,1) on the graph, the force vector still has an X-component, and the particle's x-velocity will be changed, just by a smaller amount than when we advanced straight to 1 second.
If we continue to make our time steps smaller, we find that ANY deviation in the X-direction away from zero will result in the force vector having an X-component, and thus affecting the particle's X-velocity, which was the original tangential velocity. So when you throw a ball on Earth, it IS being pulled back towards you by the Earth's gravity. Just not by very much in that short time and distance.
But, what about the Y-velocity? Well, it turns out that something similar happens to it as well, it just starts at zero and increases instead of starting at one and decreasing. In a perfectly circular orbit both the X and Y velocity vectors 'trade' magnitudes in such a way as to ensure that the overall velocity vector has the same magnitude at all times.
If you want to set a mass in an elliptical or circular orbit, you must give to it the proper initial velocity both in magnitude and direction, and also the mass must be at the proper starting point. For example to set a mass ##m## in circular orbit of radius ##R## around the earth, one way is to put the mass at height R, and give it a tangential (perpendicular to the radius) velocity with magnitude ##v## such that $$m\frac{v^2}{R+R_e}=G\frac{M_em}{(R+R_e)^2}$$
To set it in an elliptical orbit I think the initial velocity is different in magnitude and in direction, I think it is not exactly perpendicular to the radius vector.
That’s not really how it works though. Any bound orbit (ie, excluding escaping solutions) starting at the Earth’s surface will return to the Earth’s surface simply by virtue of the orbit being an ellipse. In order to achieve an actual orbit above the Earth, additional changes of velocity that are not due to gravity (eg, by rocket boosters) is necessary.
@Orodruin if you put a mass m at random height above the surface of the Earth and give it a random velocity both in magnitude and direction, then the orbit , assuming no other bodies except the mass and earth, will be elliptical with the center of Earth at one foci of the ellipse and the other foci depending on the initial height, and initial velocity. Right?
PS. Also assume Earth as point mass in order to avoid collision issues.
If the orbit is bound, yes. The collision issue is handled simply by checking the perigee of the orbit. If that is closer than the radius of the Earth there will be a collision.
Sorry I have not read any good textbook on astrophysics, what do you mean by the term "orbit is bound", you mean provided that it does not escape to infinity(initial velocity greater or equal to escape velocity)?
Yes.
  • Love
In a Walter Lewin lecture I'm watching he says the escape velocity is$$v_e = \sqrt{\frac {2MG} R }$$Where M is the mass of Earth and R is the radius of earth. This is derived by taking the mechanical energy at infinite distance, and seeing what your velocity needs to be to escape the gravitational pull at that infinity, the potential energy at infinity is 0, so the additional speed the object needs to go is 0, that means the mechanical energy is more than or equal to 0 for any mass in the force field that has escape velocity, but I'm wondering if direction of velocity matters, my guess is that it doesn't and I would like to understand why, if the object is placed at infinity and the velocity is aiming toward decreasing potential energy then will the object escape the gravitational pull as it goes to the other side? Provided it doesn't hit the Earth on it's inward trajectory? My intuition is that the additional velocity as it moves to the other end of the orbit is more than enough velocity to escape the pull of earth, but it's a little hard for me to see this concretely for velocities not aiming in direction of increasing potential energy.
Also he says that the orbital velocity is$$v_o = \sqrt{\frac {MG} R }$$Does this mean that for any orbiting object it only has to go faster by a multiple of ##\sqrt 2## to escape the pull of earth?
If any of you can provide some insight that would be awesome, thank you.
It indeed does not. As long as the object has positive total energy (or zero total energy in the limit) it will escape to infinity unless it hits the Earth in between - but that is then due to the perigee of the trajectory being below the Earth surface.
Chenkel said:
Also he says that the orbital velocity isvo=MGRDoes this mean that for any orbiting object it only has to go faster by a multiple of 2 to escape the pull of earth?
This is the orbital velocity of a circular orbit. The velocity in an elliptic orbit changes throughout the orbit. But yes, if you would double the kinetic energy of an object in circular orbit, then it would reach escape velocity.
Orodruin said:
It indeed does not. As long as the object has positive total energy (or zero total energy in the limit) it will escape to infinity unless it hits the Earth in between - but that is then due to the perigee of the trajectory being below the Earth surface.This is the orbital velocity of a circular orbit. The velocity in an elliptic orbit changes throughout the orbit. But yes, if you would double the kinetic energy of an object in circular orbit, then it would reach escape velocity.
One thing which I have difficulty reconciling is that there is ever a point where the object 'escapes' the gravitational pull of earth, for example for any finite distance from Earth there will be a force pulling on the object, the escape velocity equation looks at the mechanical energy at infinity and any real object will never reach infinity, so maybe the question I'm asking is "why does energy more than zero imply that the object will have a non elliptical orbit?"
