Redshift Mechanisms and Supernova Lightcurves
  • Context: Graduate
  • Thread starter Thread starter Thomas2
    Redshift Supernova
The discussion revolves around the mechanisms of redshift in relation to supernova lightcurves, exploring alternative explanations to the conventional understanding. Participants examine theoretical implications, mathematical models, and the validity of existing data in the context of cosmological redshift and its effects on lightcurves.
  • Some participants suggest that alternative redshift mechanisms could affect supernova lightcurves, proposing that a wavelength-independent redshift might lead to changes in observed lightcurves.
  • One participant references a theory that light may age and expand during its journey from distant galaxies, challenging the standard interpretation of redshift.
  • Another participant questions the validity of the Hubble law, citing potential discrepancies in redshift measurements across different spectral lines.
  • Concerns are raised regarding the implications of certain theories leading to singularities, with some arguing that the expansion interpretation does not necessitate a temporal beginning.
  • Participants request empirical support for claims made regarding redshift and lightcurves, including references to peer-reviewed papers and equations linking concepts.
  • There is a discussion about the Cosmic Microwave Background (CMB) and its relation to the proposed theories, with questions about how these theories account for observed phenomena.
Participants express a range of competing views regarding the mechanisms of redshift and its implications for supernova lightcurves. There is no consensus on the validity of the alternative explanations presented, and the discussion remains unresolved.
Some claims rely on specific interpretations of data and theoretical frameworks that may not be universally accepted. The discussion includes references to various models and theories, each with its own assumptions and limitations.
Readers interested in cosmology, theoretical physics, and the ongoing debates surrounding redshift mechanisms and their implications for observational astronomy may find this discussion relevant.
Thomas2
I came across Ned Wright's webpage
http://www.astro.ucla.edu/~wright/tiredlit.htm which states that
alternative explanations for the redshift of galaxies would not be
consistent with the z-dependence of supernova lightcurves. However,
this assertion is not further substantiated and as far as I can see
any wavelength independent redshift mechanism should indeed result in
the change of the supernova lightcurves:
Consider a sinusoidal lightwave modulated by a lightcurve L(t), i.e.
E(f,t)=E0*sin(f*t)*L(t) .
By expanding L(t) into a Fourier Integral i.e.
L(t)= Int[dF*cos(F*t)*a(F)]
and drawing the sine function under the integral one gets
E(f,t)=E0* Int[dF*sin(f*t)*cos(F*t)*a(F)].
Using the addition theorems for trigonometric functions, this is
equivalent to (apart from a constant factor)
E(f,t)=E0* Int[dF*(sin((f+F)*t) + sin((f-F)*t)*a(F)].
Applying now a redshift factor (1+z) changes the frequencies to
(f+F)/(1+z) and (f-F)/(1+z), i.e. the signal becomes
E(f,t,z)=E0* Int[dF*(sin((f+F)/(1+z)*t) + sin((f-F)/(1+z)*t) *a(F)],
and by reversing the addition theorem and taking the sine- function
out of the integral again
E(f,t,z)=E0* Int[dF*sin(f/(1+z)*t)*cos(F/(1+z)*t)*a(F)] =
= E0*sin(f/(1+z)*t)* Int[dF*cos(F/(1+z)*t)*a(F)] =
= E0*sin(f/(1+z)*t)*L(t/(1+z)).
This means that not only is the wave frequency redshifted but also the
light curve broadened.
For anyone intererested, I have myself suggested that the redshift of
galaxies is in fact caused by the small scale electric field due to
the intergalactic plasma (a kind of counter-part to the Faraday
-rotation in a magnetic field) (for more details see
http://www.plasmaphysics.org.uk/research/#A11).
Science news on Phys.org
very good read
Thomas2, from his webpage (my emphasis): In fact, the Hubble law appears to be based on rather limited data sets, and in particular has not been examined for its strict validity throughout the whole of the electromagnetic spectrum (in fact, it is known that the redshift factor for certain spectral lines from the same object differs by up to 10% even within the visible part of the spectrum itself).
Evidence?
same quote: In fact, the Hubble law appears to be based on rather limited data sets *SNIP
Since there are well over 100k reliable galactic redshifts (2dF alone has >200k), I can only assume Thomas2 is referring to independent distance determinations. The best data are from the http://arxiv.org/PS_cache/astro-ph/pdf/0012/0012376.pdf , which used Cepheids to determine distances to 23 galaxies. Other data are from the Tully-Fisher relation, the fundamental plane of elliptical galaxies, Type Ia supernovae, and gravitational lenses (all but the last are discussed in the Freedman et al paper, linked above).
While alternative explanations are always welcome, Thomas2's idea would leave a very great deal of 'unexplaining' to do.
[Note to Phobos: this is, IMHO, a quintessential Theory Development thread]
Thomas2,
You should doubt everything that allows a singularity in its beginning. And that is where the standard interpretation of redshift leads us. What if light ages and expands on its way from the distant galaxies, as shown in Savov's theory of interaction.
The expansion interpretation of redshifts does not necessarily lead to a singularity or does it necessarily lead to a temporal beginning
The expansion of the ageing light photon creates redshift. This expansion is similar to that of the much larger sources of interaction, which depending on their size create what we observe as space, time, cosmic bodies, etc. and then describe in the models of the universe [1].
There is no such thing as tempral beginning. Simply the all-building souces of interaction appear in different sizes to create what we see as space, time and everything else [1].
Savov, E., Theory of Interaction, Geones Books, 2002.
Moving this topic to the Theory Development forum.
Can you give a link to a peer-reviewed paper?
If not, how about some equations which link 'the ageing light photon' with redshift?
In Savov's idea, what is the CMB? How to account for its angular power spectrum?
Can Savov predict the (rest) mass(es) of the neutrino(s)? How about the Higgs? the lightest supersymmetric particle?
Thomas2 wrote: This means that not only is the wave frequency redshifted but also the light curve broadened.
Data which supports your prediction? You may wish to use that published in one or more of the large redshift surveys, and the high-z supernova searches.
BTW, how do you account for the CMB?
This is not my prediction but what is claimed to be observed by cosmologists (see http://www.astro.ucla.edu/~wright/tiredlit.htm ). They claim that the observations could only be reproduced by the Big Bang model, which is clearly incorrect as the purely mathematical argument in my opening post shows. For a further discussion on this issue see the Google's sci.astro.research newsgroup in which Ned Wright's further arguments are clearly invalidated.
