Reducing 1M to 7: Is There a Shorter Way?
  • Thread starter Thread starter recon
The discussion revolves around the challenge of reducing the number 1,000,000 to 7 using only basic arithmetic functions (+, -, ×, /) and the digit 7. Participants explore various methods, initially presenting lengthy solutions involving divisions and subtractions of fractions like 7/7. Some suggest that using a basic calculator limits the approach, as it does not allow for advanced functions like powers or decimals. Several solutions are proposed, including manipulating the number with repeated operations involving 7, such as subtracting multiples of 7 or using combinations of 7 and its multiples. A notable point is the emphasis on finding the shortest method in terms of keystrokes, with some participants calculating their approaches and refining them for efficiency. The conversation highlights the complexity of the problem and the creativity involved in arriving at a solution, with various attempts leading to close but not exact results. The challenge remains open for further exploration and optimization.
recon
Can you reduce 1,000,000 to 7 using only the functions +,-,X and / with the digit 7?
I know a lengthy way of doing it - [1,000,000 - \frac{7}{7}] \div 7 \div 7 \div 7 ....
Is there a shorter way?
(1,000,000 - \frac{7}{7}) \div(7^7) \div(7^7)...
It is a bit shorter.
The Bob (2004 ©)
EDIT: (1,000,000 - \frac{7}{7}) \div(7^7) = 1.2142645 That decimal run does not seem to have a fraction that can be put to it so I am stuck on how you got 7 from what you had.
[(1,000,000 - \frac{7}{7}) \div(7^7)]+[(7\times\frac{7}{7})-\frac{7}{7}]= 7.2142645 which is close.
\left(\frac{77 - 7}{7}\right)^{(7 - \frac{7}{7})}
I forgot to mention that you're supposed to solve this by using a basic calculator that has no 'power' function. This renders the two solutions above to the realm of the 'lengthy'.
\left(\frac{77 - 7}{7}\right)\left(\frac{77 - 7}{7}\right)\left(\frac{77 - 7}{7}\right)\left(\frac{77 - 7}{7}\right)\left(\frac{77 - 7}{7}\right)\left(\frac{77 - 7}{7}\right)
or
\left(777 + 7 \times 77 - \left(7 + 7 + 7 + 7 + \frac{7}{7}\right)\right) \times 777 + \frac{7}{7}
or
\frac{7,777,777 - 777,777}{7}
or even
\frac{777777}{.777777}
Sorry ceptimus, but you've got to start out with the number 1,000,000 and then reduce this number to 7 using anyone of the basic functions mentioned in my earlier post.
1,000,000 \times \frac{.777777 \times 7}{777777} = 7
Sorry to disappoint you again. It seems that I have not explained the problem properly. Try to imagine that you're using a calculator that has only the buttons 1,0,7,+,-,\div, \times, =. You may only use the 1 and 0 buttons for inputing the number 1,000,000 and for nothing else.
So you can now see that it is not possible to use decimal points the way you used it. :)
How about
1,000,000 \times (7 - 7) + 7 = 7
:-p
OK, that still uses brackets, and it's cheating.
I like that! :smile: However, I think that's cheating... o:)
Then again, I also did cheat with the brackets in my first post.
This works on a basic 4-function calculator without a decimal point.
1,000,000\;-\;7\;\div\;7\;=\;\div\;777\;-\;7\;\times\;77\;+\;7\;+\;7\;+\;7\;+\;7\;+\;7\;\div\;7\;=\times\;7\;\div\;777\;=
Did you mean :
([1,000,000 - \frac{7}{7}] \div 7) - 7 - 7 ... ~~~?
If you're allowed to hit the 1/X button (which you're not), there's an easy way :
(1,000,000 + (777,777/7) )/7,777,777...and take the reciprocal.
Gokul43201 said:
Did you mean :
Actually, yes. But it still won't work. :mad:
ceptimus said:
How about
:-p
If you don't have to say 1,000,000 _first_, (7-7)*1000000 + 7 can be done on a basic calculator.
Or, if you take advantage of the limited # of digits that can be stored in a basic calculator, you can do something like 1000000 / 7777777777777777 + 7
I think this may be the hardest brain teaser, yet. :-p
It looks so simple, though... :cry:
Very interesting question.
1000000 - 777777 - 77777 (repeat twice) - 7777 (repeat 8 times) - 777 (five times) - 77 (seven times) - 7 (four times) *7
would be one rather convoluted solution. I'm sure there's something better though, some number up there ought to be an even multiple of 7, 77, 777, etc. I'm seeing if I can find a more solid solution.
Wow, I exahausive searched 7k, 77k, 777k.. with each other over +-10 and not a single number is divisible by 7 (or 77, 777 etc, though that would have been kind of a bounus). Unless I did it wrong (and it's entirely possible that I did) I can't find anything. There are several +- solutions that end up with 1 like the one I did above, like:
1000000
-777777
-77777 (3x)
+7777
+777 (4x)
+77 (3x)
-7
*7
for instance. I'm not sure what's considered the "shortest", like fewest buttons pushed? I might do a more solid optimize if I have time or if someone else would enjoy it then go ahead.
[EDIT] Doh.. Adding various multiples of 7 won't have much of an effect on divisibillity by 7, will it now? I'm still thinking about the posibillity of slight mods like *7+7/7 (i.e. +1) in strategic places though, that's probably the ticket if there is a trivial solution.
Been fiddling around a bit, here's one
1000000
*7
-7
/7
/777
-777
+7
+7
+7
+7
*7
+7
/7
/77
20 7s, 33 keystrokes not counting the million. It could probably be polished down a bit I'm sure. The essential trick here is that one can use *7 (several +-7, 77, 777) /7 to accomplish arbitrary additions (by 1, 11, 111 ...) to set things up for divides. There may be a need for = here and there, I don't have really have a "normal" calculator around to test it on.
Look at all the cool people that can do it in LaTeX...
* 7
- 7
/ 777 777
- 7
* 7
- 7
11 sevens, 18 keystrokes.