@Orodruin if we give escape velocity to a mass, then its orbit will still be elliptical but with one foci at infinity?
So the object 'escapes,' but it is still influenced no matter how far it gets away. So really the escape velocity equation says what minimum velocity is needed to created an unbounded orbit, it's hard for me to see how this follows from it's derivation of 'mechanical energy for zero velocity at infinity.'
That picture looks wrong. It starts nearly tangent to the Earth's surface and ends nearly tangent to a larger radius. You can't get that behavior with an conservative inverse square central force.
It looks like a parabola with a vertical axis where an ellipse with a diagonal axis would have been correct. Cobbling up a better shape with mspaint, shifting to a horizontal axis and eyeballing to figure out where the foci live, I get a sub-orbital trajectory:
Note that since an orbit under an inverse square central force is a closed figure, it follows that an object projected from the Earth's surface at less than escape velocity will have an orbit that intersects with the surface of the Earth.
Edit: There are conservative central force laws that could produce the tangent behavior that was identified. For instance, one with a potential well at one radius surrounded by potential hills above and below.
Well by the way we apply conservation of mechanical energy for the escape velocity problem, we don't have any info on what is the exact trajectory that the object will follow on its way to infinity. I find it hard also to prove that given any "random" direction to initial escape velocity the object will reach infinity. My intuition also tells me that the initial direction matters as to whether the object escapes to infinity or not. All I can tell is that IF the object reaches infinity then its kinetic energy will be exactly zero.
If you stipulate that the force law is central then that gives you conservation of angular momentum about the center. That is a tool that you can bring to bear on the proof.
If you stipulate that the force law is monotone decreasing with increasing radius, that let's you rule out potential barriers that are too high to cross. That gives you another tool.
You should be able to leverage these to demonstrate that an object whose trajectory has escape energy and ever has a strictly positive radial velocity will retain a strictly positive radial velocity forever after.
Edit: I think that one actually needs to tweak the "monotone decreasing" bit above so that the potential energy associated with the central force is monotone increasing even after accounting for the kinetic energy associated with the tangential velocity that is assured by conservation of angular momentum. An inverse square law qualifies. Other central force laws will qualify as well.
As long as the force law does not result in an in-spiral to the center, you should be able to argue that an object that has a inward or zero initial radial velocity will eventually turn around and go outward. [This is the assertion about which I feel least comfortable].
Delta2 said:
ehm @jbriggs444 you say another condition except escape velocity, that is the strictly positive radial velocity, @Orodruin what is your take on this?
Be very careful in how you read that posting. I am talking about how one would attack a mathematical proof without directly invoking an inverse square law.
For a more general central force law, there is the possibility of an inward spiral. Let me see if I can Google something up. First hit is a homework exercise:
For an inverse square force law, a non-degenerate orbit is guaranteed to have a periapsis at a finite radius and will move outward afterward. So the launch angle is irrelevant as long as the trajectory does not intersect with the gravitating body.
For the two-body problem (with no collision), the vis-viva equation gives a relationship between just the current speed and radial distance and the orbit shape with 1/a zero being equivalent to a parabolic trajectory. As can be seen, there is no angle between speed and position in this.
Sorry can you make it more clear for me? I don't understand how the vis viva equation tell us that an object with escape velocity will reach infinity all that I can infer is that at infinity will have a certain speed which would be 0 if 1/a is zero.
Don't confuse me with what is happening with non central non inverse square force law, I am only interested in the case of central inverse square force law. You guys don't give me a clear answer ...
Clear answer: Launch angle is irrelevant.
and the clear why? Something about conservation of angular momentum and force being monotonically decreasing but I can't get the clear reasoning...
Launch angle is not totally irrelevant btw, what if I launch the object with escape velocity towards the center of the earth? e hehe
Without much math:
Case 1: Outward launch.
If you launch outward, the trajectory is increasingly more in a direct radial direction. Tangential velocity reduces based on conservation of angular momentum. Radial velocity reduces at a lower rate.
Case 2: Tangential launch.
If you launch tangentially, the trajectory bends outward based on centrifugal force. It's moving too fast to stay in circular orbit.
Case 3: Inward launch.
If you launch inward, the trajectory has a low point where angular momentum requires a tangential velocity that is big enough to include all of the object's available kinetic energy. So now you must be moving tangentially. You are back in case 2.
Case 4: Launch dead center at the point mass that is providing the central force.
You can't aim that accurately and you can't have a gravitating mass that small. We hope. Your predictions die in a singular confusion between quantum mechanics, general relativity and the mathematics of situations with measure zero.
Edit: Some thoughts about Newtonian Gravity and the continuum in this insights article by John Baez. That dead center shot is interesting to contemplate.
There is only one direction: directly away from the object. Even if you start at tangential to the surface(call that zero degrees), as the distance increases the angle increases toward 90 degrees. Try drawing a diagram of this.
