Reference frames, center of rotation, etc
  • Context: Undergrad
  • Thread starter Thread starter gen x
88 replies · 8K views
gen x
Topic about reference frames, center of rotation, postion of origin etc
Comoving ref. frame is frame that is attached to moving object, does that mean, in that frame translation and rotation of object is zero, because origin and axes(x,y,z) are fixed to object? Is it same if you place origin of frame at object center of mass or at object tail?
What type of comoving frame exist? What is lab frame?
If we talk about center of rotation do we always need to specified from what frame we observe?
You can define it either way. Whatever is more convenient.
"Center of rotation" is ambiguous, even if the frame of reference is given, because there are infinitely many ways to decompose a rigid transformation into rotation and translation.
Reply
Suppose the object is rigid. Fixing the positions of any three points on the object is sufficient to construct a co-moving coordinate system. Any frame of reference that remains at rest with the system is also a co-moving coordinate system. Usually, one chooses a frame whose origin is at the center of mass.
A.T. said:
"Center of rotation" is ambiguous, even if the frame of reference is given, because there are infinitely many way to decompose a rigid transformation into rotation and translation.
To support this see the plots I posted below
Dale said:
This is just a mathematical fact of rigid body motion, purely kinematically. It has nothing to do with forces, just the way that rigid body motion behaves mathematically.
Suppose I have a rigid disk which is spinning about its center of mass. At a given instant I can plot the velocity of each point on the disk as follows:
The formula for the velocity field is ##\vec v=(y,-x)##. This is rotation around the center, as expected.
However, suppose instead of a disk rotating, we have a wheel rolling. Kinematically these are the same motion in different reference frames. Then at any given instant I can plot the velocity of each point on the wheel as follows:
The formula for the velocity field is ##\vec v=(y,-x)+(1,0)##. Notice that this motion is also a pure rotation, but about the bottom of the wheel, the point that it contacts the ground. Again, this is kinematically identical to the disk rotating about the center in a different reference frame.
These two points are not special. In fact, for any point on the wheel you can pick a reference frame where that point is momentarily at rest. When you do so the motion is as follows:
The formula for this velocity field is ##\vec v=(y,-x)+(0,0.7)##. Notice again that this motion is momentarily a pure rotation about the chosen point which happens to be ##(0.7,0)##.
This is a general feature of rigid body motion. You can always decompose the velocity of the material points in a rigid body into a pure rotation about any point and a rigid translation.
So again, it isn't that the rotation is about the center of mass, but that the translation of the center of mass is particularly simple.
Reply
gen x said:
What is lab frame?
I am afraid this notion is not completely formalized. Say a lab frame is an inertial frame you are sitting in and with respect to which you are observing the motion.
The notion of instantaneous center of rotation is well defined for planar problems of rigid body kinematics. But it is not a part of the minimum needed for problem solving.
If origin and axes are fixed to object, then nothing moves, so what I can calculate here? what is point of that frame?
Dale said:
What is purpose of that center, if I put here ball bearing, that wheel cant be driven, because car will jumps(unballance)?
From ground frame wheel of car has instantaneous Center of Rotation at contact patch, from car frame center of rotation is at wheel CoM(ball bearing)?
How to find pivot point for this stick, we know CoM, two forces, stick lay on table, F2 is center of lateral friction force from table surface. F1 and F2 are constant forces, not impulse
wrobel said:
It is a very bad idea to throw kinematics and dynamics in the same heap
how do you mean?
gen x said:
how do you mean?
I mean that one should first study kinematics and after that dynamics.
Any motion is defined with respect to some frame only. So what?
He talk how objects naturally rotate about their Centers of Mass, from which frame?
Do you agree that object tend to rotate about their Centers of Mass?
This phrase does not make sense.
Why not?
When doing physics on Earth, we usually use a reference frame with origin and axes fixed to the Earth.
