Scott Ryals
- 5
- 1
Is it feasible to recharge satellite's batteries utilizing a ground-based laser?
Recharging satellite batteries using a ground-based laser is not a feasible option due to significant power dissipation in the atmosphere and safety concerns for aircraft. Most satellites rely on solar panels, which provide over 1000 W/m² of radiation, making solar energy harvesting a more efficient method. The discussion highlights that laser beam generation is inefficient and faces challenges such as atmospheric attenuation, especially in adverse weather conditions. Alternatives like microwave beams for powering remote ground equipment are considered more practical.
PREREQUISITESAerospace engineers, satellite designers, energy researchers, and anyone interested in advanced power transmission technologies.
Usually a reverse situation is considered (i.e. recharging a difficult-to-access ground equipment via satellite beam). For example, sensing network over dormant volcano kept powered by microwave beam, allowing operations beyond lifespan of batteries with small maintenance (because power satellite can service entire world, in sequence).Scott Ryals said:Is it feasible to recharge satellite's batteries utilizing a ground-based laser?
trurle said:Usually a reverse situation is considered (i.e. recharging a difficult-to-access ground equipment via satellite beam). For example, sensing network over dormant volcano kept powered by microwave beam, allowing operations beyond lifespan of batteries with small maintenance (because power satellite can service entire world, in sequence).
The laser-powered satellite is considered usually only if very high power to weight (~20 kW/kg) is required - the only related talk i can remember was about laser-powered upper stages, to slash the cost of launch. Normal solar panels are good enough up to 5 W/kg satellites.
It would be interesting from engineering and exploration perspective to try and see how it will fail. My estimation of chances of "breakthrough starshot" reaching another star and communicating back to Earth is 0.00%.Scott Ryals said:What are your thoughts regarding the Breakthrough Starshot initiative?