Depends on the definition of "to rotate about a point", as already explained above, and in many previous threads:
https://www.physicsforums.com/threa...ays-rotate-about-their-centre-of-mass.990571/
https://www.physicsforums.com/threads/does-every-object-rotate-around-its-center-of-gravity.998359/
https://www.physicsforums.com/threa...-rotate-only-about-its-center-of-mass.986625/
https://www.physicsforums.com/threads/does-the-moon-rotate-on-its-axis.874223/
Question:
Leo Liu said:
Why do unconstrained objects always rotate about the lines passing through their CMs when tangential forces are applied to them? I understand that if an object does not rotate about its CM, then its rotation will decay to the rotation about the axis passing through its CM.
Answer:
Dale said:
If they did not then the center of mass would not be traveling in a straight line. This would violate Newton’s first law.
Objects always rotate about the lines passing through their CM is only valid when net force=zero?
But isn't we say that object rotate around any point?
Relitivization of the turning point, if that point is relative then we can't say object rotate around that point.
gen x said:
Answer:
Here a more recent and accurate answer by the same poster, already quoted in this thread:
It's not about being relative in the sense of 'frame dependent'. Even when the frame is given, you can say it rotates about any point, by choosing the matching translation of that point. But as written above, some translations are simpler, and thus more convenient.
Reply
FYI Landau-Lifsitz's Mechanics explains in section 31
Then they investigate the case where O' which is distance a from O is taken. I recommed you to find a copy and read it.
The point is to show that any point can be chosen as the center, if desired. You have freedom to choose the center.
You misunderstand. All of those plots show the same motion of the same object at the same time. In all three plots the axle is in the center of the wheel and the wheel is spinning smoothly. There is no physical difference between the three. The differences are purely mathematical. For the same rigid physical motion you can choose any point and decompose the total motion as a translation and a rotation about that chosen point.
What does it mean for a point to be a pivot point?
I would agree. I would also agree with someone who picked any other point. Rigid objects rotate about any given point at the every time.
Usually, you choose the point that makes the math easiest. Often that is the center of mass.
I did explain that later in the same thread. If you are reading that thread then keep reading. It is a long one.
Can we ask where is physical center of rotation of object, does that make more sense?
Not really, because the problem is that there are multiple ways to break the motion of a rigid body into rotation and translation, and they all give different answers for where the center of the rotation is. All are equally valid.
Intuitively, you probably want to pick the center of mass frame, and then the rotation is about the center of mass. But you are not obliged to do so.
Reply
Does that apply to center of revolution as well?
You can ask “which center of rotation makes my analysis easiest”.
I have never encountered the term "center of revolution" in the context of physics. Nor has Google, it seems. The references it found were to politics and war.
Can you explain what you mean by "center of revolution" as distinct from "center of rotation"? Maybe the barycenter of a pair of objects orbiting one another?
Reply
Throwing even more unspecific terms at this forum will not yield more specific answers.
So yes, you are talking about the case of two or more objects orbitting one another.
In that case we do not have a rigid body and the concept of rigid rotation about a point is not relevant.
Reply
But the same applies here:
- For mere kinematics, any "center of revolution" is as good as another.
- For dynamics, there are choices more convenient than others, but we still have the choice.
Reply
I think that more important than a label of rotation vs revolution you should focus on rigid vs non-rigid motion.
Rigid motion can be decomposed into a rotation about any arbitrary point and a translation. Non-rigid motion can not generally be decomposed into such simple motions at all.
The spinning of a planet is (to a good approximation) a rigid motion. The orbital motion of a planet is not a rigid motion.
For orbital motion the center is not a kinematic concept. It is a dynamic concept, i.e. a central force rather than a center of revolution.
Edit: I see I am late to saying the same thing others have said
Why is not rigid motion?
@jbriggs444
@A.T.
How can you throw wheel/stick in the air and force to not rotate around CoM? I think it is impossible to not rotate around com. Isnt it?
Reply
  • Sad
